anyone else's targa top squeak? |
pete914 |
Sep 11 2007, 08:35 PM
Member Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
haven't driven my teener with the top on it in some time. i forgot that the top squeaks a bit from the passenger's rear corner when going over bumps. this is obviously from body flex. however, you can jump up and down on the seat while rolling up the window and it doesn't hang up.
(IMG:style_emoticons/default/WTF.gif) |
Pat Garvey |
Sep 11 2007, 08:46 PM
haven't driven my teener with the top on it in some time. i forgot that the top squeaks a bit from the passenger's rear corner when going over bumps. this is obviously from body flex. however, you can jump up and down on the seat while rolling up the window and it doesn't hang up. (IMG:style_emoticons/default/WTF.gif) Try putting glycerin on the seals. Pat |
malaga_red75 |
Sep 11 2007, 09:00 PM
'74 2.5L N/A Subie Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None |
you might want to check out the point where the latch attaches to the little nub from the top. mine was making noise and all i had to do was put some rubber tubing over the nub and the sound went away. I used watering tubing for small bushes and trees and what not...
PeeGreen 914 |
Sep 11 2007, 09:57 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
You could just keep it off (IMG:style_emoticons/default/biggrin.gif)
jimtab |
Sep 12 2007, 12:16 AM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
I used shrink tubing on the latches...nice and tight and quiet now...
So.Cal.914 |
Sep 12 2007, 06:33 AM
QUOTE anyone else's targa top squeak? Anyone have a targa top that dosen't squeak? At one time or another? All the above advise is good...and works. |
pfierb |
Sep 12 2007, 06:40 AM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
you might want to check out the point where the latch attaches to the little nub from the top. mine was making noise and all i had to do was put some rubber tubing over the nub and the sound went away. I used watering tubing for small bushes and trees and what not... That's what silenced mine...Peace and quiet now |
Toast |
Sep 12 2007, 02:11 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
OMG, does it ever!?!
Mine squeeks from the exact same spot, and has since I have owned it!! I have tried adding felt around the targa, using 303 Protectant (a seal softener), putting padding where the latch knobby thingies are to try to make the top press down more firmly to the body, adjusting the latches..............(IMG:style_emoticons/default/headbang.gif) Other than replacing the rear seal itself :trackfees:, I think I have tried just about everything and It STILL SQUEAKS!! If you find a remedy, Please Post it Here!! (IMG:style_emoticons/default/toast.gif) |
porschecb |
Sep 12 2007, 02:22 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
I used a tiny, tiny black wire tie to make the gap tighter. No squeaks for over 2 years now and with the top off you can hardly notice it unless you were looking for it. I like the shrink tube idea also. But thought that might wear through over time. (IMG:style_emoticons/default/aktion035.gif)
Johny Blackstain |
Sep 12 2007, 02:44 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I just tried the shrink tube & it works. Nice. Double wrapped it to make it tighter & last longer. When it wears out I'll just do it again.
cassidy_bolger |
Sep 12 2007, 02:59 PM
Member Group: Members Posts: 106 Joined: 17-March 06 From: = Member No.: 5,737 Region Association: None |
can you post a picture?
thx |
mikerose |
Sep 12 2007, 03:31 PM
Happy to be back Group: Members Posts: 657 Joined: 31-December 02 From: Pittsburg,ca Member No.: 60 Region Association: None |
can you post a picture? thx (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Attached image(s) |
Joe Ricard |
Sep 12 2007, 04:02 PM
I have no idea if it sqeaks. Between the Tangerine and Webers, GT engine lid and no back pad.
Oh and I normally wear ear plugs and or a helmet. |
pete914 |
Sep 12 2007, 04:52 PM
shrink tubing around the "hooks" sounds like a good idea to me. glad to hear i'm not alone in this.
PeeGreen 914 |
Sep 12 2007, 05:00 PM
I have no idea if it sqeaks. Between the Tangerine and Webers, GT engine lid and no back pad. Oh and I normally wear ear plugs and or a helmet. (IMG:style_emoticons/default/aktion035.gif) Same here. Well, that and I rarely have the top on. |
Johny Blackstain |
Sep 12 2007, 05:36 PM
can you post a picture? thx Sorry, this is the best I could get. I tried 4 different shots & the damned digital camera would not focus right. You can see I used a piece of sheet metal as a shield against the lighter. A heat gun would have been better. Just slip it on the roof nub & heat it up. Clamp the clamps & you're done. Attached image(s) |
jimtab |
Sep 12 2007, 09:06 PM
Hey, did Andy take that pic?? (IMG:style_emoticons/default/biggrin.gif)
Pat Garvey |
Sep 12 2007, 09:14 PM
I repeat my earlier statement - glycerine!
My squeak started & ended in 1974. Did I mention glycerine? Quiet since, though I did re-treat all the seals in '84. Hmmm, probably ready again about now. Besides, unless its raining, why would the top be on? |
Eric_Shea |
Sep 12 2007, 09:35 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE anyone else's targa top squeak? Nope... never happens on a 914. (IMG:style_emoticons/default/wink.gif) |
cassidy_bolger |
Sep 12 2007, 11:09 PM
Johny,
Thanks for the pics, I get what you guys are saying now. About the camera, try pressing the "macro" button - should look like a little flower - for closeup focus. And, call me an idiot, but what the hell is glycerine? I have heard of nitro-glycerine (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:28 AM |
