20 Pages V « < 4 5 6 7 > »
> Starting a 1973 restoration, Restoring a left for dead $500 914...
FourBlades
post Jun 14 2008, 10:58 AM
Post #97
From Wreck to Rockin
Tom,
Great work! Looks like you are making some good progress. Maybe someone
has a door post from a wrecked car for you. Seems like it would be hard to
repair that area otherwise.
You should start your own progress thread so we can see what you are doing.
Good luck...John
FourBlades
post Jul 7 2008, 08:18 PM
Post #98
Got some rebuilt calipers recently from Eric Shea.
MMMM, tasty!!!
Eric's calipers are a thing of beauty and very reasonably priced, although
there is a $100 core charge per foo foo dog.
John
FourBlades
post Jul 7 2008, 08:35 PM
Post #99
Closing up the firewall. I salvaged the e-brake tubes from an old firewall by
cutting out some sheet metal around them on the inside and outside walls.
Here is the inside section.
Did a hideous job of welding the outer piece in. Not sure why the welds came
out so badly. Also made a small patch for the left side.
Made a patch for the passenger firewall section.
These welds turned out better. It ended up taking 9 separate patches
to complete close up the inside and outside of the firewall and the result
would make Mary Shelley proud.
This is definitely a case where I would have been better off just buying the inner
and outer repro pieces from Auto Atlanta. The hassle of drilling out all the spot
welds to get the fragements of the old crap out would have been less than all the
careful cutting and fitting I had to do for a look that will never pass for factory.
The more I work on this, the more I want the sheet metal repairs to be close
to original.
FourBlades
post Jul 7 2008, 08:46 PM
Post #100
Inside of the firewall.
Firewall and tunnel sprayed with Eastwood silver rust encapsulator.
Almost done with the chassis work. Then its on to cosmetic sheet
metal. (IMG:style_emoticons/default/mad.gif) The last post not withstanding I am tempted to make this
thing into a rat rod and spray matte black primer over the rest of
the rust and holes and be done with it... (IMG:style_emoticons/default/happy11.gif)
John
FourBlades
post Jul 17 2008, 02:21 PM
Post #101
I want to keep an eye on the tune and health of my engine so I am
thinking of running some additional gauges. I am getting a Raby
2270 built by McMark and want to keep it in good shape.
I am thinking of using a wide band air fuel gauge, a cylinder head
temperature gauge, an oil temperature gauge, and an oil pressure
gauge. Because this will be a street/AX/DE car and I live in Florida
I think the temperatures need watching.
There is no VDO WB AF gauge, so I will probably buy autometer guages
(or something) that are close to the VDO look. I will probably mount them
on a home brewed center console.
Any suggestions or ideas would help me out because I am just starting
to work on my gauge approach.
John
FourBlades
post Aug 19 2008, 02:25 PM
Post #102
Its another beautiful day in the Sun Shine State. (IMG:style_emoticons/default/mad.gif)
Just right for working on my 914 in my outdoor "garage". I hope my 914 rocker
does not tip over, I have weighted the framework with bags of blasting media and
some paving stones. The eye is forecast to pass right over my house with 65 mph
winds. Maybe I will go to the beach instead of working on my car. (IMG:style_emoticons/default/rolleyes.gif)
John
Eric_Shea
post Aug 19 2008, 04:03 PM
Post #103
PMB Performance
Stay dry and keep the wood side down! (IMG:style_emoticons/default/ohmy.gif)
Arms make it? 4 packages from thee arrived yesterday. (IMG:style_emoticons/default/wink.gif)
FourBlades
post Aug 19 2008, 08:02 PM
Post #104
Eric,
Yes, thanks I got the arms last week. They look fantastic. I have the
cores boxed up and will send later this week. So far this storm has been
no big deal here, just a lot of rain.
John
914rhatt
post Aug 19 2008, 11:12 PM
Post #105
WOW!!!! I just wanted to say thatwas remarkable....I have had two 914 for years one I drove for only a few years and the other I got as a donor car for the driver...I started to get my driver back on the road a few weeks ago and was kind of getting depressed with the rust...(Mind you nothing like what you were showing..) but still a bit...you have given me new energy to get mine back on the road...it has been setting for 18 years until a few weeks ago...Thanks for all the pic's and the inspirationto go on....
FourBlades
post Aug 20 2008, 10:59 AM
Post #106
Good luck! 90% of it is keeping your motivation going, that and:
Everything I needed to know, I learned from 914World. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
John
FourBlades
post Sep 17 2008, 05:58 PM
Post #107
OK, I'm back. I have made a buncha progress that I will be posting but lately
I have been busy with a lot of stuff that is no where near as important as my
914. I cut out some metal from the bottom of the long that was rusted very
thin, made an 18 gauge patch and welded it in.
FourBlades
post Sep 17 2008, 06:04 PM
Post #108
I replaced one of the inner suspension consoles and finally got around to replacing
the 18 guage reinforcing plates that join the inner and outer sections. The inside
and outside pieces of the pinch weld at the bottom of the long have gaps in
between each spot weld. Like the forces on the suspension console halves
have been trying to pull the long apart. You can see the gaps in the middle of
the left side of the picture. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif)
FourBlades
post Sep 17 2008, 06:18 PM
Post #109
The boxed reinforcement of the floor under my pedal area was cut off so I made
a reinforcing section from 18 guage and welded it on. Not sure if I over did it here
but I think having a pedal box that does not flex is a Good Thing.
I also welded on the seat attachments. I determined where to put these pieces
by temporarily screwing seat tracks onto them and installing the tilt adjustment
combs. I could actually put seats in my 914 now and not have them fall through
onto the ground. Not sure I can handle this...
I'm trying to finish up everything that needs to get welded to the floor, so I can
finish painting, seam sealing and undercoating it and turn my car back the way
Porsche intended it to be. I need to do this before my "rotisserie" rots....
John
heavydriver
post Sep 18 2008, 12:08 PM
Post #110
Will you be available for some consultationsin the near future ?????? (IMG:style_emoticons/default/driving.gif)
FourBlades
post Sep 18 2008, 12:29 PM
Post #111
Sure, what do you have in mind? Realize that I am no expert, just some guy
who learned a buncha stuff by reading about it and trying it out...
John
carr914
post Sep 18 2008, 02:50 PM
Post #112
Racer from Birth
He wants to learn how to keep termites away. (IMG:style_emoticons/default/biggrin.gif)
Your projects looking good.
T.C.
FourBlades
post Sep 18 2008, 05:32 PM
Post #113
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
I am seriously worried about the wood rotting soon. I should have
painted it.
If you are doing a big build thrash and BBQ I may be able to trek
over and help out. I am sure I will learn some stuff...
John
FourBlades
post Sep 18 2008, 08:05 PM
Post #114
Time to replace the rusty rear trunk.
First I need to cure a painful case of 914 trunk inner tit rot. (IMG:style_emoticons/default/icon8.gif)
There are actually about six holes that need to be cut out and replaced on the
rear whatever the ass panel of the car is called.
FourBlades
post Sep 18 2008, 08:13 PM
Post #115
Got five of the holes welded up and somewhat ground down.
I decided to stop grinding when my neighbor started hurling good size
coconuts in "support" of my project. While they make a good pina colada,
they leave dents that I will have to pound out later...
Test fit my replacement panel which should make a "nearly invisible repair"
as they say. See if you can spot the new panel.
I really need to start drinking more... (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif)
John
FourBlades
post Sep 19 2008, 05:39 PM
Post #116
Spare suspension mounts for ConeDodger. Threads look ok.
Is this what you are looking for?
John
- Lo-Fi Version Time is now: 27th December 2024 - 02:47 AM
