Bringing out the dead |
Jeff Hail |
Feb 3 2010, 12:26 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
mis·cel·la·neous rambings
I'm back. Interesting leave of absence. Women can be strange at times. Never can understand them can we? Back to work. Anyone ever notice my photos are semi myopic? Cant ever show too much can you? Here is where I am at: Front body is 98% done. Front bumper and fenders just need to be hung. Dzus fastener mounts are all located. Just need to complete the finish work on the left fender and basicly done. I havent come to a conclusion on headlamps yet but I hate the pop up lids - so they must go. Considering the CA laws on lamps some ideas have come to mind. Just like a formula in racing its all really open to interpretation and the risk. Attached thumbnail(s) |
Jeff Hail |
Feb 3 2010, 12:30 AM
Working on the left inner long. Its done. Just need to replace the outer long and good to go. Threw the Engman stiffener on there for looks.
I am getting ready for the rear floor section and lower firewall installation. I'm excited. Attached thumbnail(s) |
Jeff Hail |
Feb 3 2010, 12:34 AM
Completed the tunnel repair patch for both sides. This will be plug welded once I install the floor. Fitment prior to floor cut and trim.
An afterthought! Porsche/VW should have made the tunnel the same height as the longs. Would have made a much stiffer platform. Shorten the shifter a bit and well.. it didnt happen. Attached thumbnail(s) |
strawman |
Feb 3 2010, 01:29 PM
Senior Member Group: Members Posts: 883 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Hi Jeff,
Lookin' great! I can't wait to see what you come up with for the headlights. I have mocked up my radiator mounting for my Suby swap, and the upper mount bar and airflow would be much better IMHO without the headlight boxes to deal with. I've got a front fender cut that I hope to use to mock up HID bulbs inside the factory turn signal pods... much easier on the workbench than on the car. Geoff |
bcaschera |
Feb 3 2010, 05:38 PM
Member Group: Members Posts: 73 Joined: 1-October 09 From: san jose Member No.: 10,873 Region Association: None |
The turn signal pods are just begging to be stuffed with some nice HID lamps. I found some high/low HID's from PIAA and i believe they would fit nicely. The only problem being the cover and the price (IMG:style_emoticons/default/icon8.gif) . This project looks great by the way... I wish i had half the tools and 1/8 the skills you have. Keep it up (IMG:style_emoticons/default/chowtime.gif) |
Jeff Hail |
Feb 3 2010, 06:24 PM
The recent copy of Exellence provided a few extreme ideas.
Jeff Hail |
Feb 15 2010, 10:46 PM
The Redhead has me stirred up!!!
Need to take it out on some 16 gauge steel. Ok, Fabricate the closing plate at the rear of the left outer long (rocker to us body guys) Start with a big flat piece of 16 gauge steel. A little bending in the brake. Some trimming and there you go. Attached image(s) |
Jeff Hail |
Feb 21 2010, 10:45 PM
The Red Head has me really stirred up! And she probably still has the link I sent her 8 months ago. I do care about her.
Left inner long has been repaired. Last will see of it. Should have signed my initials on the inside before I closed it up. Next: Prepare the new outer long. Fit and add a sleeve for the infamous Hail butt weld. Sleeves make the joint twice as strong and provide a solid joint to burn in without blowing holes. A tight fitting backer is the key to a good structural joint. Really not a butt weld but a modified butt/ lap... kind of. Attached thumbnail(s) |
Jeff Hail |
Feb 21 2010, 10:48 PM
Test fit of the Left Outer Long. Check for level and top and bottom flanges.
Clamp in place. Punch the requisite holes and grind the flanges as appropriate. Attached thumbnail(s) |
Jeff Hail |
Feb 21 2010, 10:49 PM
Lets burn some metal. Alchemy!!
Grinding the plugs is next. BTW.. the upper flange was welded on the inside as I pre-drilled the holes on the inner long. Makes for a better cleaner finished product on the outside. Attached thumbnail(s) |
Jeff Hail |
Feb 21 2010, 11:09 PM
I removed the brace just above the inner long before I welded the outer together.
The door gap stayed perfect. Lot of talk lately on the site about twisted chassis when welding in roll cages and long reinforcements. The only conclusion is "Occums Razor".. aka welding to fast. I burned the outer long in about 45 minutes while piping in air flow with an air nozzle laying inside the long. Just a bleed of air flow to cool the metal as I plugged along. I would say I generated the same amount of heat welding the outer long as installing an Engman reinforcement. Weld slowly! Take your time. Attached thumbnail(s) |
Eric_Shea |
Feb 27 2010, 03:38 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Did ya notice the hinges? Weight Watchers for Fat Girls style. Jeff, What method did you use to get the support bar out of the hinge? (nevermind...upon further inspection, it looks to still be in place.) |
Jeff Hail |
Feb 28 2010, 02:56 AM
Hi Eric
Jeff Hail |
Feb 28 2010, 02:58 AM
A few mnutes to play...
Final fitting of the rear outer rocker closing plate. Burn it in! I will grind all the welds down tomorrow. Attached thumbnail(s) |
Jeff Hail |
Feb 28 2010, 03:06 AM
Ok shit that hurts. Anyone who works with sheetmetal is gonna get a "hurts donut" inevitably. Got this one when the vise grip slipped and banged my knuckle on the edge where the qtr panel is cut off for access. Yep it went to the bone and was a bleeder. Probably should have gotten 3-4 stitches. No time but cyanoacrylate closed it right up.
rick 918-S |
Feb 28 2010, 08:05 AM
Hey nice rack! -Celette Group: Members Posts: 20,689 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Nice work Jeff! (IMG:style_emoticons/default/thumb3d.gif) REAlly nice gash! (IMG:style_emoticons/default/chowtime.gif) (IMG:style_emoticons/default/biggrin.gif)
Krank |
Feb 28 2010, 09:07 AM
Member Group: Members Posts: 140 Joined: 11-October 09 From: Winnipeg, MB Member No.: 10,922 Region Association: Canada |
A little lemon and salt on there and I bet the vodka would go down really fast! Nice thread Jeff, lots of great info for peeps of all levels here. Thanks for all the extra time spent on pics and documentation. It takes enough time just getting the work done.
Cairo94507 |
Feb 28 2010, 09:25 AM
Michael Group: Members Posts: 10,035 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Wow; Jeff you are one talented man. Any chance you might move to Alamo California anytime soon? I would love to have your skill set.
d914 |
Feb 28 2010, 10:40 AM
Advanced Member Group: Members Posts: 2,333 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
I WAS married to a red head!! Say no more I fully understand!!!!! (IMG:style_emoticons/default/smile.gif)
Eric_Shea |
Feb 28 2010, 11:14 AM
One way to get some "gash" (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 7th October 2024 - 08:33 PM |
