This is What I did today. Removed FI, Went over to the Dark Side. |
Thack |
Oct 21 2007, 10:03 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
I'm going to go over my FI system. I took everything out of the car tonight. I'll install Solex H40 carbs in the meantime. What a vast difference the engine bay looks after the FI is gone. This is the before pic.
Attached thumbnail(s) |
Thack |
Oct 21 2007, 10:04 PM
This is after FI removal.
scrz914 |
Oct 21 2007, 10:12 PM
Member Group: Members Posts: 405 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
Looks bare. Dirty...but bare. Clean that puppy up.
So, are you going to recondition the FI? What would that process entail? |
Thack |
Oct 21 2007, 10:20 PM
First, I'm sending the injectors to be tested/cleaned. I found about a pound of dirt and rust in the tank. Then I'll test the fuel pump or get a new one. Look at the trigger points, get all new FI hose/lines... All of the components seemed to test OK while in the car like the MPS, CSV, TPS, pressure regulator but I was running very lean. I think not enough fuel was getting into the engine through some fault of the FI system.
scrz914 |
Oct 21 2007, 11:22 PM
I wonder if anyone here has gotten a wild hair and bought all brand new stock FI parts. Probably can't get new TPS or throttle body, but injectors, ECU, MPS ($$), hoses and even harness can all be had brand new. Would it be more than new Webers and linkage?
Thack |
Oct 22 2007, 10:57 AM
Lo-Fi Version | Time is now: 21st December 2024 - 08:40 AM |
