14 Pages V < 1 2 3 4 > »
> Tangerine Six Build, ***Update; 07/17/11***
9146FAN
post Apr 14 2008, 10:55 PM
Post #21
next
9146FAN
post Apr 14 2008, 10:56 PM
Post #22
last one for now
smg914
post Apr 14 2008, 11:11 PM
Post #23
Sahara Beige Steve
I'm sure you know that the area that would be below the side engine lid grills needs to be painted black.
9146FAN
post Apr 14 2008, 11:28 PM
Post #24
Thanks for reminding me.
9146FAN
Post #25
other side
9146FAN
post Apr 14 2008, 11:34 PM
Post #26
QUOTE(smg914 @ Apr 14 2008, 10:11 PM) *
BTW smg,
Your Sahara Beige is one beautiful machine. A friend of mine saw it in person at Datytona and said it was perfect.
(IMG:style_emoticons/default/beerchug.gif) cheers.
thesey914
post Apr 15 2008, 03:58 AM
Post #27
Can you give me any details of how you fitted the vinyl. It looks so professional. I'm just about to tackle mine. Did you trim the edges with scissors and how did you punch the holes?
pete914
post Apr 15 2008, 05:48 AM
Post #28
wow,
I wish i had done that clean a job on my sail trim vinyl!
Everything is looking damn near perfect
Do you have a choice for an engine?
(IMG:style_emoticons/default/beer.gif)
degreeoff
post Apr 15 2008, 06:56 AM
Post #29
I like big butts and I can not lie!
I said DAMN that looks good....I wanna paint booth too!!
stephenaki
post Apr 15 2008, 08:05 AM
Post #30
Can I get this one dad??
QUOTE(9146FAN @ Mar 30 2008, 08:20 PM) *
Under Dash
I wished my wiring looked that damn good!
9146FAN
post Apr 15 2008, 10:09 PM
Post #31
QUOTE(thesey914 @ Apr 15 2008, 02:58 AM) *
Thanks for the compliment. I'm no professional, but I did talk to a one before i tackeled it. Here's what I did:
1. Lay the aluminum trim pieces on the roll bar and attach with blue tape.
2. Using blue masking tape, trace the area where the glue should be sprayed less
1/4 inch inside, and lots of plastic to protect from overspray
3. Scratch the painted surface with a scoth bright pad, then remove any dust with
clean, dry cloth.
4. I used 3M Super 77 spray adhesive. Spraying roll bar and back side of vinyl
evenly.
5. Let dry for only 30-seconds. It is very tacky at this point but not dry.
6. While positioning, you need to "stretch" the vinyl, starting at the top.
Remember, it's very sticky, once it's on, it's very hard to move.
7. Wait a while, then peal back the masing tape and blue tape because there's
no glue there. Then trim with scizzors.
8. Once everything is where you want it, use a sharp scribe to poke holes.
then trimm around the poked holes with a sharp pointy exacto knife to make
the holes round.
There is a liitle patience needed at the top corners, kinda like gift wrapping.
BTW, all the stainless is new which makes the job look like a pro did it.
Good luck!
9146FAN
post Apr 15 2008, 10:19 PM
Post #32
QUOTE(pete914 @ Apr 15 2008, 04:48 AM) *
wow,
This was a normal driving six 2.0. Way Too Slowww. My driving choice is high RPM with high HP and lower torque. What I chose was a perfect 7R case (I know that's hard to believe), all mods done by Ollies, 2.7 RS Spec., NOS Mahle 8.5 European Spec., New "S" cams (yes, I know they're peaky) I'll run Weber 40's. Everything in the motor is new. Should be in the 200-215HP range. We'll see.
My goal is to open the engine lid and look like a '70 period motor. No electronics etc.
9146FAN
post Apr 15 2008, 10:22 PM
Post #33
QUOTE(degreeoff @ Apr 15 2008, 05:56 AM) *
It looks like you're no stranger to a paint booth. I checked out your thread, looking very cool.
Congratulations!
9146FAN
post Apr 15 2008, 10:25 PM
Post #34
QUOTE(stephenaki @ Apr 15 2008, 07:05 AM) *
Under Dash
I took my time getting the harness in. It's a PITA job. Also, new harness and Fuse block make any job look great.
Cheers.
thesey914
post Apr 18 2008, 04:10 AM
Post #35
beautiful pictures -thanks for the 'how-to' on the vinyl
Be very interested in seeing more progress pics
9146FAN
post Jul 6 2008, 10:17 PM
Post #36
Got the hardware back from the plating co (thanks Bruce).
The front dust shields are modified to fit with Brembo 4-piston front calipers from a 968. I cut the tin, then sent to plater.
9146FAN
post Jul 6 2008, 10:19 PM
Post #37
more plated hardware using yellow zink.
9146FAN
post Jul 6 2008, 10:20 PM
Post #38
some more hardware
9146FAN
post Jul 6 2008, 10:21 PM
Post #39
and the nuts-n-bolts
9146FAN
post Jul 6 2008, 10:22 PM
Post #40
I also painted the black area of the engine lid.
- Lo-Fi Version Time is now: 25th November 2024 - 04:29 AM
