20 Pages V « < 5 6 7 8 9 > »
> Starting a 1973 restoration, Restoring a left for dead $500 914...
FourBlades
post Sep 28 2008, 07:38 PM
Post #121
From Wreck to Rockin
Steve,
I think you could salvage the two main "L" sections and adapt them to your
project, no problem. I'm trying to finish up the underside so I can get my car
back on its own feet again. Lets get together soon.
John
FourBlades
post Sep 28 2008, 09:23 PM
Post #122
Welded in and painted the rear trunk.
Started seam sealing the trunks and bottom of the car.
Once it is all seam sealed, I am going to paint it with two
more layers of eastwood rust encapsulator and then undercoat
it. I hope this will keep it from rusting for a long time.
John
FourBlades
post Oct 3 2008, 06:31 PM
Post #123
Rust encapsulator, seam sealer, 2 more coats of rust encapsulator, 2 coats of
rubberized undercoating.
Going to install brake master cylinder, some brake lines, steering rack,
front jacking donuts, then its time to flip it back to normal mode.
John
southernmost914
post Oct 3 2008, 07:41 PM
Post #124
KEY WEST/HAVANA Tunnel Authority
Awsome! Funny how in Florida you do most of your work in the summer(afternoon rain, storms). I grew up in M.I. , Hampton homes just North of 520. I know every road in Brevard county. You got skills, ROCK ON!
Steve
jc914
post Oct 4 2008, 08:29 AM
Post #125
You are doing a great job. Very impressive restoration (IMG:style_emoticons/default/beerchug.gif)
FourBlades
post Oct 16 2008, 08:10 PM
Post #126
Thanks for the feedback guys. (IMG:style_emoticons/default/smile.gif)
Big news today. I welded on the front jacking donuts and flipped the car back
to normal side down!!!
Wow, it looks weird this way after so long on its side. Flipping it back was a little
hairy because it gets really heavy past the balancing point. I screwed a long
2x4 on to provide leverage and carefully eased it down.
I you are [A] building a wood rotisserie in your backyard [B] planning to use
it for more than a few months, and [C] pretty much considered insane by your
friends, then you really should paint the rotisserie because the plywood
reinforcements will rot and weaken in 3 or 4 months, and plan ahead when tipping
the car back because if it gets away from you it will crash down big time. You
need to use leverage and caution because without 4 or 5 friends you can't
muscle a 350 pound car body.
Now I in the home stretch, only 77 items on my to do list and $3500 more
parts on my buy list. I am so glad I saved money on my car insurance
because restoring a $500 car is not a big money maker. (IMG:style_emoticons/default/rolleyes.gif)
It is amazing how much a 914 costs when you buy every single part
except the (rusty) tub one by one. Find a car with the vast majority of the
parts in useable condition if you want to be a CSOB.
Seriously, I am getting really excited about getting this thing on the road.
John
jc914
post Oct 16 2008, 09:43 PM
Post #127
Once again Great job John. I am glad you were able to get it back down without any damage. It is looking good. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/driving.gif)
sean_v8_914
post Oct 16 2008, 11:16 PM
Post #128
Chingon 601
wow!
my hell hole repairs suddenly seem so trivial
dlee6204
post Oct 16 2008, 11:28 PM
Post #129
Howdy
I've watched this build from the beginning and I'm even starting to get excited! (IMG:style_emoticons/default/w00t.gif) Keep up the good work!
FourBlades
post Oct 17 2008, 07:11 AM
Post #130
Thanks for the good words, it keeps me motivated. (IMG:style_emoticons/default/piratenanner.gif)
I REALLY wanted to make the Rocket City Ramble this year but it was not to be.
I'm gonna make next year's east coast event if I have haul my 914 there in a
dump truck...
John
FourBlades
post Oct 19 2008, 06:34 PM
Post #131
Finishing the passenger door sills. Welded on the support triangles. Used the
sill plate to line up the triangles properly.
Added the sill plate. Now I have to close the hole between the sill
plate the door jamb. Trim off the rusty edges.
Patched it using two separate pieces of metal to avoid having to make such
a complex shape in one piece.
Weld it up and grind it. It ain't purty but it is solid.
Passenger side is done.
John
FourBlades
post Oct 19 2008, 06:58 PM
Post #132
Now I have this to look forward to fixing. (IMG:style_emoticons/default/wacko.gif)
The inside where the door vent comes out is almost as pretty. Anyone got
any ideas about the easy way to fix this??? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
For now, it is (IMG:style_emoticons/default/beer3.gif) time...
John
FourBlades
post Oct 20 2008, 07:55 PM
Post #133
I broke down and ordered the Auto Atlanta sail panel to fix the outside of
that nasty rust hole in the previous post.
Fixing the driver's side door sill. Still have some major rust areas to fix.
Cut out the rusty parts and clean it up. I don't know about you but I hate drilling
out spot welds, so I am using a new trick I read about in a book. First, cut away
the majority of the panel being removed. This leaves a strip of metal that is spot
welded to the other panel. Use a wire wheel to clean the strip and reveal where
the spot welds are. Then use a grinder to cut through just the panel being
removed in between each spot weld. Then the situation looks like this:
Now take some major end nippers and grab hold of each piece of the strip. By
squeezing down and then twisting it is easy to break off each piece of the strip
one by one.
The end nippers are great because they get under the ends of the strip easily.
Only the very small spot weld area is actually attached to the other panel making
it easy to remove the pieces.
I find this method is faster and less annoying than drilling out each weld. It also
really helps to cut out the majority of the panel first whether you are drilling or
twisting the rest off. Then use a grinder to remove the spot weld stubs.
Saves me lots of time and iritation.
FourBlades
post Oct 20 2008, 08:13 PM
Post #134
Continue fixing the drivers door sill area. Made some patches for the holes using
left over long replacement panel. This makes fitting the patches very easy.
(IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif)
Took some time grinding down all the welds in this area. Made a patch for the
sill. Put back the chunk of fender I cut away months ago while fixing the heck
hole.
Carefully welded it all up. Tried to go slow and not warp the fender. It looks
pretty good, maybe bowed out a tiny bit. I'll need to grind it down carefully
too so as not to over heat it.
I think this leaves six rusty areas to fix. (IMG:style_emoticons/default/piratenanner.gif)
Driver side sail panel. (IMG:style_emoticons/default/bootyshake.gif)
Driver side lower door jamb. (IMG:style_emoticons/default/blink.gif)
Driver side cowl to fender joint. (IMG:style_emoticons/default/sheeplove.gif)
Passenger side cowl to fender joint. (IMG:style_emoticons/default/bs.gif)
Front trunk rain gutters. (IMG:style_emoticons/default/icon8.gif)
Rear trunk tail light openings. (IMG:style_emoticons/default/welder.gif)
Each one will probably take 3-5 hours to fix.
One more month and it will have been a year. (IMG:style_emoticons/default/bye1.gif)
John
jd74914
post Oct 20 2008, 08:38 PM
Post #135
Its alive
QUOTE(FourBlades @ Oct 20 2008, 08:55 PM) *
Pansy. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/happy11.gif)
Just kidding! The car looks great. (IMG:style_emoticons/default/biggrin.gif)
FourBlades
post Oct 20 2008, 08:46 PM
Post #136
Jim, That is some nasty sail panel rust! Did you make your own patch
for that??? Those are some interesting looking side vents...
John
jd74914
post Oct 20 2008, 09:13 PM
Post #137
Its alive
Yep, I made all of my own patches (the other side looked like that too, except its entire door handle recess was gone). I'm only 20, and at that time (well, currently too) had much more time than money, and not buying replacement stamping was a great way for me to save. It was also a great experience in metal working.
The side vents were added by someone in the 80s; probably well before I was born. (IMG:style_emoticons/default/laugh.gif) I'm not their biggest fan, but I do like their uniqueness. What you see is just a cutout. They have a "cover thingie" that bolts on over it and gives them definition.
Jim
FourBlades
post Oct 21 2008, 07:30 AM
Post #138
Jim,
Looks like you did a nice job fixing those holes. I like to make my own patches
but I guess I am getting impatient to be done with the body work. My new
engine is collecting dust in my bedroom right now, I want to see it in the car...
John
Root_Werks
post Oct 21 2008, 08:21 AM
Post #139
Village Idiot
(IMG:style_emoticons/default/huh.gif) I will not wine about the rust on my 914 ever again, I will not wine about the rust in my 914 again.... (IMG:style_emoticons/default/blink.gif)
Seriuosly, great work! I love keeping up on this thread. (IMG:style_emoticons/default/welder.gif)
jd74914
post Oct 21 2008, 02:52 PM
Post #140
Its alive
QUOTE(FourBlades @ Oct 21 2008, 08:30 AM) *
Jim,
John
That sentiment is easy to sympathize with. (IMG:style_emoticons/default/smile.gif)
20 User(s) are reading this topic (20 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 04:05 AM
