Bringing out the dead |
Jeff Hail |
May 16 2008, 12:12 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
I was prepping a post and the lights went out! The site went down. It's like running out of MIG gas!
(Preview of next weeks board meeting:o) Rt fender off. I new I had some rust at the top by the cowl. Not as bad as I expected. Fender was removed as a skin leaving the cowl extension intact. The upper cowl extension will get cut out and replaced. Easy piece to fabricate. I swear that piece was designed for Dzus fasteners! The cowl itself is ok at the horizontal area but the side will need some new metal. I used the Wurth "flail" to remove the sealer and take it down to bare iron. The rear of the wheelhouse is fine no rust. The front of the rocker/ hinge pillar will need a closing plate fabricated. All in a days work. Attached image(s) |
Jeff Hail |
May 16 2008, 12:35 AM
A really good product I have used for years is Jasco metal etch. It's a little different than metal ready. 1st its more agressive and only has to sit about 10 minutes (the instructions says 1 minute and rinse) versus some other products out there. It is very cheap in comparison to others and I think does a better job overall because it is full strength. (3/1, 2/1 with H20 or full strength as I use it right out of the bottle)
This is an excellent etching product. What it does not do ......It is not a conversion coating as it has no zinc or phosphate. If you are repairing and going directly to epoxy primer Jasco is a great product. If you are leaving metal exposed for a period you may get some flash and probably should use a zinc conversion coating even on good clean steel. I am not fond of conversion coatings because rust is rust no matter what color it turns. Attached image(s) |
craig downs |
May 16 2008, 12:37 AM
Senior Member Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Where can you get it
Jeff Hail |
May 16 2008, 12:40 AM
craig downs |
May 16 2008, 12:54 AM
Thanks
I've never seen it before but I'll go get some and try it. |
sean_v8_914 |
May 16 2008, 10:19 AM
Frazee paint store has it too
Jeff Hail |
May 17 2008, 09:13 PM
Cut the dead wood out of the cowl and cowl side extension.
Metal added was done in two pieces as the cowl has a step in it below the fender line. First piece in and then second piece on top just below. The weld becomes the step (really doesnt do anything) Attached image(s) |
Jeff Hail |
May 17 2008, 09:20 PM
Shaping this area is a tight squeeze in the bends. The front corner of the cowl has a little rust and I will do that separately with the hood off.
Jeff Hail |
May 17 2008, 09:24 PM
Make a template for the old rusty cowl extension. This is the top curved piece. The closing plate will be made last once everything is fitted.
Jeff Hail |
May 17 2008, 09:26 PM
Rough fitting the upper curved extension. Needs a little tweaking at the rear and a flange added.
Until Next time! Attached image(s) |
Jeff Hail |
May 26 2008, 01:42 AM
Where was I Eric?
Oh yes. Finished the passenger side cowl repairs. Also repaired the drain trough and hood seal fence. Attached image(s) |
Jeff Hail |
May 26 2008, 01:45 AM
It started raining while I was shooting primer. Not good! Had to sit there with a heat gun to force dry the epoxy primer. Car is covered just do not like to introduce moisture to the equation.
Jeff Hail |
May 31 2008, 10:37 PM
Few things done during the week.
Right front wheelhouse Attached image(s) |
Jeff Hail |
May 31 2008, 10:39 PM
Nothing interesting here. No rust........Primer time.
Jeff Hail |
May 31 2008, 10:41 PM
Saturdays business
Front of the right rocker. I actually thought I would find more rust here than thought. Cut out the old metal and put in some new... Attached image(s) |
Jeff Hail |
May 31 2008, 10:42 PM
More primer.....
Jeff Hail |
May 31 2008, 10:43 PM
Some porn for Shea!
Eric_Shea |
Jun 1 2008, 12:34 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Nice... (IMG:style_emoticons/default/wink.gif)
brer |
Jun 1 2008, 01:00 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
So, does water drain from the front hood seal trough out through the cowl/fender gap? While looking at mine I wondered if that cowl/fender gap was for water to escape when driving full speed.
Jeff Hail |
Jun 2 2008, 12:32 AM
So, does water drain from the front hood seal trough out through the cowl/fender gap? While looking at mine I wondered if that cowl/fender gap was for water to escape when driving full speed. Funny you say that. My left side has the outer fench that makes up the trough all the way back to the cowl. Right side had a gap of about 1-1/2 inches. The outer fence is actually part of the fender, the inner fence is made up with the apron. My first thought is the right fender may have been replaced at one time. After removing all the coatings it was the original fender although a minor repair was done where it meets the door. I think this is where the rust came from. Personally allowing drainage off the side into the fender well is a good idea. Anyhow I cut the fender off at the fence to repair this area and left the outer fence intact. Wasnt sure where to cut until the next step in body panels is completed. Which leads to why I cut the fender in the first place.... The next saga in my build is holding to the weight plan. This is one thing I am really trying to not deviate from: A friend who is the prop industry is letting me use his shop. I obtained the plugs which are an original set of full steel GT fenders that are on loan. You have no idea how hard it was to convince the owner to borrow these in the middle of a high dollar restoration his car is going thru now. The molds we made are done and will lay up the fenders in Kevlar reinforced Carbon fiber using epoxy resin. The Carbon fiber weave is 7 oz which is pretty thick so they will blow away any current fiberlgass part supplier out of the water and also be streetable. People have asked why I am going this route? First is weight. Second is my cost to make my own GT fenders out of Carbon fiber are about $200 a fender thanks to access to a professional mold making shop. The last reason is all the glass fenders I have seen except for Sheridan are pretty poor quality. This is a bold statement to make but most of the glass part suppliers are getting top dollar for junk that requires so much re-working that I feel is just unacceptable. They are officially on notice now. I can do better for less. |
Lo-Fi Version | Time is now: 7th October 2024 - 01:16 AM |
