maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
isnt it ideal to have the cable pull from the center of the crossbar, that way if it flexes, it flexes at the same rate for both carbs? I could put it off to the side easily, but i thought that the crossbar flexing would make syncing hard to do right Ideally, yes, but I seriously doubt the forces required to open the throttle plates would result in a measurable difference in the radial displacement at the end linkake arms whether the cable pull arm was in the center or at the end of the crossbar, at least with a substantial cross bar like the CB hex-bar, Triad, or Weltmeister (I have this one and it appears to be the same as the Triad). I bet the throttle cable breaks before you get noticeable flex in the cross bar. |
purple |
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None ![]() |
isnt it ideal to have the cable pull from the center of the crossbar, that way if it flexes, it flexes at the same rate for both carbs? I could put it off to the side easily, but i thought that the crossbar flexing would make syncing hard to do right Ideally, yes, but I seriously doubt the forces required to open the throttle plates would result in a measurable difference in the radial displacement at the end linkake arms whether the cable pull arm was in the center or at the end of the crossbar, at least with a substantial cross bar like the CB hex-bar, Triad, or Weltmeister (I have this one and it appears to be the same as the Triad). I bet the throttle cable breaks before you get noticeable flex in the cross bar. Fair enough! I will straighten that cable plate out and make it out of steel! That is...if the thing gives me enough for full frottle phun! |
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
You sure you are getting enough rotation on that linkage Elliyut? I only ask because that's sort of how mine looked before I made my newest bracket.
Have someone sit in and floor it and see if you can rotate it more. |
Kargeek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 ![]() |
[/quote]isnt it ideal to have the cable pull from the center of the crossbar, that way if it flexes, it flexes at the same rate for both carbs?
I could put it off to the side easily, but i thought that the crossbar flexing would make syncing hard to do right Not really, there is no flex with the crossbar. Early 911's have their crossbar bracket for the cable linkage off to one side. I've run mine for over 20 years - no problem. Attached thumbnail(s) ![]() |
purple |
Let me just say what everyone is thinking, kargeek....those air filters are pure secks... (IMG:style_emoticons/default/wub.gif)
Lo-Fi Version | Time is now: 23rd June 2024 - 01:46 PM |
