> Starting a 1973 restoration, Restoring a left for dead $500 914...
FourBlades
post Dec 15 2007, 02:02 PM
Post #37
From Wreck to Rockin
Hello 914 World Members!
I am starting on restoring a $500 914 that was left in a field for several years with no windshield. The car belonged to the POs older brother and thus has sentimental value. The sold it to me on the condition that I not part it out. I was looking for a project so this was fine with me. This is my first restoration project so I figured I would learn a lot (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
The car is a mixture of really good sections, appears to have suffered no major accidents, is straight, never been repainted--but it has totally rusted out floors and hell hole. All the suspension mounting points are not rusted. The door gaps are all even and good. If I can replace the floors, I think it will be a good straight car. Many small parts were stolen while it was "stored" and the wiring loom is a complete loss.
Thanks for any comments...John
FourBlades   Starting a 1973 restoration   Dec 15 2007, 02:02 PM
FourBlades   Some pictures in my restoration "garage...   Dec 15 2007, 02:09 PM
David_S   Hello 914 World Members! I am starting on re...   Dec 15 2007, 02:13 PM
Joe Owensby   Start digging into it to see how bad the rust is. ...   Dec 15 2007, 03:09 PM
roadster fan   :wttc: Dig In, and see what you have. The under...   Dec 15 2007, 03:16 PM
Chuck   :wttc: As Yogi would say, its deja vu all over a...   Dec 15 2007, 03:42 PM
FourBlades   :wttc: As Yogi would say, its deja vu all over ...   Dec 15 2007, 10:18 PM
Chuck   If you decide to go the big 4 route check out Ja...   Dec 16 2007, 05:34 PM
Jake Raby   If you decide to go the big 4 route check out Ja...   Dec 17 2007, 07:58 AM
FourBlades   Thanks for the encouragement. I can see this is a...   Dec 15 2007, 10:15 PM
Chuck   You're correct. The floorpan is spot welded to...   Dec 15 2007, 10:20 PM
swl   I hate to be a spoil sport but that interior pictu...   Dec 16 2007, 07:46 AM
FourBlades   I hate to be a spoil sport but that interior pict...   Dec 16 2007, 09:40 AM
swl   Just for the record that wasn't me on the digg...   Dec 16 2007, 03:48 PM
FourBlades   Thanks guys, I am seriously interested in a 2270 4...   Jan 17 2008, 06:38 PM
FourBlades   Cleaned to good metal, primed, patched and added h...   Jan 17 2008, 06:43 PM
tracks914   Nice work, I think you will do well. I just did a...   Jan 17 2008, 07:36 PM
swl   Indeed that was one awful looking chassis you brou...   Jan 18 2008, 03:10 PM
FourBlades   Thanks Doug, I will most likely be asking for advi...   Jan 18 2008, 08:13 PM
tracks914   Thanks Doug, I will most likely be asking for adv...   Feb 3 2008, 04:16 PM
FourBlades   Hell hole finally makes it to primer heaven! ...   Feb 2 2008, 07:44 PM
SirAndy   nice progress! :trophy: did 'ya add th...   Feb 2 2008, 07:46 PM
FourBlades   Cut rust out of front of passenger long. Notice t...   Feb 2 2008, 07:56 PM
FourBlades   Innermost sheet metal welded in. Sleeving the i...   Feb 2 2008, 08:03 PM
FourBlades   Welded and cleaned. Nothing better than shiny new...   Feb 2 2008, 08:10 PM
FourBlades   VIN number added to 914 World database. I'll ...   Feb 2 2008, 08:15 PM
FourBlades   Note that I use weldable primer on anything that w...   Feb 2 2008, 08:22 PM
Bartlett 914   Looks pretty good. Keep up the nice work and keep ...   Feb 3 2008, 10:03 AM
rjames   Looking great! And I couldn't agree mor...   Feb 3 2008, 12:57 PM
sendjonathanmail   Wow Doug, that was some serious rust. Lookin' ...   Feb 3 2008, 05:16 PM
FourBlades   Man Doug, looks like the heater tube was the only ...   Feb 3 2008, 09:51 PM
jd74914   McMaster Carr should have the right size tubing (s...   Feb 3 2008, 10:06 PM
FourBlades   Fixing the driver side footwell and long. It is m...   Feb 22 2008, 06:44 PM
FourBlades   :blink: :blink: Peeling the rust bucket onion :...   Feb 22 2008, 06:53 PM
FourBlades   Rebuilding the first layer of the onion. Made a p...   Feb 22 2008, 06:58 PM
FourBlades   Rebuilding the second layer of the onion. Made a ...   Feb 22 2008, 07:14 PM
FourBlades   Now I have this pristine pedal and brake master cy...   Feb 22 2008, 07:38 PM
FourBlades   Afew more gratuitous Roebling pictures... Now...   Feb 22 2008, 07:41 PM
FourBlades   Welded on a patch to the lower part of the passeng...   Mar 14 2008, 08:16 PM
FourBlades   Now it is time to fix the "Heck Hole" wh...   Mar 14 2008, 08:21 PM
Van   Fantastic work!   Mar 14 2008, 08:38 PM
FourBlades   Thanks Van, but I am really just an amateur at thi...   Mar 19 2008, 06:02 PM
TINCAN914   :worship: :worship: :welder: Keep it up.. :head...   Mar 19 2008, 06:37 PM
charliew   John good work. I have used por 15 for many years ...   Mar 26 2008, 01:04 PM
sean_v8_914   you guys are true 914 champions. the POR 15 need...   Mar 26 2008, 01:25 PM
Richard Casto   John, Great work. It is nice to see someone save...   Mar 26 2008, 03:41 PM
FourBlades   Thanks for all the responses. Its nice to know I ...   Mar 27 2008, 08:36 PM
FourBlades   Fixing the driver's side jacking point. I cut...   Mar 31 2008, 08:31 PM
SirAndy   :trophy:   Mar 31 2008, 08:38 PM
FourBlades   One more major longitudinal problem to fix. Made ...   Mar 31 2008, 08:44 PM
FourBlades   I got a rear half of a tunnel plus cross member fr...   Mar 31 2008, 09:06 PM
solex   John, I''m impressed not only do you have ...   Mar 31 2008, 09:18 PM
FourBlades   Thanks Dan. I'm telling you, it really helps ...   Mar 31 2008, 09:26 PM
FourBlades   Two big milestones today. Finished off a 10 pound...   Apr 8 2008, 07:29 PM
Sleepin   Great work! I really enjoyed the read so far...   Apr 8 2008, 11:37 PM
jbyron   Wow! Very educational. Keep up the good work...   Apr 9 2008, 10:11 AM
FourBlades   Flip Your 914 the CSOB Way I got fed up with work...   Apr 13 2008, 06:15 PM
FourBlades   Flip Your 914 Part Deux When the car was tipped a...   Apr 13 2008, 06:21 PM
slow914   dude, that is badass   Apr 13 2008, 06:50 PM
TROJANMAN   Flip Your 914 Part Deux It's like a 914 ...   Apr 15 2008, 08:38 PM
ericread   Flip Your 914 Part Deux It's like a 914...   Apr 16 2008, 12:15 AM
FourBlades   No, it is cheap ass! I think this cost about ...   Apr 13 2008, 06:59 PM
Bartlett 914   Looks pretty good. My car is on a rotisserie. It i...   Apr 14 2008, 09:04 AM
FourBlades   Mark, My motivation for doing it this way was to ...   Apr 15 2008, 08:13 AM
Gint   That's kickass! Thanks for posting that.   Apr 15 2008, 08:21 PM
tracks914   That's just insane!!! For the 914 ...   Apr 15 2008, 09:14 PM
McMark   Either way you were gonna be famous. This way you...   Apr 16 2008, 02:16 AM
tdgray   Congrats... now there is thinking outside the box....   Apr 16 2008, 08:28 AM
Eric_Shea   Way to go... cool thread! :trophy:   Apr 16 2008, 09:12 AM
FourBlades   Wow, thanks everyone. I'm glad people liked t...   Apr 16 2008, 12:45 PM
Eric_Shea   Make me a Resonator! :D   Apr 16 2008, 02:17 PM
FourBlades   Eric, I can make you a Dobro style guitar with a ...   Apr 16 2008, 10:28 PM
FourBlades   Finished welding on the floor pans and primed them...   Apr 25 2008, 12:03 PM
FourBlades   Primed front of passenger compartment and floor pa...   Apr 26 2008, 05:44 PM
McMark   Lookin' GREAT!!!!   Apr 27 2008, 01:22 AM
swl   Just freakin' awesome. I'm so impressed w...   Apr 27 2008, 07:07 AM
scotty b   :lol: That's awesome !!! I 'v...   Apr 27 2008, 09:50 AM
FourBlades   Thanks Scotty, you should see the ballista I built...   Apr 27 2008, 07:42 PM
FourBlades   Cut out the front trunk. About now you start won...   Apr 27 2008, 08:03 PM
FourBlades   Seam welded in between the tacks on the new front ...   Apr 27 2008, 08:07 PM
ericread   AMAZING JOB!!! :headbanger: Keep up...   Apr 27 2008, 08:40 PM
FourBlades   Building the armageddon proof clutch tube!...   May 29 2008, 08:11 PM
FourBlades   Took me a while to figure out what tubes and cable...   May 29 2008, 08:23 PM
Bartlett 914   John you make these things look easy. I did the sa...   May 30 2008, 08:41 AM
Richard Casto   John, Keep it up! I love this thread. :) B...   May 30 2008, 08:49 AM
FourBlades   John, Keep it up! I love this thread. :) ...   Jun 2 2008, 05:06 PM
Slider   Nice Job! Im glad to see someone bringing ano...   Jun 2 2008, 07:48 PM
FourBlades   More work on the tunnel for welding porn fans. Bo...   Jun 11 2008, 09:18 PM
craig downs   Awesome work I'm glad I didn't have to go ...   Jun 12 2008, 12:36 AM
FourBlades   It does not make a lot of sense. I wish they had ...   Jun 12 2008, 07:49 AM
914Tom   great motivation to get my lacy butt off the coutc...   Jun 12 2008, 02:22 PM
FourBlades   All right, 914Tom, lets see some pictures of your ...   Jun 12 2008, 05:12 PM
Eric_Shea   Ut-ummm... :WTF: All this welding seems to be t...   Jun 12 2008, 06:58 PM
FourBlades   That is freaking crazy. How big a tire can you fi...   Jun 12 2008, 09:09 PM
914Tom   OK, here is my projekt. bough it winter 2003-2004...   Jun 14 2008, 06:43 AM
Eric_Shea   Awesome :trophy: I've always loved Zebra.   Jun 12 2008, 10:27 PM
FourBlades   Tom, Great work! Looks like you are making s...   Jun 14 2008, 10:58 AM
FourBlades   Got some rebuilt calipers recently from Eric Shea....   Jul 7 2008, 08:18 PM
FourBlades   Closing up the firewall. I salvaged the e-brake t...   Jul 7 2008, 08:35 PM
FourBlades   Inside of the firewall. Firewall and tunnel spr...   Jul 7 2008, 08:46 PM
4 Pages V  1 2 3 > »
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 01:04 PM
