purple |
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None ![]() |
I only know this from RC engines, but when you put a tube like that on an intake, you're tuning your intake to a certain RPM...and I've never seen something like that work well. Methinks mounting ONE cone straight up and down on the middle round part would serve you better than those two tubes.
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
Whats worse for HP is the throttle butterfly, for maximum torque you really need to speed up the velocity of the intake charge. Theoretically, the system would work best if the TB was about 10x its diameter away from the intake manifold. Not that this works with a v8 system, its slightly impractical packaging.
Now, a v8 engine is suceptable to these RPM tunings, but unless you are working towards maximum power its not a big deal. RC engines are highly tuned in regard to SBCs. |
Brian Mifsud |
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None ![]() |
well, I dont' care what any of you say.. and I AM an engineer...so go to hell!!!
he is absolutely right, and I don't give a rats ass what any of you chip-on-the-shoulder shadetree mechanic say.... IT DOES LOOK LIKE THE ROBOT!!! (IMG:http://www.culttvman2.com/dnn/Portals/0/Gallery/John%20Zizolfo/Lost%20In%20Space%20Robot/JZrobot.jpg) (IMG:http://members.cox.net/stdotjohn/Air%20Filters%20600.jpg) And I like it alot!!!! |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
If heat is not an issue, I like it. Looks like the rest of your car...Unique.
But those are some pretty small straws. |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
Screw the filter idea. Just make a huge velocity stack out of some sheet metal. (IMG:style_emoticons/default/laugh.gif)
drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
Screw the filter idea. Just make a huge velocity stack out of some sheet metal. (IMG:style_emoticons/default/laugh.gif) I just may pick up another engine lid and do just that! I put the old filter back on (IMG:style_emoticons/default/brain.gif) |
Jax914 |
Schwienhund Rennenmannshaft ![]() ![]() Group: Members Posts: 138 Joined: 7-August 06 From: Jacksonville, FL Member No.: 6,602 Region Association: South East States ![]() |
ditto on the straws....
But I'd be more concerned about the tiny volume above the air horn. The short, small "can" probably won't do much for a nice smooth airflow. I think someone above was hinting that you'll probably have inconsistent efficiency - possibly resulting in rich/lean conditions. You normally don't see a small cover like this except in forced induction applications - where airflow efficiency becomes less a concern because of the pressured environment. I'd consider going to something larger like a typical SBC dual snorkel filter - you could still dual filter it, but you could also fit an airhorn to smooth the airflow. .02 Troy |
Maltese Falcon |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,709 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
![]() K & N makes this cast alum bonnet and has a perfect 4" dia. snout. This pic is with a 4" flex alum flex tube (prototype) going to a 4" neck x 10" long K & N filter. The filter is (not seen) tucked into the rear qtr. area , and gets some cold air from a duct on the fender. Since the pic, I've installed a custom mandrel bend 4" dia. tube in place of the flex. It works totally better than the old style top mount filter (IMG:style_emoticons/default/smile.gif) Marty |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
spunone |
Senior Member ![]() ![]() ![]() Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California ![]() |
Why don't we make a low profile stack that will fit a stock filter ??? (IMG:style_emoticons/default/smash.gif) probally cost ya a couple beers??
Lo-Fi Version | Time is now: 18th June 2024 - 05:29 AM |
