36 Pages V « < 8 9 10 11 > »
> Bringing out the dead
Jeff Hail
post Feb 10 2008, 09:54 PM
Post #166
No rust left here. All new steel.
Made another fixture to keep the longs in check. Threaded rod with plates on each end. Tack welded to the inner longs. Keeps the dimensions in check and the longs won't splay in process.
Remember to take measurements before you begin cutting off stuff. Especially the suspension consoles
Jeff Hail
post Feb 10 2008, 10:00 PM
Post #167
More on measuring.
Do not proceed without measuring before you cut. This is vital to returning a chassis to dimensional tolerance. You do not have to high tech equipment. A tape measure will get by if on a budget. Pre- measure both sides before you cut any suspension consoles off.
Jeff Hail
post Feb 10 2008, 10:05 PM
Post #168
Finished the long connection at the rear rail. Added a sleeve at the joint. This will strengthen the connection and eliminate the flex at this area that 914's at notorious for.
Notice I punched holes in the sleeve. Since this is a area known for corrosion I did the work from inside the long. No leaks from pin holes in any welds will happen here. Also less finish work required since it is all inside once the long is closed up.
Work smart -not hard!
Jeff Hail
post Feb 10 2008, 10:15 PM
Post #169
Twice as strong as the factory design in this area. No welds from the outside except the outside butt joint equals no water leaks in this area.
I rough fit the new outer wheelhouse ( oops didn't take a pic)
I little more trimming needed but should be installed next weekend.
I am actually considering modifying a shelf where the rear diagonal long meets
the inner long at the firewall. An angled addition of sheetmetal to make water run off and down away from the long. Easy to do and hardly noticeable. More on that later.
Jeff Hail
post Feb 10 2008, 10:31 PM
Post #170
Value in scribbled notes:
I am sure this will help someone one day!
Measurements...........
Seat hinge mounting
Jeff Hail
post Feb 10 2008, 10:33 PM
Post #171
More value in scribbled notes:
Outer suspension console specs...............
Jeff Hail
post Feb 10 2008, 10:35 PM
Post #172
Inner suspension console specs...............
Jeff Hail
post Feb 10 2008, 10:39 PM
Post #173
More scribbled notes:
Jack post tube............... if you want your rocker moldings to fit correctly (tube centered in the rocker molding cutout hole)
type11969
post Feb 11 2008, 06:41 AM
Post #174
Looks familiar . . . just much nicer!
-Chris
Eric_Shea
post Feb 11 2008, 04:45 PM
Post #175
PMB Performance
How long before my "Rock Crusher" is done... (IMG:style_emoticons/default/confused24.gif)
http://www.914world.com/bbs2/index.php?showtopic=80797
Jeff Hail
post Feb 11 2008, 08:44 PM
Post #176
Two weeks! Isn't that what all shops say?
Twystd1
post Feb 12 2008, 12:08 AM
Post #177
You don't want to know... really.....
Eric, I have seen Jeff's work first hand.
Your rock crusher should be done in 9 days if I read it right.
C
Jeff Hail
post Feb 13 2008, 12:26 AM
Post #178
Might as well add this to the thread (IMG:style_emoticons/default/welder.gif) too:
The design make's everything a one man operation. The width of the upper bed is 32 inches wide which fits between the rear inner console ears that are the lowest part of the car. The height from the ground up was based on the maximum height of the common floor jack +2 inches (adding 2x2x 6 foot) cross bars that sat on jackstands and the bench rolled right underneath with a hair to spare? Of course easy access to gain access and roll around underneath on a creeper was taken into account.
Twystd1
post Feb 13 2008, 02:52 AM
Post #179
This is my favorite thread on this site so far. I LOVE THIS STUFF.
Clayton
Zimms
post Feb 14 2008, 04:57 AM
Post #180
(IMG:style_emoticons/default/agree.gif) Thanks for posting all of the sketches. I am going to be starting something similar this summer.
Jeff Hail
post Feb 17 2008, 06:44 PM
Post #181
Lets make some Sill Triangles
Made 2 templates. The first one is actual size after the bends (silhouette) of the mounted original. The second is 3/8 larger all the way around.
Cut out the sheetmetal using the larger template and then trace the smaller (silhouette) template onto the cutouts. Then drill the holes. I am making right and left sides.
Make some relief cuts so the bends don't buckle the flat area's. I tacked some really small welds where the sill plate doglegs over the bracket for strength.
These were the tools used in the process and a metal scroll saw to make the cutouts .
Finished triangle next to the original.
Jeff Hail
post Feb 17 2008, 06:46 PM
Post #182
Primed set of 4 right and left side triangles.......
watsonrx13
post Feb 18 2008, 05:58 AM
Post #183
Jeff, very nice job on the triangles. BTW, what gauge metal did you use?
-- Rob
Jeff Hail
post Feb 18 2008, 09:55 AM
Post #184
QUOTE(watsonrx13 @ Feb 18 2008, 03:58 AM) *
-- Rob
18 gauge - Factory used a metric equivalent of 17.
Wes V
post Feb 18 2008, 07:35 PM
Post #185
Jeff;
I just wanted to say thanks again for the sketch of your working platform.
I just had 60 feet of steel delivered so I can build my own.
Wes
- Lo-Fi Version Time is now: 20th January 2025 - 08:03 AM
