rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,646 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,789 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Maybe @Tygaboy will lend you the "Header Legos" he used to make the 914 Ferrari headers?
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,417 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
@ClayPerrine @Rick 918-S Rick, the header kit I have is 1 5/8". If that'll work for you, let me know. I'd be happy to lend it to you. If you want to check it out, look up Ice Engine Works. |
Maltese Falcon |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,800 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
Maltese Falcon |
Maltese Falcon |
rick 918-S |
@ClayPerrine @Rick 918-S Rick, the header kit I have is 1 5/8". If that'll work for you, let me know. I'd be happy to lend it to you. If you want to check it out, look up Ice Engine Works. Thank you for the offer. Looks like Marty has a simple solution. I was just going to deconstruct 2 of the tubes from the collectors, Rotate the tubes inward to take the hips out of the set. The way I have it planned I won't loose any of the equal length tubes. |
rick 918-S |
Cool! Sent you a PM. |
rick 918-S |
Well I was able to deconstruct two of the header tubes on the right side today. I cut the bottom of the first two tubes at the head flange and tipped the header out to move it away from the cable pulley. Then I started reshaping the third and forth tubes for a tighter fit.
![]() ![]() ![]() I started tacking the tubes back together. I have some mandrel bends on order to finish out the tubes. |
technicalninja |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,807 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
OMG are those NICE! (IMG:style_emoticons/default/new_shocked.gif) So much better than the collectors on the exhaust now. I'd HAVE to have those! |
Maltese Falcon |
@technicalninja we use this merge style collector on all of our production headers; 928, 928 32v, 944, 944 16v, 968. A bit more HP/tQ and throttle response with the merge !
Rick I'm sure that once you get them big hips outta there, you're fab skills + final detailing on the primaries = you will have a good pair of custom headers. Hope you make the 914 meet up ! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/marty914.jpg) |
rick 918-S |
@technicalninja we use this merge style collector on all of our production headers; 928, 928 32v, 944, 944 16v, 968. A bit more HP/tQ and throttle response with the merge ! Rick I'm sure that once you get them big hips outta there, you're fab skills + final detailing on the primaries = you will have a good pair of custom headers. Hope you make the 914 meet up ! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/marty914.jpg) Thanks Marty!! This engine is going to be completely different with these cams and these headers!! (IMG:style_emoticons/default/aktion035.gif) |
rick 918-S |
Ok, so I have been working on this header issue over the week. As I was working on the first redesign I realized the header was too low and too long to really connect up to the out put tubes.
So back to the drawing board. This is what I ended up with. I am loosing the equal length effect a "little" but I don't have a tubing bender and didn't have any real tight bends to shoot the two rear tubes forward radically then back. Everything is tacked and ready to TIG weld. Ultimately I think it was worth the effort so far. ![]() |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,408 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
That is pretty sweet! Can't wait to see how it all fits together in the 914.
rick 918-S |
New 12200 cams are installed and the valve covers are back on.
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,485 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Sweet, better than ever alien (IMG:style_emoticons/default/very_first_smiley[1].gif)
8cyl goodness with the feels of my old 2.7 cis runners look. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,184 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
You have mad skills Rick! First rate detail.
Maltese Falcon |
You have mad skills Rick! First rate detail. (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/marty914.jpg) |
rick 918-S |
Started the research on the flywheel for the Boxster Conversion. This is a 928 Automatic Transaxle flywheel I think I can machine the ring gear off and use it.
Root_Werks |
Can't remember or find in this thread, is your 901 essentially a 4spd or are you able to make use of 1st?
Lo-Fi Version | Time is now: 7th September 2024 - 05:40 PM |
