alpha434 |
My member number is no coincidence. ![]() ![]() ![]() ![]() Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains ![]() |
Alright. How do I make it?
I have a source for the ferro-fluid. I just don't know how to get it to bond into a paint. And I'm sure someone here knows. I'll just bet Clayton shows up here and says he's got a 55 gallon drum in his basement. (IMG:style_emoticons/default/KMA.gif) |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
I have a 55 gallon drum of it in my basement.
Clayton |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Brush it on... The brush marks scatter IR patterns and make for near invisibility.
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
You can get similar results with a hot glue gun and a jumbo sized box of paper clips.
hcdmueller |
????????????? ![]() ![]() ![]() Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England ![]() ![]() |
A few years ago one of my friends used to work Aircraft Structural Maintenance. He painted his sportbike with some leftovers from work. Bikes already have a low signature to begin with. His was completely invisible to radar. We used to test it out all the time with those huge radar signs the cops put out in Florida.
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
stir it into some semi-gloss clear and see what happens!
SlackeR32 |
Newbie ![]() Group: Members Posts: 20 Joined: 30-August 07 From: Denver Member No.: 8,057 ![]() |
I have a source for the ferro-fluid.... I dont think ferro fluid is going to help you. You need something disapative (not entierly conductive) with a resonance near radar freq. Microwaves are also commonly called centimeter waves, so you'll need something in that ballpark. The paperclips are a better idea, but heavy. Shredded carbon fiber is my best suggestion short of actually getting the real deal. |
RoninEclipse2G |
Suby Geek ![]() ![]() Group: Members Posts: 232 Joined: 28-April 07 From: Parker, Colorado Member No.: 7,701 Region Association: Rocky Mountains ![]() |
When I had one of my cars painted flat black, most radar wouldn't pick it up until I was ~150 ft away, I used to think a permanent radar post on my way to work was broken, then I drove the subaru past it, got me all the way up the hill 1/2 mile away
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
yup my fiberglass hood paineted flat black with glass bumper and air dam screws with those X band sites. but K or KA no chance. Freaking Laser is so last minute. Saw the cop with a car pulled over, he turns around and points the laser. instant BUSTED you ain't got a prayer. Good thing I wasn't speeding.
RoninEclipse2G |
laser can be avoided, don't have reflective headlamps or a front license plate, basically shy away fron anything that will reflect light and is fairly flat. glossy paint doesn't help
TonyAKAVW |
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None ![]() |
So there are a couple ways to absorb RF. First is to absorb the magnetic field component and the second is to absorb the electric field portion (since microwaves are electro-magnetic waves) While I don't know what ferrofluid would do, the idea of using iron filings suspended in paint could work. At least two companies manufacture H-field (magnetic field) absorbers using this. One of the common applications of this is to reduce the tendency of a metal cavity to resonate. You'll see the stuff applied to the top of the cavity. Its called flexible ferrite...
The other method using carbon is commonly used for absorbing propogating waves. Carbon loaded foams are used to line the walls of anechoic chambers for testing antennas, etc. Black ESD foam is a form of carbon loaded foam. There are different types of carbon loaded foams, with varying carbon-profiles and densities. Tuning the thickness of thees can help absorb narrow ranges of microwave frequencies. So you can actually buy paints that are microwave absorbing, but to have maximum benefit it will need to be applied thick. If you want to make your own, go buy some carbon black powder and mix it in with paint. I suggest carbon because its less prone to rust (IMG:style_emoticons/default/smile.gif) And as other said, make sure to remove or coat any reflective surfaces. If it reflects light, it will probably reflect RF. Also things inside your car can cause reflections as well. Paperclips or any metallic element would be about the worst thing you could do. Think of what planes do for countermeasures... They eject a cloud of reflective metal pieces. Metal is reflective. Radar works on reflections (IMG:style_emoticons/default/smile.gif) -Tony |
balljoint |
Damn. I thought I had something there for a while.
Brian Mifsud |
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None ![]() |
Anti Radar, Anti Sonar... I think I have what you need.
I buy surplus paint from the Mare Island Shipyard from an old guy who advertises as "The Paint Guy" in marine publications. He sells 2 gallon packs of "Epoxy" for $10. It is very black when mixed, smells to very high heaven, and I'm sure ultra toxic. It was used to paint our nuclear subs...... I painted my Chevy's (formerly) chromed rubrail on the top of the pickup's tailgate with a paint brush after I sanded off the rust so does this mean my tailgate is immune to being torpedoed??? Good stuff.. it is so toxic, it keeps the oysters from anchoring on the iron ballast casting on my sailboat... Can't beat the price either. |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Nothing beats the absorbency of a pallet load of maxi pads stuck to your car (IMG:style_emoticons/default/thumb3d.gif)
ztbell |
Newbie ![]() Group: Members Posts: 44 Joined: 8-August 06 From: Jacksonville, Illinois Member No.: 6,619 Region Association: None ![]() |
(IMG:style_emoticons/default/gint.gif)
smear some of that stuff on my X's |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
the point of this excersize is lost on me.
k |
alpha434 |
Ferrofluid is a liquid that has both magnetic tendencies and is electrically conductive. It is the primary component to the paint that the military currently uses for the stealths.
I just don't know how to make it bond properly, or if it would function properly as a mixture with "normal" paint. Brian. Your's sounds like the older "iron ball" paint. Which would work just fine. What kind of finish does it leave? |
Rick_Eberle |
Member ![]() ![]() Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 ![]() |
Get some pheromones too... then you'll be invisible to cops, AND irresistible to women! (IMG:style_emoticons/default/av-943.gif)
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Ferrofluid is a liquid that has both magnetic tendencies and is electrically conductive. It is the primary component to the paint that the military currently uses for the stealths. I just don't know how to make it bond properly, or if it would function properly as a mixture with "normal" paint. Brian. Your's sounds like the older "iron ball" paint. Which would work just fine. What kind of finish does it leave? Ferro fluid is very fine iron particles in an oil suspension. You will find it is often used in high power speakers. I work with engraving machines. Ferro fluid is used as a dampening component. I am interested in what you have found. I would like to acquire some myself. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Not to get off topic here, but go and buy one of those motion sensors like they have at the grocery story (you know the kind that set off your radar detector), mount it some where facing forward, next time your tooling along and need that volvo station wagon with a radar detector out of your way, pow, flip the switch, he'll get out of your way! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
Just kidding I would not recommend doing this, but the practical application is interesting. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:20 AM |
