Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Just my opinion Jim but I think your car looks much better without the pins. Are you doing this because you're concerned about hood security or is it just something to do? I would leave them off and am re-considering installing the pins on my car. I doubt I'll do it.
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Jim, you have the upper plates laid out wrong to my eye.
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
Two pins on Kermee, good for over 150mph at Daytona...
Attached thumbnail(s) ![]() |
Larmo63 |
A very smart Porsche guy told me the only authentic use of hood pins on a 914 front bonnet is when you have a fiberglass hood. Same thing goes for the rear rubber latches on the rear trunk lid.
I think that is sound policy. |
Elliot Cannon |
A very smart Porsche guy told me the only authentic use of hood pins on a 914 front bonnet is only when you have a fiberglass hood. Same thing goes for the rear rubber latches on the rear trunk lid. I think that is sound policy. Both my trunk lids are fiberglass. Maybe I should re-think this. But then again my car rarely sees 150 MPH. (IMG:style_emoticons/default/laugh.gif) |
forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
Not sure if this was noted earlier in this thread but the original GT hood pins were tapered and not simply a domed cylinder. The taper takes care of most angle issues as the hood and strike-plates can be loweresd down on the smaller tapered top and by the time the hood is seated, the hood pin plate holes are snug against the full bore of the hood pin. Mine are aluminum and easy to taper slightly on a lathe or drill press / I have never had an issue with four pins.
(IMG:style_emoticons/default/beerchug.gif) |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Larmo63 |
Larmo63 |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
Just my opinion Jim but I think your car looks much better without the pins. Are you doing this because you're concerned about hood security or is it just something to do? I would leave them off and am re-considering installing the pins on my car. I doubt I'll do it. to nice to be drilling hole in (IMG:style_emoticons/default/slap.gif) and there hideous I`d rethink that one,but it is your car have fun (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 09:08 AM |
