FYI: Official Alien Build thread Started 2003, Alien Resurection is underway. Flywheel is finished - transaxle is bolted - Starter works |
TravisNeff |
May 5 2007, 02:42 AM
majkos |
May 5 2007, 07:42 AM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
aircooledboy |
May 5 2007, 12:54 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Nice Work Rick.
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/happy11.gif) |
rick 918-S |
May 5 2007, 08:03 PM
Hey nice rack! -Celette Group: Members Posts: 20,785 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Just dry fired it to make sure everything was connected correctly. It sounds awesome without exhaust! (IMG:style_emoticons/default/aktion035.gif) Pegged my 150 psi gauge. that's a good sign. I still have the Bar sender connected to a US spec VDO gauge. Still need to replace the sender but it is as it was with the old engine. All looks good. No leaks that I've seen yet. Now I can finish it up.
I still need to fix the exhaust, install the axles, and fill and bleed the cooling system. The test drive will be tomorrow. |
wbergtho |
May 5 2007, 09:12 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
Test drive tommorrow? Hey......you have patched the alien back together to invade far away places once again! AWESOME! Glad to hear it. I want a ride when I come up into your neighborhood in June for Grandmas marathon.
Bill |
rick 918-S |
May 5 2007, 09:14 PM
(IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/assimilate.gif)
Test drive tommorrow? Hey......you have patched the alien back together to invade far away places once again! AWESOME! Glad to hear it. I want a ride when I come up into your neighborhood in June for Grandmas marathon. Bill |
Gint |
May 5 2007, 09:15 PM
Mike Ginter Group: Admin Posts: 16,094 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Hiya Rick... (IMG:style_emoticons/default/wavey.gif)
rick 918-S |
May 6 2007, 12:03 AM
Hi Mike! How ya healing up? Sandy is purchasing her one way ticket to Denver to meet me for the caravan to the Atomic Ramble. I wanted her to wait until I knew the engine was going to run before she purchased her ticket. See ya in a couple or 3 weeks! |
Gint |
May 6 2007, 07:01 AM
spare time toys |
May 6 2007, 05:07 PM
Can we get a quick teaser photo of the engine in the car (IMG:style_emoticons/default/clap56.gif)
rick 918-S |
May 6 2007, 10:52 PM
My Camera grew legs and walked off. I just bought a new one so no pics yet. It looks the same only clean. I didn't use the red cam housings as the early motors had a removable lifter bore and they were stuck in my heads. The late heads allow the cams to slide out easily. On the early heads the lifter bores need to be removed to pull the cams. So, the euro cams with their original housing are back on the motor for now. I did build some trick throttle linkage though. Now I will be able to use full throttle! (IMG:style_emoticons/default/blink.gif) BTW: Special thanks goes out to chappy for the last minute parts stash! Thanks buddy! |
seanery |
May 6 2007, 11:20 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
SWEET!
I can't wait to see pics! Great job (again) Rick! |
rick 918-S |
May 7 2007, 10:01 PM
Throttle linkage pics. See the tube with bearings inside on the back of the engine.
The cable pulls a cam that pushes a linkage that pulls a cable. The linkage rod has sperical bearings. Attached image(s) |
rick 918-S |
May 12 2007, 10:50 PM
OK, It's running. I need to put the timing light on it. I drove it out of the garage onto the driveway. It's ready to run to the exhaust shop. I had to cut the lead pipes off the twin muffler setup because I changed to later style exhaust manifolds. They were a little different and the exhaust wouldn't bolt up anymore.
Here's what's left: Tune in the CIS Replace the cap Time it. Fix the exhaust Install the 180 lb rear springs. Finish and install my 1" 4130 sway bar project Repair some body damage and paint... Not sure I'll have time for the paint work before the Atomic Ramble. The painting is last. I may get to it, I may not.. Oh ya, I left chappy a rumbling voice mail when I lit it up! (IMG:style_emoticons/default/av-943.gif) |
McMark |
May 13 2007, 12:23 AM
Seeing the Alien again is one of the BIG reasons I'm considering making the drive to AR.
Gint |
May 13 2007, 02:48 AM
rick 918-S |
May 13 2007, 08:05 AM
[quote name='McMark' date='May 12 2007, 10:23 PM' post='899938']
(IMG:style_emoticons/default/biggrin.gif) You know if there were any way I could make both events I'd be there. (IMG:style_emoticons/default/sad.gif) I'm at least flying the WCR link in support. (IMG:style_emoticons/default/biggrin.gif) I really hope you can make the trip Mark. (IMG:style_emoticons/default/wavey.gif) BTW all, I wrecked my lower back bending over the flare working on the car. I can hardly walk today much less drive the car. just a short term thing. |
rick 918-S |
Jun 10 2007, 12:24 PM
Up date for anyone interested. I have a fried relay board that is keeping me from tuning the car. It failed at the fuel pump relay that also powers my AAV and WUR.
This was a contributing factor (not the whole reason) I missed the Atomic Ramble. I've had limited time to work on the car now. My work schedule and my electrical issues now caused me to miss the WCR. I figured I would do a wire around the relay board thing to at least try to tune out some of the other things until I have time to get a replacement board. edit: I just can back from a 60 mile drive. It's amazing what a Bosch relay from the local FLAPS and a foot of wire can cure. The fuel pump is now working off the relay and AAV and WUR now have power. I'm confident I will have a base line for a tune up this week. The throttle cable is sticking a little yet but when it's not the idle is now steady and smooth. No pulsing or gas fumes beltching out the exhaust. I still need to recheck the timing, reset the air screw, then hook up an O2 sensor and adjust the CIS sensor plate. I now have my sights set on the RRC. |
effutuo101 |
Jun 10 2007, 04:26 PM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Keep it up Rick, you will get er done. Sorry to hear you missed the AR. Hope to see you out and about soon.
3.6 teener |
Jul 18 2007, 05:27 PM
Newbie Group: Members Posts: 24 Joined: 10-January 06 From: San Diego, Ca. Member No.: 5,400 |
Hey Rick, hope all is well. Any thing new to report on the Alien? Also, did you make or buy your engine to transimission adapter? As much as I keep telling myself no, no, no..., I'm starting to think this might be a project I would like to take on, including trying to get the engine to run on 48IDA webers. Might be the (IMG:style_emoticons/default/smoke.gif) Thanks.
Lo-Fi Version | Time is now: 23rd November 2024 - 06:35 PM |
