39 Pages V « < 36 37 38 39 >
> FYI: Official Alien Build thread Started 2003, Alien Resurection is underway. Flywheel is finished - transaxle is bolted - Starter works
rick 918-S
post Oct 22 2024, 08:56 PM
Post #741
Hey nice rack! -Celette
Waiting for the flywheel. Here is a mockup of the starter mount.
rick 918-S
post Oct 23 2024, 10:31 PM
Post #742
I got the flywheel back from the clutch and brake place. The aluminum spacer was fine. I assembled the parts and mounted the flywheel. I was also able to cut out the 1/4" plate.
First Test fit
East coaster
post Oct 24 2024, 05:40 AM
Post #743
Do you plan on balancing the assembly?
rick 918-S
post Oct 24 2024, 05:53 AM
Post #744
QUOTE(East coaster @ Oct 24 2024, 06:40 AM) *
Yes I have a friend that has done it for me for my 914 setup.
Root_Werks
post Oct 24 2024, 09:25 AM
Post #745
Village Idiot
Dang that turned out nice! Boxster trans matted to a 928 engine.....has to be a one off!
rick 918-S
post Oct 24 2024, 09:33 AM
Post #746
QUOTE(Root_Werks @ Oct 24 2024, 10:25 AM) *
So I was thinking about this whole design early this morning and I think I am working on a redesign already. More to come.
worn
post Oct 24 2024, 09:11 PM
Post #747
can't remember
QUOTE(rick 918-S @ Oct 24 2024, 08:33 AM) *
Reminds me of the project creep that can annoy and satisfy. Good luck!
tygaboy
post Oct 24 2024, 09:29 PM
Post #748
Do-overs... I know the feeling. We're always happier with version N+1! (IMG:style_emoticons/default/happy11.gif)
Such a cool build.
rick 918-S
post Oct 25 2024, 05:59 AM
Post #749
QUOTE(tygaboy @ Oct 24 2024, 10:29 PM) *
Such a cool build.
I hear ya. I already scrapped the 1" adapter I spent a month sourcing materials, chasing parts, and cutting the dang thing out. But hey, I learned alot and had to re-remember what I did way back in 2003 when I started this thing.
What triggered the redesign was the thread on the failed clutch on the LS Boxster post. I did a search on line and see the flywheel for the LS has a very extended "HAT" I will call it. So I took some measurements for what I currently have and figured out a way to extend mine without moving the flywheel out away from the block.
I even called Kennedy to see if they would attach their part to my flywheel. I received a very cold reception and answer. So much for the easy route.
Chris914n6
post Oct 25 2024, 11:31 AM
Post #750
Jackstands are my life.
I have an issue with Kennedy too.
Inquired about getting an adapter ring spec'd for the 3.5 timing plate and they said they had a new design and I would need a $900 flywheel made. So I fiddled with it more and all I needed to do was rotate the ring 45*.
Then I decided to postpone the upgrade and mount the 3.5 to a subaru trans instead.
Sorry I can't offer more help, I have no idea how all your stuff fits together... (IMG:style_emoticons/default/smile.gif)
I was super impressed you got it done the first time.
rick 918-S
post Oct 27 2024, 09:49 PM
Post #751
I have been doing more research on the factory style Boxster clutch. I realized they have a duel mass flywheel. I read that and asked myself " what the heck is a duel mass flywheel?? I called Clay and asked him. He described it as two discs with rubber between them. I thought What the Heck, What if I design something similar without the rubber. So I cut out a second 1" disc and used a 1/4" plate and ended up with the exact measurement I needed to install the transaxle without surgery.
One step closer (IMG:style_emoticons/default/idea.gif)
914 Ranch
post Oct 28 2024, 05:54 AM
Post #752
Team Sharp where the 914 grow wings
Hey Rick , your gunna love this. When I was sophomore in HS my father put a Jag clutch disk on his '56 AH 100. He was fallowing Carol Shelby's example of a 260 ford AH hot rod. I think you can do almost anything you can imagine. Come on, the slippers use counter weights and multiple plates. I have a slipper in a sandrail that used shimmes to space the pressure plate from the flywheel.
Do you still have your 100S?
rick 918-S
post Oct 28 2024, 06:41 AM
Post #753
QUOTE(914 Ranch @ Oct 28 2024, 06:54 AM) *
Hey Joe! Thanks for the kind words. This is seems to be a never ending project. I sold the 100-4 several years ago and spent the money to purchase the Raspberry 914.
I would love to here those new traps! Miss you my friend. Hope our paths cross again some day. Drive it like you stole it! (IMG:style_emoticons/default/driving.gif)
rick 918-S
post Oct 29 2024, 07:55 AM
Post #754
I thought I would lend some validity to the direction I am going with this flywheel. This is a Boxster Engine. The distance from the trans mounting surface on the block to the face of the clutch disc surface is 4.5cm or 1 3/4" that is what I have now.
rick 918-S
post Oct 30 2024, 09:27 PM
Post #755
Finished the flywheel today. I cut the center out of the 1/4 steel spacer and the second 1" aluminum spacer ring and used my router to finish the aluminum to size. I still need to send it to get balanced but this is a major hurtle.
I finished the adapter plate tonight and bolted the transaxle to the engine.
East coaster
post Oct 31 2024, 04:50 AM
Post #756
Nice!
Root_Werks
post Oct 31 2024, 10:58 AM
Post #757
Village Idiot
Holy crap! I bet that's a first for anyone to do or see, nice!
jd74914
post Oct 31 2024, 11:39 AM
Post #758
Its alive
Wow, that's awesome!!
worn
post Oct 31 2024, 07:06 PM
Post #759
can't remember
QUOTE(rick 918-S @ Oct 30 2024, 08:27 PM) *
And that fits into…a 914? Wow. Wow.
rick 918-S
post Oct 31 2024, 09:30 PM
Post #760
Working on the starter mount tonight. I may end up using the botched 1" adapter plate after all. At least the bottom section... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/shades.gif)
- Lo-Fi Version Time is now: 22nd November 2024 - 10:11 PM
