36 Pages V « < 6 7 8 9 > »
> Bringing out the dead
Jeff Hail
post Nov 25 2007, 08:52 PM
Post #126
Clecos are easier to work with than self-tapping screw's. They plug in and out. Cleco's have enough "slop" in them to allow slight adjustment if only a few are used. The more are used the more rigid the mock up. Once I get the position
of the part where it needs to be I will tack it with the MIG.
Jeff Hail
post Nov 25 2007, 09:41 PM
Post #127
The original outer wheelhouse has a reinforcement (double wall) welded to the inside. It has a ledge that locates the inner rail's top flange (highlighted). This was my reference point to measure the pitch of the original rail design along with the opposite left rail.
Nothing better than a factory template! Once I tack the rail at the trunk bulhead and top of the rail the lower flange will be a cinch to tweak as I go.
I wish I had more daylight. I want my summer hours back!
Jeff Hail
post Nov 25 2007, 10:21 PM
Post #128
Interesting Vitaloni's found in the box of extra's. I have not seen these since 1983. They are in perfect shape. No scratches on the glass or housings. Rubber in good perfect condition. Not California's, not Baby Turbos, not Classics.........That blue tinted glass is so 80's. They are actually pn# a right and left (not universal) pair.
They are marked Vitaloni Bravo III's which were standard on the the Lancia Zegato and Alfa Romeo's.
What the hell were these doing on a German car?
Aaron Cox
post Nov 26 2007, 09:25 PM
Post #129
Professional Lawn Dart
wow jeff.
wow. I just read your whole thread, after clayton told me about his visit to su casa.
Quite the craftsman!!! Keep up the good work buddy!
Aaron
Jeff Hail
post Dec 2 2007, 08:04 PM
Post #130
Busy week and weekend. No time to play. Work, birthdays, meetings etc.
Finished fitting the rear frame rail and punched the flange holes. Some minor adjustments to the rail with a grinder to improve the fit and butt joints.
Used some stock to square up the joints and clamped everything in place.
Not 100% happy with the fit. The AA part dimensionally has some issues.
The arc of the rail itself is not right and will have to be adjusted once I make some tacks. Then I can twist it into place. These things come up even with new oem parts so it just part of the process. That's why they call it work.
Jeff Hail
post Dec 2 2007, 08:23 PM
Post #131
More stock to square the inner long to the rear rail and clamp in place. You will notice the rectangle inside the long. Just some scrap that I can clamp in place to keep the panels straight and tight. Once you start tack welding metal tends to draw together. This just helps keep things in place so things don't go sideways.
Another tip is to keep the welder close enough that the controls are in arms reach.
One thing about welding on the 914 is you have the longs and rails which are about 17 gauge oem and 18 gauge non oem steel. The wheelhouse and trunk bulkhead are the same. The joint at the shock tower is close to 15 gauge. A few small heat adjustments are necessary on the fly.
Old 914 sheetmetal even when really clean can still have some issues. I have learned on many a Porsche that the best steel (Krupp and Thyssen) was not utilized and can be "dirty". During the manufacturing process the alloy can vary and this sometimes means more or less sulpher. Some parts such as the longs and rails are an early form of HSLA steel. (High strength low alloy) which mean's it is harder and stiffer. If you have ever tried welding a new steel panel to old steel on a 914 you know what I mean. A great weld, then a little popping and sputter here, blow a hole there. Its all part of the game. Prep metal and get it as clean as possible for welding.
Jeff Hail
post Dec 2 2007, 08:38 PM
Post #132
Enough talk. Time to burn some metal.
Tacked the rear at the bulhead then tacked the front at the bottom of the long.
Re-check fit and then lay on the heat. I like to seam weld thin sheetmetal in 1/2 to 1 inch burst's. This way I do not oveheat and warp the area but still get enough heat for proper penetration.
You will notice the top of the mid inner long is not tacked to the rear rail. This is where I have a little twist in the rail that needs some fitment. With the rear and lower tacked in I can get some leverage on the top and fit the butt joints better.
The outer wheelhouse is getting a section so no plug welds were made except for where the Cleco's were pinned.
Jeff Hail
post Dec 2 2007, 09:11 PM
Post #133
Crud!!!!!went to make another post and the site went dead for a minute. Lets try again.
The area's highlighted in yellow have no welds, plugs or tacks.
Area's in red have been tacked, seam welded and plugged.
I now have structural integrity again (sort of). The top of the rail at the top of the long is free. I need some adjustment room when I install the wheelhouse section
The entire right qtr panel, wheelhouse at the long / firewall junction have been held together with one single tack weld at the inside of the door jamb/ dogleg.
I could not perform these operations on jackstands. The door bars kept the door gaps open and everything rigid on the upper body. The rack below kept everything level.
Jeff Hail
post Dec 2 2007, 09:24 PM
Post #134
One single weld holding the qtr panel/ dogleg this whole time. (highlighted)
Now that structural integrity is back I will move to the wheelhouse. Another piece that will require fitting. It is easier to go back to something that was partially completed then going backwards and doing something over if it doesn't come out right. Take your time and be patient.
Couple of things. Most of the prior welding on the longs was done at about 70-80 degree's. The rail was done at 48 degree's. Metal cools much faster and draws together quicker. This is noticable and it will affect gaps. That single weld will save me hours of future fitting and headaches.
The other one is the mid long and rail joint is butt welded. This will get a double wall sleeve just like the factory design. Do not butt weld a rocker without a sleeve. This is for any car with a structural roof or not. It is one of those things you do not ask why, just do it.
Twystd1
post Dec 3 2007, 12:20 AM
Post #135
You don't want to know... really.....
Jeff, explain that further. As I think I know what you mean. But I want to be exactly clear on what you are saying.. (pics would be good for this nut head)
Ohh.. I found a Cellete bench with both the 911 and the 914 jigs in Buena Park.. In a Porsche mechanics garage.... No shit....
Now how do I tell the guy I need it for my bros...????
And where the hell do I put it on the assumption he will sell it to me...?????
Ya got any ideas...?????
Oh... Before I forget... I LOVE THIS SHIT.......!!!!!!!!!!!!!!!
Carry on sir.
Clayton
Jeff Hail
post Dec 3 2007, 01:37 AM
Post #136
QUOTE(Twystd1 @ Dec 2 2007, 10:20 PM) *
Carry on sir.
Clayton
It's pretty much a re-hash of Page 4 on this thread.
Mid long =longitudinal under the door.
Rear long =rear frame rail
This is nuts.
They should call the bolt on rocker the rocker molding.
Then the outer rocker would be the piece the sills and triangles weld to.
The inner long should really be called the inner rocker panel.
Every other manufacturer uses this terminolgy.
Why can't we? Organized chaos theory interpretation by Porsche?
In the collision repair industry if you refer to an inner rocker as a longitudinal
you are going to get that "what the f up" look.
Celette? How much? 20K minimum for a 20 year old bench with full set of obsolete fixtures is my guess and that is low if the guy is not using it. Maybe he moved in and the old tenant left it there (ha, ha). Even used they are spendy.
The cheapest bench they sell are like the one below that the 356 is on. The other one that the 911 sits on is quite a few duckets more. A bare Celette bench with nothing, no fixtures, no rocker clamps/ perch's- nothing is about 16k today for a new roller. For restoration work you do not need towers (for pulling). A good Port-A Power set is cheap for jacking stuff around.
Then if you do buy a dedicated bench how are you going to get home? Your red toy isnt going to do it.
Jeff Hail
post Dec 3 2007, 02:20 AM
Post #137
[quote name='Jeff Hail' date='Dec 2 2007, 11:37 PM' post='973233']
[quote name='Twystd1' post='973215' date='Dec 2 2007, 10:20 PM']
[quote]The other one is the mid long and rail joint is butt welded. This will get a double wall sleeve just like the factory design. Do not butt weld a rocker without a sleeve. This is for any car with a structural roof or not. It is one of those things you do not ask why, just do it.[/quote]
Clayton,
Did I loose you along the way?
The rear long will be butt welded and sleeved just like the inner long section that is already done. Same procedure except about 16 inches farther back.
I included a photo of the old piece to show the double wall. Only difference is instead of a single wall I will double the layer at the butt weld on 3 sides of the box.
Clayton? Clayton?
Sarastro
post Dec 3 2007, 12:59 PM
Post #138
I don't know why I find your work so fascinating. Maybe I'm someone who likes to see things done the way they should be (and not so often are). As a long time 914 owner (since 1973) I really appreciate what you are able to do to conserve these cars.
I am not a mechanic and I haven't done any welding since High School autoshop in the 60's but after watching you work, I feel like buying a Miller and joining metal.
Jeff Hail
post Dec 8 2007, 04:50 PM
Post #139
Sheet happens!
Ever wonder how much force is on a door bar when welding? Ever wonder how much energy is moving when metal draws together? Ever wonder how much a 914 shrinks when welding in the long area?
My passenger side door opening brace snapped. I am underneath and hear this BANG! Scared the crap of me and hit my head. The turnbuckle gave way. It was only 3/8 but it was forged. I have used them on another 914 and also a 911. They lived a good life.
Jeff Hail
post Dec 8 2007, 04:52 PM
Post #140
Built another set of door braces. This time I used 5/8 inch cold rolled solid rod and 1/2 inch rod ends. Of course they have to look good too (waiting on paint to dry).
Twystd1
post Dec 9 2007, 12:59 AM
Post #141
Hi Jeff,
Kinda been 2 busy to respond lately.
The follow up pics and explanation was PURRRFECT.
That exactly what I needed to show someone. I am most grateful for the answers you provided.
Now where the hell are we gunna put the Cellete bench??????
I came up with a number he liked. (Stupid Cheap)
Now I just need a Christmas ferry to show up and make it real.
Jeff... The bench is in this guys HOME Garage.
WITH all the 914 and 911 jigs. It isn't the small bench. It's the medium size one for 9elebens on down. He wants it gone by February...
HHHmmmm... Can we put a room addition on your house by then...????
Cheers and maximum thanks bro.
Clayton
Jeff Hail
post Dec 9 2007, 05:54 PM
Post #142
Clayton,
I will pass on the Celette. No room! My avatar signature says it all.
Thanks buddy.
Jeff Hail
post Dec 9 2007, 06:28 PM
Post #143
HOW TO BUILD A CLUTCH TUBE
Choose your steel wisely. Once it's in the last thing you need is a problem.
The original OEM tube is metric and some weird stuff. I thought at first it may be stainless. Stainless does rust by the way. Nope not stainless. Then maybe something else. Finally ended up taking a sample to friend who is a machinist. Pretty sure it's chromemoly. Who knows what alloy though?
Have you ever priced SAE tube versus Metric? Same alloy's although Metric is about 3-5 times more. Organized crime!
The OEM clutch tube is:
.470 OD
.040 Wall
McMaster-Carr
4130 Chromemoly Aircraft Grade Structural tubing. Inside has to be seamless DOM or honed. You do not want a weld burr fraying your cable. Even with the a cable liner a burr will chew it up.
.438 OD
.065 Wall
Thicker wall and a hair smaller OD diameter (0.032). I will be using a heavy duty clutch cable and fit is loose inside the tube. Good to go.
First to make the flare. It's really not a flare. It's more of a fishmouth- flare.
Chromemoly is fairly tough. I do not have a flaring tool this large. I also do not want to flare it cold because I think it will split the opening. 0.065 wall tube is thick.
Crank up the fire stick and get the end cherry red all the way around........
In the background you will see a blue punch laying on the bench. It has a perfect taper mid way up the shank that match's the original tube's contour. After heating the tube until it glows I slide the punch into the tube and let the taper do the work with the assistance of a 5lb hammer. I did not have to beat it to death. Just work the punch in gently. Keep it under heat (not enough to melt) and drive the punch in little deeper. Took about 5 minutes.
Jeff Hail
post Dec 9 2007, 06:35 PM
Post #144
HOW TO BUILD A CLUTCH TUBE -Cont'd
Once I was happy with the contour I smoothed the entrance of the flare to remove any burrs. I first used a small round stone (for porting) on a shank to round the mouth beyond what the punch would do. Then I took a smaller stone and rounded the opening a little more. A dab of valve grinding compound provides a final finish.
The old tube (right) and the new one (left)
Jeff Hail
post Dec 9 2007, 07:01 PM
Post #145
Too cold to do any welding outside today (yes this is SoCal) It's 40 degrees.
Inside a garage with torch's is a great idea!
I have to bend the tube. It also needs to match the original arc so I have correct cable length on both ends.
I little trick I learned in the aircraft industry (cheating). If you put a tube in a vise you don't want to crush the tube use a collar or sleeve around the tube. The tube you are working with can remain free or if you tighten it up enough it can secure the tube without crushing it. It also will not leave tool marks or sharp edges.
With the new tube in the collar I heated the tube again until it has a soft red glow. (not cherry) I keep the heat moving in the span of the arc I want to create. Once the tube is warmed up I apply presure as I walk the tube thru the collar at about 3/4 inch intervals to create the arc. With each step thru the collar a light tug makes a nice round bend. The actual radius of the bend is large so a tubing bender didnt make sense.
This has to be done slowly and gently otherwise the tube will kink or collapse and end up oval shape pinching the cable.
- Lo-Fi Version Time is now: 20th January 2025 - 02:55 PM
