36 Pages V « < 17 18 19 20 > »
> Bringing out the dead
Rocket Man
post Sep 5 2008, 08:20 PM
Post #346
Jeff,
Awesome work and great thread… (IMG:style_emoticons/default/smilie_pokal.gif) you have inspired me.
I have a couple of questions to help me determine where to re-start on my garage queen teener.
1. Where did you find the factory tolerance info on the starting page of your thread, quoted below?
“Keep in mind that tolerances for the 914 were 7-9mm from the factory so anything you can do to make it better is worth it.”
Is this info documented anywhere, and do the tolerances include door gaps and hood-fender gaps?
My rear trunk lid to fender gap gets wider on both sides going from the back to the front…I suspect it could be from a questionable fender flaring process from the PO.
2. Is there a preferred way to remove/separate parts that have previously been seam welded rather than spot welded together, such as a previously replaced battery box or front fender, without damaging either the part being removed, or the part it is removed from? A battery box is not so valuable, but a front fender is. I want to remove and re-use the fender, and do it right, unlike the PO.
Thanks, and keep your progress updates coming.
Eric_Shea
post Sep 5 2008, 08:58 PM
Post #347
PMB Performance
Eric, a gt cooler shroud would fit fine. The tubular structure is wider and higher than the f/g piece.
That's what I was thinking. There might be hope for a suspension tie-in for me yet.
Jeff Hail
post Sep 12 2008, 02:44 PM
Post #348
(IMG:style_emoticons/default/WTF.gif)
r_towle
post Sep 12 2008, 02:49 PM
Post #349
Custom Member
What did Jeff do this week???
Inquiring minds want to SEE
Rich
Jeff Hail
post Sep 13 2008, 09:00 PM
Post #350
QUOTE(r_towle @ Sep 12 2008, 01:49 PM) *
Rich
CF+EPR= REAR FLARES DONE
No showy yet. Just pulled from the molds.
Jeff Hail
post Sep 13 2008, 09:03 PM
Post #351
Bits and pieces done today.
Repaired and sectioned a piece at bottom of the front wheelhouse.
Crap I couldnt even find the seam when I was done.
Closed the antenna wire hole. I swear that had one purpose! To leak!
Just had to stick my finger in the wet primer. Nope not dry yet!
Jeff Hail
post Sep 13 2008, 09:05 PM
Post #352
Lower left front wheelhouse. Not bad. Little piece to replace.
Jeff Hail
post Sep 13 2008, 09:17 PM
Post #353
Front left floor is not as bad as I first thought. The pedal base is all good steel.
Just to the left where I cut the dead foot out is easily repaired.
Jeff Hail
post Sep 13 2008, 09:38 PM
Post #354
One thing I did notice is two cracks in the sheetmetal where the suspension crossmember hump is. I saw these from underneath the body. This required removal of the dead foot to access the area. The cracks are clean and appear to be from the forming process not stress.
When sheetmetal is formed in a die the edges/bends need to be smooth or polished otherwise the metal will not draw smoothly and thin out at the bend. Wax or lube used during the forming process also helps a lot. This will eventually split open.
Any of you guys who reload will understand. Try sizing a case without lube.
I will need to media blast this area clean. Fab the pieces and as Shea would say "do that welding thing I do".
Water entry did not help this area. Although that came from the cowl above.
Surprisingly the steel is in good condition with the exception of what I cut out.
Jeff Hail
post Sep 18 2008, 12:57 AM
Post #355
Cut and trimmed the front floor footwell. Media blasted the surface flash.
Easier to do the repair in two pieces (actually 3)
The piece just to the left of the pedal box is an easy part to make. Just a rectangle cut to size and burn it in.
Jeff Hail
post Sep 18 2008, 12:59 AM
Post #356
The second piece to the left of that took some "beating". My beating bag of choice.
Jeff Hail
post Sep 18 2008, 01:01 AM
Post #357
Cut the template
Jeff Hail
post Sep 18 2008, 01:02 AM
Post #358
Piece #1 clamped and ready for fire.
Jeff Hail
post Sep 18 2008, 01:04 AM
Post #359
Piece #2
Jeff Hail
post Sep 18 2008, 01:07 AM
Post #360
Ran out of daylite. Piece #2 will be burned on Thursday.
Jeff Hail
post Sep 19 2008, 06:02 PM
Post #361
OBJECTS MAY APPEAR CLOSER THAN THEY APPEAR
Nice 914 on the 5 Fwy at Valencia Blvd today
Jeff Hail
post Sep 23 2008, 09:26 PM
Post #362
Not bad...
Twystd1
post Sep 23 2008, 10:35 PM
Post #363
You don't want to know... really.....
Jeff.
You gunna be at your house next weekend?
And do you need any help for a few hours?
Clayton
Jeff Hail
post Sep 24 2008, 12:59 AM
Post #364
QUOTE(Twystd1 @ Sep 23 2008, 09:35 PM) *
Jeff.
Clayton
Long time no hear Clayton! Glad to know you are still lurking in the shadows. I hope all is well my friend. How is the beach life these days? I'm in cruise mode right now. Can't say I will be home or not. You never know?
(Post edited due to foresight)
Jeff Hail
post Sep 30 2008, 09:55 PM
Post #365
This evenings fabrication.
pedal board support to replace the old rusted one I cut out.
- Lo-Fi Version Time is now: 19th January 2025 - 03:06 AM
