Bringing out the dead |
craig downs |
May 16 2008, 12:54 AM
Senior Member Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Thanks
I've never seen it before but I'll go get some and try it. |
sean_v8_914 |
May 16 2008, 10:19 AM
Frazee paint store has it too
Jeff Hail |
May 17 2008, 09:13 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Cut the dead wood out of the cowl and cowl side extension.
Metal added was done in two pieces as the cowl has a step in it below the fender line. First piece in and then second piece on top just below. The weld becomes the step (really doesnt do anything) Attached image(s) |
Jeff Hail |
May 17 2008, 09:20 PM
Shaping this area is a tight squeeze in the bends. The front corner of the cowl has a little rust and I will do that separately with the hood off.
Jeff Hail |
May 17 2008, 09:24 PM
Make a template for the old rusty cowl extension. This is the top curved piece. The closing plate will be made last once everything is fitted.
Jeff Hail |
May 17 2008, 09:26 PM
Rough fitting the upper curved extension. Needs a little tweaking at the rear and a flange added.
Until Next time! Attached image(s) |
Jeff Hail |
May 26 2008, 01:42 AM
Where was I Eric?
Oh yes. Finished the passenger side cowl repairs. Also repaired the drain trough and hood seal fence. Attached image(s) |
Jeff Hail |
May 26 2008, 01:45 AM
It started raining while I was shooting primer. Not good! Had to sit there with a heat gun to force dry the epoxy primer. Car is covered just do not like to introduce moisture to the equation.
Jeff Hail |
May 31 2008, 10:37 PM
Few things done during the week.
Right front wheelhouse Attached image(s) |
Jeff Hail |
May 31 2008, 10:39 PM
Nothing interesting here. No rust........Primer time.
Jeff Hail |
May 31 2008, 10:41 PM
Saturdays business
Front of the right rocker. I actually thought I would find more rust here than thought. Cut out the old metal and put in some new... Attached image(s) |
Jeff Hail |
May 31 2008, 10:42 PM
More primer.....
Jeff Hail |
May 31 2008, 10:43 PM
Some porn for Shea!
Eric_Shea |
Jun 1 2008, 12:34 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Nice... (IMG:style_emoticons/default/wink.gif)
brer |
Jun 1 2008, 01:00 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
So, does water drain from the front hood seal trough out through the cowl/fender gap? While looking at mine I wondered if that cowl/fender gap was for water to escape when driving full speed.
Jeff Hail |
Jun 2 2008, 12:32 AM
So, does water drain from the front hood seal trough out through the cowl/fender gap? While looking at mine I wondered if that cowl/fender gap was for water to escape when driving full speed. Funny you say that. My left side has the outer fench that makes up the trough all the way back to the cowl. Right side had a gap of about 1-1/2 inches. The outer fence is actually part of the fender, the inner fence is made up with the apron. My first thought is the right fender may have been replaced at one time. After removing all the coatings it was the original fender although a minor repair was done where it meets the door. I think this is where the rust came from. Personally allowing drainage off the side into the fender well is a good idea. Anyhow I cut the fender off at the fence to repair this area and left the outer fence intact. Wasnt sure where to cut until the next step in body panels is completed. Which leads to why I cut the fender in the first place.... The next saga in my build is holding to the weight plan. This is one thing I am really trying to not deviate from: A friend who is the prop industry is letting me use his shop. I obtained the plugs which are an original set of full steel GT fenders that are on loan. You have no idea how hard it was to convince the owner to borrow these in the middle of a high dollar restoration his car is going thru now. The molds we made are done and will lay up the fenders in Kevlar reinforced Carbon fiber using epoxy resin. The Carbon fiber weave is 7 oz which is pretty thick so they will blow away any current fiberlgass part supplier out of the water and also be streetable. People have asked why I am going this route? First is weight. Second is my cost to make my own GT fenders out of Carbon fiber are about $200 a fender thanks to access to a professional mold making shop. The last reason is all the glass fenders I have seen except for Sheridan are pretty poor quality. This is a bold statement to make but most of the glass part suppliers are getting top dollar for junk that requires so much re-working that I feel is just unacceptable. They are officially on notice now. I can do better for less. |
Loser_Cruiser |
Jun 2 2008, 12:40 AM
Member Group: Members Posts: 407 Joined: 4-April 05 From: Bellingham, WA Member No.: 3,873 Region Association: Pacific Northwest |
so are these a one time deal or are you gonna be taking orders in the future? (IMG:style_emoticons/default/biggrin.gif)
Jeff Hail |
Jun 2 2008, 12:43 AM
so are these a one time deal or are you gonna be taking orders in the future? (IMG:style_emoticons/default/biggrin.gif) These are one off's. Sorry! |
Eric_Shea |
Jun 2 2008, 08:41 AM
QUOTE They are officially on notice now. QUOTE These are one off's. Sorry! Ohhhhh... you've got them shaking and quaking in their boots now! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/tongue.gif) |
Jeff Hail |
Jun 2 2008, 07:50 PM
QUOTE They are officially on notice now. QUOTE These are one off's. Sorry! Ohhhhh... you've got them shaking and quaking in their boots now! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/tongue.gif) You make me laugh Eric (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 19th January 2025 - 01:33 PM |
