turn signal indicator, not working |
will |
Nov 23 2007, 10:34 PM
licensed to kill Group: Members Posts: 272 Joined: 14-December 05 From: rancho cucamonga, california Member No.: 5,276 |
I replace my dash bulbs and replaced the windshield washer switch. now the turn signal will not work nor will the windshield washer. it was working before. fuses are fine. hazard light works fine. gauge lights all work. my car is a 1973 model.
I rechecked all connections on the gauges and all seems fine. any clues as where to search next? has anyone dissected a turn signal switch and a windshield washer switch? I would like a pic of the internal mechanism. thanks, will |
Spoke |
Nov 24 2007, 07:51 AM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Sounds like a dirty, loose, or oxidized connector somewhere in the area of where you did your work. A dirty or oxidized connector is hard to find and usually cannot be seen with the naked eye.
Sometimes removing and replacing connections will give a better connection. Also double check for correct wiring. Might be time to get the voltmeter and schematic out and start looking for power and ground on the offending units. Spoke |
Lo-Fi Version | Time is now: 26th September 2024 - 05:34 PM |
