v8 t-stat, what else should i check |
John2kx |
Dec 29 2003, 03:15 AM
Senior Member Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 |
Paul,
As a reference, my fans turn on at 179.6F and off at 170F, as measured from a probe in radiator. Engine temperature when this occurs (as measured from a probe in intake), fans come on a little over 180F and off a little under 180F. You might have your fans coming on a little too late and suffering from a snowball effect where your system can never catch up. FYI, my fans don't kick in unless at idle or in bumper to bumper traffic.......never while car is continuously moving at any speed above about 30 mph. I've never seen high temps. (260F) at idle. This is where your making the least amount of heat in engine. Allow the fans to run manually at idle (prior to reaching 160F or so) and see what happens. What size is hole in front of radiator/bumper? How is air escaping front hood area? Is outlet opening(s) twice the size of inlet? John |
smrz914 |
Dec 29 2003, 03:12 PM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
Oh it doesn't matter when the fans turn on it still get's hot. I have a pretty big opening in the front of my car. and openings in the hood and the fenders. The hood I opened as an attempt to cool better but it did nothing. The hood was crap anyway, 2 front end collisions. Anyway the water going back to the engine is definitly cooler then what is coming in.
IT's raining so I can't do any work, rats. |
smrz914 |
Dec 30 2003, 08:49 PM
I checked the spark plugs and they look really good. The oil looks fine, no signs of water.
QUOTE Did you see the bubbles completely go away at your fill point while engine was warming up? If you lower the level at that point about 1" and increase idle to about 1200-1500 or so, you will be able to run engine while water is expanding. If air bubbles you present then, I'd suspect a blown head gasket. You could also pull your plugs.........if a cylinder is pumping water, you'll see a rusty color on plug. no bubbles if i increase the idle. The guy at the parts store suggested that i ring the car for about 15 sec. and see if there is any buildup of presure for the cylinders. That turned out negative. No word from Meuller. |
John2kx |
Dec 31 2003, 02:18 AM
Time to try another gage.
smrz914 |
Dec 31 2003, 02:24 AM
what is the guage going to do? The car is boiling over. It is hot. It's not the guage that is overheating it.
Brad Roberts |
Dec 31 2003, 04:25 AM
Paul,
where are you located ?? I need to deliver a tranny near Sac this week. I would rather see this in person and try to help you out. B |
John2kx |
Dec 31 2003, 10:34 AM
Paul,
I didn't know you were boiling over.........never heard that in your previous posts and thought your gage was suspect. Take Brad up on his offer to help in person. The brief/vague descriptions you've described are somewhat difficult to use in diagnosing problem. Good luck, John |
smrz914 |
Jan 1 2004, 07:18 PM
brad- I'm in lafayette, east bay, close to walnut creek and pleasand hill. My car is outside and i have no garage so i only work on it when it's not raining. I'll send you a note with address and phone# and i'm around all the time just let me know when you have time. I appriciate the offer.
john- It's hard to include everything sonce there are so many variables. I thought i mentioned it boiling over but who knows. |
Lo-Fi Version | Time is now: 26th December 2024 - 09:33 AM |
