36 Pages V « < 18 19 20 21 > »
> Bringing out the dead
Twystd1
post Sep 30 2008, 10:39 PM
Post #366
You don't want to know... really.....
Hi Jeff.
I was just looking at the ground control shocks setup that BradHolio said he could hook me up with.
It cost about 2K for that particular setup for all four corners..
Do you have a sense of waht are you going to run for bars, springs and shocks? (Brands, etc)
AND... Since I'm tearing into the body work and minor suspension mods. What would you do if you were going to throw some bucks at the chassis?
The Engman long kit is a must as well as the sway bar braces. What else would suggest for a flared car with 7s and 8s stickys for the street and occasional A/X?
What bracing can I do while the car is apart that creates enough rigidity and still be streetable and affordable? I am thinking a 4 point cage with a down bar that attatches right below the door hinges and goes back to the sill/long area next to the trunk release.
6 points actually.
My fear is transferring to much flex to the wheel house and front end. As they are basically stock.
I dunno... I just want to hear what you might do for a street and occasional AX car?
Note. At the proper time and the proper place........
I drive the streets like it's a track. I have all my life.
Thus it is necessary to make this car work without snapping suspension pieces because I am a middle aged nut case.
I believe I can build dam near anything given the time and money..
It just doesn't look ANYTHING like your work. I wish I had your mad skilzzzz.
By the way. I have 3 new in box intercoolers. Ya know anyone that need any ICs?
Cheers,
Clayton
Jeff Hail
post Oct 1 2008, 12:34 AM
Post #367
QUOTE(Twystd1 @ Sep 30 2008, 09:39 PM) *
Hi Jeff.
6 points actually.
Cheers,
Clayton
I will be running Bil's front and rear. Sway Away 22mm torsion bars up front and Eibach 250's out back. Tarret bar up front.
I am not worried about the suspension pieces taking a beating. Its the chassis that needs help. Engman reinforcements a must. I am going to install reinforcements where the Engman kit stops and continue it all the way back to the rear strut towers as I am raising the suspension pickups. Weight is not that much. Plus the cage ties into the rear rails. Easy as I have not welded the lower firewall in yet.
The front is another issue. The cowl flex's considerably which with heavy t-bars may result in cowl shake. To me the best way even with an inexpensive cage would be to tie the cage into the hinge pillars (down low) and high through the bulkhead into the strut towers. If you are thinking 6 pts might as well just add two more tubes (cheap)
If you are going front coil overs the strut towers will need to be modified with camber box's or heavily reinforced.
tronporsche
post Oct 1 2008, 12:40 AM
Post #368
Jeff, what size Or weight springs are those please ? Do only that size or weight come in red like that ? What use is those size springs for (racing, daily driving , to be comfortable, etc,) The reason I ask is I have the same set and shocks on my car that came from another car. Thank you.
gs11x
post Oct 11 2008, 06:17 PM
Post #369
Hi Jeff,
Can you share how you are doing your media blasting in your rust repairs? I agree with you comment about trying to grind the rust out because it removes to much metal. I want to buy some media blast equipment but I am not sure what equipment to get. Thanks
Jeff Hail
post Oct 11 2008, 07:17 PM
Post #370
Edited. Non auto stuff removed.
Jeff Hail
post Oct 11 2008, 07:19 PM
Post #371
Jeff Hail
post Oct 11 2008, 07:20 PM
Post #372
Jeff Hail
post Oct 11 2008, 07:21 PM
Post #373
Jeff Hail
post Oct 11 2008, 07:25 PM
Post #374
edited. Non auto stuff removed.
Jeff Hail
post Oct 11 2008, 09:10 PM
Post #375
QUOTE(gs11x @ Oct 11 2008, 05:17 PM) *
Hi Jeff,
I use both a professional forced pressure gun (hopper type) and a cheap hand held suction gun with a huge nozzle (Home Depot bucket is the hopper). Forced for larger areas and the hand held for smaller spot areas. I do not use sand. I use Dupont Starblast ( I think I posted somewhere way back about the Starblast). Process is straight forward. Blast until the rust is gone. Wear gloves, a windowed hood and proper respirator. I lay out a big blue poly tarp under the work area to catch the spent media and then recycle it by sifting it thru a ultra fine strainer to remove the contaminants. (pain but it works)
Since I am doing this project in stages I try to work smaller areas that can be started and completed without leaving exposed metal for periods of time.
Wilhelm
post Oct 12 2008, 09:19 AM
Post #376
Hi Jeff,
Heres my sandblasting effort............
http://www.914world.com/bbs2/index.php?showtopic=87896
Jeff Hail
post Nov 30 2008, 07:10 PM
Post #377
We appologize for the interuption. We will return to our regular programming in a moment.
No time to work on the tub until now. I feel like the Duracell bunny sometimes. Go,go, go......
Finished the pedal box and pedal board support. A few modifications to the original design but I am happy with the result.
Primed, seam sealed and primed again - done
Anyone who has worked/ repaired this area knows its tight confines.
Jeff Hail
post Dec 20 2008, 01:51 AM
Post #378
Chris,
Really I have been working on the car. Ho Ho Ho
Jeff Hail
post Dec 20 2008, 02:06 AM
Post #379
Its been 28 degree's at night and raining/ snowing for a week. What is the best way to stay warm? Fire - of course.. Crazy thing is i'm in L.A County...snow? well a little mostly just frig'in cold.
Welded some backers/ reinforcing plates on the inside of the firewall. The thought of the PMS mount supporting a fat six with only 18 guage sheet made me think. While I'm in there add some metal. This is an area most cannot do while in there because its inaccessible. Do it once and never have to worry. No fatigue in the firewall sheet metal at a later date.
Two reasons..I can really turn up the heat when I weld the mount in and I can also tie the plates into the cage from inside the passenger compartment. Best thing is its all concealed by the inner firewall. Sano. You get the idea. Better overkill than not enough.
ChrisFoley
post Dec 20 2008, 06:22 PM
Post #380
I am Tangerine Racing
QUOTE(Jeff Hail @ Dec 20 2008, 02:51 AM) *
Chris,
lololol
Jeff Hail
post Jan 1 2009, 02:59 AM
Post #381
A few posts ago (many- somewhere on the site). I provided a glimpse on a center pull/ tunnel mounted E Brake using a 993 E brake assembly. A few reasons......get rid of the rinky dink left side E Brake and improve the system in the process. Using two right side 914 cables of equal length and relocating it to the tunnel. Full adjustment at the lever and cables from inside the car.
Here you go completed product. No modifications to the cables needed.
Yup Shea....freak of nature. Dr. FP would be proud!
Quote:Sarah Conner from the movie Terminator. "Men like you thought it up. You think you're so creative. You don't know what it's like to really create something".
Quote: Jeff Hail "Sarah be quiet- you are annoying me. Go to your room "
Happy freak'in New Year!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![size=3]
Jeff Hail
post Jan 2 2009, 12:36 PM
Post #382
Front floor officially done
Cut out the area that had some rust for the access cover and fabbed a square piece to insert.
Eric_Shea
post Jan 2 2009, 02:47 PM
Post #383
PMB Performance
(IMG:style_emoticons/default/beer.gif)
Jeff Hail
post Jan 11 2009, 07:21 PM
Post #384
Final coat of epoxy primer on the front floor/ pedal box. Nice and pretty.
........and yes that is a dent in the floor just to the left of the cut in the trans tunnel.
Didnt notice it until after I primed it. It will easily be corrected with a piece of 4x4 and a floor jack. Few hits with a rubber mallet to raise the low area.
Jeff Hail
post Jan 11 2009, 07:24 PM
Post #385
The left side cowl is as expected. Evaluate and start cutting out the bad metal.
- Lo-Fi Version Time is now: 19th January 2025 - 12:19 AM
