Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
The wheels look great!
Nice patch work! What ga steel are you using? 14ga? |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,996 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The wheels look great! Nice patch work! What ga steel are you using? 14ga? Thanks. Compared to what they looked like when I got them, they turned out fantastic. I can't wait to 5-lug the car and mount them. I'm using 18ga on the floor and body panels and 16ga on the longs. I have a big piece of 14ga that I will put on the outside of the long for further reinforcement. |
Spoke |
Finished up all the small pieces of the floor next to the inner long.
Also tied in the crossmember. The passenger side floor is now done unless some more rust-through holes show up. Attached image(s) ![]() ![]() ![]() |
Andyrew |
Wow 18ga really? I didnt realize the floors were so thin.
You really think you'll need another bit of reinforcement after the engman kit? I have the engman kit and it is pretty damn solid. The next step is tieing in the suspension points to the long IMHO |
Spoke |
Wow 18ga really? I didnt realize the floors were so thin. You really think you'll need another bit of reinforcement after the engman kit? I have the engman kit and it is pretty damn solid. The next step is tieing in the suspension points to the long IMHO I don't know about what gauge the floors are. I guessed at 18ga since the longs are 16ga I think. I was thinking about how to better tie the front of the long to the door pillar. Any suggestions? |
Andyrew |
Hmmm that is a good question, I havent looked at that piece in a while, you got any pics of the area?
Spoke |
Cleaning up the front portion of the long. Found 2 holes so time to cut it open.
![]() ![]() ![]() ![]() So this is what is left of the bottom of the long. ![]() |
Spoke |
Prepped the area for new metal.
![]() Center support done. ![]() Outer long is much more solid now. ![]() ![]() |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Spoke |
Where's that home-made tool thread? Here's my temporary metal break. I scored this 14 gauge piece so it would bend easily.
![]() ![]() Finished piece ready for installation. ![]() |
Spoke |
14 gauge outer clam shell all welded on.
Spoke |
Putting the door support back together.
The support plates will help bind the support to the bottom piece. ![]() I put a support piece from the top of the long to the door support. ![]() ![]() |
Spoke |
Finished the door support. Used 16 gauge for all new metal.
Attached image(s) ![]() ![]() ![]() ![]() |
Spoke |
For the finishing touch, I put ribs on the outer long. For now I'm finished welding on the passenger long.
Next steps: o Clean up welds on long. o Sandblast the rear fender replacement. It will need some new metal. o Install fender replacement. o replace sill. o Paint outer long and door jamb. Attached image(s) ![]() ![]() ![]() |
Andyrew |
Thats a shitload of metal there!
The Ribs were an interesting idea! |
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
Wow, that is a lot of welding! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) Very nice work. John |
Spoke |
Sandblasted the fender replacement. I knew it was rusted through. Now the damage is obvious. The whole corner of the fender needs replacing.
![]() ![]() ![]() I will make 4 pieces to do the repair. This is the base plate. Next will be the bottom lip, then the door jamb, then the fender and underside wraparound. ![]() ![]() |
Spoke |
My latest purchase. Not bad for $150 delivered to my home.
This is from a 74 and has the 3-inch front calipers. Rotors will likely need replaced. Front calipers will need rebuilt. ![]() Separate purchase. Saves me from widening and rebuilding my existing calipers. These look too nice to use. ![]() |
Andyrew |
With the spacers for vented rotors? Nice!!
Talk about a score! |
Spoke |
Bottom lip is welded on.
![]() ![]() Now the door jamb piece. ![]() Finally the fender piece. Too late tonight to grind the welds down. Good as new. ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 02:48 PM |
