3 Pages V < 1 2 3
> My engine temps are high...real high, Paging Jake Raby
thomasotten
post Sep 20 2007, 04:14 PM
Post #41
I believe it MUST have the thermostat flaps, but in Texas, not necessarily the thermostat. Without the flaps, air is not directed properly into the oil cooler fins.
purple
post Sep 20 2007, 06:11 PM
Post #42
Pigeon feeders attract me
thankfully i have the flaps.
As I've read the flaps close off the oil cooler air until it's up to a certain temp.
My oil takes quite a long time to heat up.
I went after the tin with my HVAC speed tape and closed off everything. Question, it looks like there were holes on the side of the tin for the spark plugs. This means that it's not 2.0L tin, right? Thomas had some really hot converted tin that he needs to sell me (IMG:style_emoticons/default/wink.gif)
Why is 2.0L tin so rare? are there advantages to running this stuff over 1.7L converted tin?
TIN TIN TIN!
Rand
post Sep 20 2007, 06:50 PM
Post #43
Cross Member
QUOTE(Jake Raby @ Sep 20 2007, 02:12 PM) *
I have ALL the sheetmetal and dozens of each piece in my stockpile cheap, because our conversions don't use it...
What do your systems use now Jake? They aren't all DTM are they?
toon1
post Sep 21 2007, 08:53 AM
Post #44
QUOTE(purple @ Sep 20 2007, 05:11 PM) *
TIN TIN TIN!
Take some pics of what you are talking about.
The reason 2.0 tin is rare is because everyone wants it.
Jake Raby
post Sep 21 2007, 09:12 AM
Post #45
Engine Surgeon
QUOTE(Rand @ Sep 20 2007, 05:50 PM) *
Yes, the DTM is standard, stock sheetmetal is an option on all my turnkeys except the lowest performance version of the 2056 that uses stock EFI.
purple
post Sep 21 2007, 10:10 AM
Post #46
Jake....would it be completely advantageous to put the DTM on here? Should I focus on other things first?
rhodyguy
post Sep 21 2007, 10:22 AM
Post #47
the plug angle is dif on the 2.0 vs 1.7/1.8 heads. hense the dif on the plug hole locations.
k
stateofidleness
post Sep 21 2007, 10:25 AM
Post #48
does anyone have pictures of this tin? and these "flaps"? as ive recently found out that im most likely missing mine...
toon1
post Sep 21 2007, 11:02 AM
Post #49
QUOTE(stateofidleness @ Sep 21 2007, 09:25 AM) *
The tin he is refering to are the two pieces that go ontop of the motor that have the spark plug acess holes.
The flaps he is refering to are on the top and inside of the fan shroud.
The flaps are connected to the bellows by a wire/cable on the bottom of the engine case on the drivers side.
The flaps direct air over the top of the oil cooler when the bellow expandes
Again take pics. of what you have then it we can tell you what's missing.
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 31st October 2024 - 07:26 PM
