36 Pages V « < 30 31 32 33 > »
> Bringing out the dead
Eric_Shea
post Mar 11 2014, 08:51 PM
Post #606
PMB Performance
What the hell did I miss here? Jeff turned a pressure cooker into an oil tank? (IMG:style_emoticons/default/ohmy.gif)
Jeff Hail
post Mar 16 2014, 08:56 PM
Post #607
43 Plymouth dash? Nope!
Jeff Hail
post Mar 16 2014, 08:58 PM
Post #608
Got to make some room.
Thought about putting a Carrera front spoiler oil cooler but those things are really long at 21+ inches. Would not follow the body contour and would interfere with the bumper fit.
Standard Carrera fender oil cooler tipped on its side. They flow that way anyways.
The core is 13 x 7 x 2.5 which provides a lot of heat throw.
I will shroud the bottom of the cooler and leave an exit behind and under it since it has plenty of room on the backside of the cooler. Its 2 inches above the bottom of the floor well so it wont bottom on anything.
More welding and grinding to finish it off but you get the idea.
Never liked the idea of weather or oil cooler exhaust air going into the trunk.
Jeff Hail
post Mar 16 2014, 09:43 PM
Post #609
The metal I used is 16 gauge. Would like to have a little bit of strength considering what was removed. Its tied into the floor where it rolls upward and across to each control arm reinforcement to just below the latch.
Funny I used to be able to grab the nose just above the hood latch and it would flex a little. Not anymore. That area is plenty stout now,
Jeff Hail
post Mar 20 2014, 11:29 PM
Post #610
Hey its got a front end again. A little "R" styling for the oil cooler inlets. Will need to modify the spoiler ends to fit the flairs better later.
Jeff Hail
post Mar 20 2014, 11:35 PM
Post #611
It has a rear end to ! Lots of work to do here.
Jeff Hail
post Mar 23 2014, 12:41 AM
Post #612
Rear lighting. Bases painted and assembled.
jaxdream
post Apr 3 2014, 05:45 PM
Post #613
QUOTE(Jeff Hail @ Jun 4 2008, 10:28 PM) *
QUOTE(Eric_Shea @ Jun 3 2008, 09:24 PM) *
Tip your bartenders and waitresses...
Word has it around here you are a class act (IMG:style_emoticons/default/piratenanner.gif) Are you tending bar tonight or the host?
To back up a bit to last weeks intimate conversation. Here are the spacers for using the late Carrera hubs (one inner, one outer on each side of the 914 wheel bearing). Easy enough? Rotors are also Carrera. Depending on going 20mm or 24 mm appropriate caliper half spacers required.
By the way you spelled Carrera incorrectly. Two "R's always come before the single "R". I just wanted to point that out you know. I am sure the bartender or host will volley back with a good jab just for fun. Thats getting back for the Kings Lad thing.
Jeff please explain the second spacer that appears to go on the backside of the bearing/ SC hub ?? I got and installed the 5mm spacer that goes on the front side / wheel side of the hub to use up against the bearing to use the wider bearing SC hub . Thanks for any info on this setup.
Jack
Jeff Hail
post Apr 3 2014, 10:12 PM
Post #614
QUOTE(jaxdream @ Apr 3 2014, 04:45 PM) *
Jack
Easiest way to explain: Using Carrera hubs and axels. The late 911 stuff uses a wider bearing. To use the 914 cartridge bearing the spacers simply make up the difference in width on each side to match the 911 bearing. The spacers are sized accordingly to properly space the hub in the trailing arm. Boils down to making the bearing cones wider while retaining the dimension of the 914 bearing at the race so as to not modify the 914 trailing arm at the bearing carrier. If you are going with Carrera axels you will need both spacers.
The rotors are a matter of choice and really depend on the calipers being used. I just swapped a buddy my Carrera rotors for SC rotors because Shea will bust my balls about the weight difference. Maybe he wont because he is so cool. When I decided to go with Boxster calipers can use either rotor.
I just went through some parts and have everything out. Let me see if I can take some photos to show the differences. Will add shortly.
Jeff Hail
post Apr 3 2014, 11:01 PM
Post #615
Carrera axel and lug centric hub on the left with spacers installed.
914 bearing
914 axel on the right.
As you can see the axel stub shank is the same length for both the 911 and the 914.
The shank is the same diameter on both. The splines are different (one course, one fine).
The Carrera axel stub has a more defined step on the shank where the bearing butts up against it. The spacers are chamfered to accommodate this.
With the bearing and hub installed the offset would be incorrect. The spacers correct that issue to center the hub face so the rotors center with the caliper mouth.
jaxdream
post Apr 4 2014, 07:49 AM
Post #616
Ok I gottcha , you are centering the Carrera hub in the bearing and using Carrera axles also. It seems a matter of getting the right parts with spacers to work around the 914 bearing size . Nice that these are available to source for differing setups. Thanks again for the info, somthing to ponder.
Jack
Jeff Hail
post Apr 13 2014, 02:21 PM
Post #617
Unhappy with factory lighting and unsatisfied with the bulb output of the Hella R tailites had to take this to another level.
Sourced some dual output (running, brake) LED clusters. They were the brightest I could locate using red LEDS. Red LEDS with red lenses were the obvious solution since white LED washes the color.
Jeff Hail
post Apr 13 2014, 02:25 PM
Post #618
Modified the Hella bulb housings and installed some standoffs to bring the cluster close to the lens. Because there is no side marker I needed the cluster to illuminate the lens from all angles.
The clusters are waterproof since they are dipped in epoxy. I let these run for 1 hour straight and they do not get hot at all. In fact they don't even get warm.
Jeff Hail
post Apr 13 2014, 02:30 PM
Post #619
With the lights in the garage out these are really bright on both the run and stop modes.
The last photo is of the ceiling to show how much output these give off. Lit up the whole garage. This was a test with a single lamp on.
Very bright and I am satisfied.
Eric_Shea
post Apr 13 2014, 06:14 PM
Post #620
PMB Performance
(IMG:style_emoticons/default/smilie_pokal.gif) Nice work Jeff. Nice to see some skin on it!
(you can install as many flywheels on your car as ye see fit. I'm just an innocent bystander) (IMG:style_emoticons/default/wink.gif)
Maltese Falcon
post Apr 13 2014, 06:18 PM
Post #621
Jeff, I'll need to source some of the hub-to-bearing spacers soon.
Are you still parking the chop top 911 in your front rec-room? (IMG:style_emoticons/default/biggrin.gif)
Marty
Maltese Falcon
post May 15 2014, 11:31 PM
Post #622
Jeff...any updates on your build ?
Hope your shoulder+ hand are doing better...I joined the sheet metal lacerated finger brigade as well (IMG:style_emoticons/default/blink.gif)
Marty
post May 16 2014, 09:02 AM
Post #623
QUOTE(Jeff Hail @ Mar 22 2014, 11:41 PM) *
Jeff, I've seen this style tail light assm in 2 other builds. Are they available aftermarket? Looks good!
Jeff Hail
post May 16 2014, 11:52 PM
Post #624
QUOTE(Maltese Falcon @ May 15 2014, 10:31 PM) *
Marty
Been working on the 14 just have not been taking photos.
Jeff Hail
post May 16 2014, 11:57 PM
Post #625
QUOTE(76-914 @ May 16 2014, 08:02 AM) *
Honestly they are a pain in the ass to make. No aftermarket because I own the molds and masters.
- Lo-Fi Version Time is now: 16th January 2025 - 11:54 PM
