Bringing out the dead |
tdgray |
Nov 12 2007, 10:20 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Absolutley incredible Jeff... you have the talent I only wish I could have.
Very nice INDEED ! |
flippa |
Nov 12 2007, 11:05 AM
Advanced Member Group: Members Posts: 3,178 Joined: 7-May 07 From: Boston, MA Member No.: 7,720 Region Association: North East States |
Jeff, you are the man!!!!!
I am just beginning my project. Thanks for taking the time to post all this great work. You don't even know how helpful this has been and how much time & aggravation you are saving me. Keep the great work & education coming. Thanks |
restore2seater |
Nov 12 2007, 07:06 PM
Future 914 copilot. Group: Members Posts: 311 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
Jeff,
Have you ever used Picklex-20 before? If you have what's your opinion of it? The reason I'm asking is, when repairing several small areas on one or more panels rather than mixing up a small amount of epoxy primer and spraying the bare metal a spot at a time you could use this to protect the metal until you have a large enough area to mix up one batch of epoxy primer to cover all the small areas. |
Jeff Hail |
Nov 12 2007, 08:14 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Jeff, Have you ever used Picklex-20 before? If you have what's your opinion of it? The reason I'm asking is, when repairing several small areas on one or more panels rather than mixing up a small amount of epoxy primer and spraying the bare metal a spot at a time you could use this to protect the metal until you have a large enough area to mix up one batch of epoxy primer to cover all the small areas. Never used the product. I do not think the tradename actually refers to Pickling though. Pickling is a process used to remove mill scale during the manufacturing. Mechanical removal and then a solution called Pickel liquor which is usually hydrochloric acid or nitric acid. Different types of steel (carbon, stainless etc) use different process's and chemicals. I do not like mixing small quanities of epoxy primer either. The primer and activator are expensive. It takes me longer to clean the spray gun than it does to apply. If I have to mix up some EP I try to find other things that need priming too like the dog, the neighbors kid (kidding). I will use EP on anything I take down to bare steel. It has better adhesion qualities than surfacers do. Super sticky and holds up better than standard catalyzed primers. Everyone has an opinion as to what is best. EP works for me. Actually if I have a small spot I will use some etching primer if it's temporary. I will sometimes let bare metal sit knowing I will be back in a day or a few to finish the area. If it is going to be a long period I will try to throw some cheap primer on even if it means sanding it down at a later time. |
restore2seater |
Nov 12 2007, 11:10 PM
I was watching an episode of Trucks (Spike TV) this weekend and they mentioned it as a way to seal the bare metal to prevent flash rust. First time I had heard of it.
I have done a few searches on a couple forums and really haven't read anything negative. The people who have used it commented that it works. I might give it a try when I start doing body work on my teener. |
Jeff Hail |
Nov 17 2007, 10:23 PM
Still waiting on tube for the tunnel. I hate waiting on parts!
Did some finish work in the trunk. Welded up some pin holes from the floor replacement. 100 pounds of StarBlast just sitting, might as well strip some paint! Media blasted the rear trunk, removed some scale at the taillight pockets and wheelhouses. A little feather edging. Now it's about 6 o'clock and the sun is down. A little fog is coming in tonight. Moisture and cold air is not what I need right now. The media blasting removed the zinc coating on the new rear floor. I need to get a coating on this now. Epoxy primed the rear compartment in the dark with a couple of floodlights so I can see. Finished the primer and the temperature dropped to about 58 degree's. Epoxy Primer won’t kick if it's to cold. With two heat lamps I created the "Worlds Largest Easy Bake Oven". It's a toasty 85 degree's inside the trunk. Enough to cure the Epoxy primer. Attached image(s) |
Jeff Hail |
Nov 20 2007, 12:11 AM
A little more on corrosion protection and applicators.
http://www.914world.com/bbs2/index.php?showtopic=78326 In case anyone wonders I am not a salesman for Wurth Products. I use them because they are superior to most of what I have found available on the market today. Start with the best and the finished product will speak for itself. |
Twise |
Nov 20 2007, 04:35 PM
Member Group: Members Posts: 475 Joined: 20-September 06 From: SoCal - Temecula Member No.: 6,881 Region Association: Southern California |
A little more on corrosion protection and applicators. http://www.914world.com/bbs2/index.php?showtopic=78326 In case anyone wonders I am not a salesman for Wurth Products. I use them because they are superior to most of what I have found available on the market today. Start with the best and the finished product will speak for itself. I second that... |
Jeff Hail |
Nov 24 2007, 09:26 PM
Sprayed the Wurth Seam Sealer in the trunk. Finally looks like a trunk again.
This will all get get covered in color later. Attached image(s) |
Jeff Hail |
Nov 24 2007, 09:32 PM
Did some more access work for the right rear long replacement. This piece is a bitch to install the entire part. Would be easier to section it behind the suspension console. The high road taken.
I had to cut a window at the trunk bulkhead. No way to get the whole piece in without the cut because it installs from below. I also media blasted the wheelhouse and bulkhead joint. This area is really tight to weld in so better it as "clean" as I can get it. Attached image(s) |
Jeff Hail |
Nov 24 2007, 09:39 PM
As you can see the rear long junction at the bulkhead is really confined behind the first wall. It was gas welded at the factory behind the first bulkhead wall. No access for factory resistance welding. This is a significant connection so I want full access to weld all 3 sides. I used a worn cut off disc to get access ( 2 inches of disc) for the vertical cut.
The last pic is before the prep work (ugly) Attached image(s) |
Jeff Hail |
Nov 24 2007, 09:50 PM
Applied some Metal Ready for conversion coating. This way once I install the rear long it will have some corrosion resistance inside the panel. These will get cavity waxed at completion after epoxy primer.
I am going to section the lower wheelhouse. You can tell from the battery tray area down the rust has perforated the panel just behind the firewall. This was planned so when I install the inner rear long I will not weld it to the wheelhouse. Not even the media blasting would remove the rust. Pitted badly. I do not want to cut both the wheelhouse and inner long at the same time because the entire right 1/4 of the car is supported right now. I will join the rear inner long to the mid long and weld at the trunk bulhead. This way I have still retain full support during structural repairs. Once I cut the wheelhouse section I can coat the entire inner long from the wheelwell side with epoxy primer (except the flanges) and it will have superior protection. Attached image(s) |
Twystd1 |
Nov 24 2007, 10:34 PM
You don't want to know... really..... Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Jeff,
Rumor has it that you did all of the above work while cooking a turkey, watching a football game, solving a Rubics cube, winning 3 games of online poker and solved the Aids crisis in Rhodesia. How the hell do you do that....???????? LOL.... Jeff, This is simply great stuff that you are doing. Like many others. I am in awe of what you do. By the way... Joe Sharp is having a couple of get togethers in Huntington Beach on the first and the seventh of December. Ya wanna come down and meet the 914 peeps...????? You would be a most welcome guest. And I am bringing enough coffee for both of us..... And a backup pack of smokes.... By the way.... Ya know anyone that has a spare set of 15 X6 Fuchs for cheap??? (not deep ones) I need them to swap for a set of 7s and 8s. Cheers and keep it going bro.. This is so much fun to see this work in progress. If ya need me up there to help ya... Just PM me. I'm down to help if needed. Clayton |
Jeff Hail |
Nov 24 2007, 10:53 PM
Jeff, Rumor has it that you did all of the above work while cooking a turkey, watching a football game, solving a Rubics cube, winning 3 games of online poker and solved the Aids crisis in Rhodesia. How the hell do you do that....???????? LOL.... Jeff, This is simply great stuff that you are doing. Like many others. I am in awe of what you do. By the way... Joe Sharp is having a couple of get togethers in Huntington Beach on the first and the seventh of December. Ya wanna come down and meet the 914 peeps...????? You would be a most welcome guest. And I am bringing enough coffee for both of us..... And a backup pack of smokes.... By the way.... Ya know anyone that has a spare set of 15 X6 Fuchs for cheap??? (not deep ones) I need them to swap for a set of 7s and 8s. Cheers and keep it going bro.. This is so much fun to see this work in progress. If ya need me up there to help ya... Just PM me. I'm down to help if needed. Clayton Well the turkey has metal shaving's in it. Good source of iron though! The Rubiks Cube wasn't a challenge and I used it as a decoration in my fish tank years ago. Football? Nope....I like sports that use a stick. My best friends son was just voted National Rookie of the Year in baseball. Proud pappa! No gambling except for an occassional lottery ticket. Porsche's cost money you know? Hunger is cured with coffee, lots of strong black coffee. I have only been working on the car on the weekends. 10 hours or so a week. I want summer back. Won't be able to make the 1st or the 7th. Thanks for the invite. Wheels? I need a set of Rota's in 7 and 9 for my car. Something tells me I am going wih glass 1/4 panels so rear 10's might be in the lineup. If I can make my buddy part with an original set of RSR 9's and 11's I might shoehorn them in. |
Eric_Shea |
Nov 24 2007, 10:55 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Jeff, I have been reading your thread as you go along and I only have one question. Can I have your car when you are done??? QUOTE No! How about me? Can I have it? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif) |
Jeff Hail |
Nov 24 2007, 11:00 PM
QUOTE Jeff, I have been reading your thread as you go along and I only have one question. Can I have your car when you are done??? QUOTE No! How about me? Can I have it? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif) Eric will have the pleasure of rebuilding my calipers soon. At least you get a piece of the car! (IMG:style_emoticons/default/biggrin.gif) |
Eric_Shea |
Nov 24 2007, 11:03 PM
Yeah but... I have to give them back! (IMG:style_emoticons/default/biggrin.gif)
Keep up the good work bud. (IMG:style_emoticons/default/smilie_pokal.gif) Do you like to ski (and weld)? (IMG:style_emoticons/default/biggrin.gif) |
Jeff Hail |
Nov 24 2007, 11:19 PM
Yeah but... I have to give them back! (IMG:style_emoticons/default/biggrin.gif) Keep up the good work bud. (IMG:style_emoticons/default/smilie_pokal.gif) Do you like to ski (and weld)? (IMG:style_emoticons/default/biggrin.gif) I used to ski and race giant slalom 20 years ago as a young man. I became bored with skiing. Snowboarders slowed everyone down. (IMG:style_emoticons/default/dead horse.gif) Last time I raced was at Ajax/ Aspen a long time ago. Welding is fun. I get to burn things on purpose. (IMG:style_emoticons/default/welder.gif) |
Jeff Hail |
Nov 25 2007, 08:24 PM
Spent about 3 hours today fitting the new rear rail. I had a bit of re-work to get the dimensions right. It's not bad, just takes some time to fit.
Anyway the part whether new of aftermarket has to be fit and trimmed. Any sheetmetal part that is not bolt on and is supplied as cut to fit is going to take some work. The trick on the rear rail (AA Part) is to fit it to the front inner long first. From there you will get the correct pitch (angle) leading to the trunk bulkhead. This took some fiddling and trimming. I cut off about 1/4 inch at the rear and obtained the correct angle for a flush fit. I then had to fishmouth the front inner long to get some "play" in the adjustment. ( I hate bending a newly installed inner long) The pitch of the rear rail is 34 degree's as measured from the driver side. I am at 31 now. I need to drop the front ever so slightly (1/4 inch). This is imperitive for suspension geometry. Then I trimmed another 1/2 inch at the front long connection to get a verticle flush/ butt connection. (I still have to do some fine tuning with a grinder) This will need to be sleeved (double walled) as it is a highly stressed joint) I was hoping as I timmed back the new rear rail I could lap weld the joint but the convolutions did not allow that. No worry. I will modify the aftermarket part to incorporate the factory type reinforcement. If you look at the second picture you will see the top of the panel connection is really close. The bottom is way off. This is a manufacturing issue. I will adjust and weld the top first, then splay the rail (box) open some more to fit the bottom. As the fit process came to conclusion I held the new panel in with a C-clamp and cleco's. This is only a rough fit and not tack welded until I complete the adjustments by lowering rear rail by 1/4 of an inch at the front long connection. Attached image(s) |
Jeff Hail |
Nov 25 2007, 08:31 PM
For this installation a protractor or (inclination gauge) is worth it's weight in gold ($18). I can take fast comparitive measurements from side to side.
I have not been able to find specifications in print for this area from Celette, Mitchell or even the factory so it pays to have a tool for comparison. By making some fixtures for the control points prior this will alleviate any problems later. I also have an aftermarket suspension console to use for fit purposes. This will provide fit and additional comparison measurements for correct suspension geometry. Attached image(s) |
Lo-Fi Version | Time is now: 20th January 2025 - 06:43 PM |
