17 Pages V « < 11 12 13 14 15 > »
> Spoke's 71 2.056L 914 Progress Thread, Driving it Like I Stole It
Spoke
post Apr 8 2011, 09:02 PM
Post #241
Jerry
Got around to grinding down the welds on the fender. The repair came out very good.
Spoke
post Apr 8 2011, 09:05 PM
Post #242
Jerry
WTF are these appendages? Any guesses?
Spoke
post Apr 9 2011, 07:02 PM
Post #243
Jerry
One shortcoming of the inner fender well is that all the rocks and debris kicked up by the tires can end up trapped between the rocker panel and the jack point.
With these brackets I'll attach a rock deflector to keep the jack point relatively clear of debris. I'm thinking of using a plastic-type mudflap for the material. Don't really want to use steel.
Spoke
post Apr 9 2011, 07:10 PM
Post #244
Jerry
Well, with all the work I did to the inner and outer longs, I managed to shrink my car by about 1/8 inch such that the passenger door wouldn't close.
After the accident, the door gap was quite small but today when I mounted the door, it wouldn't close. So I had to shorten the rear fender a bit and push the door jamb back a bit.
The last piece to attach on the passenger side. I cut the piece to near the right size then used the angle grinder to get it to fit nice. Looks good not to see the big hole in the fender. I bought this piece about 2 years ago.
This is the original door sill. I cut off about 5 inches of the back part of this cause it was totally rusted out.
Spoke
post Apr 10 2011, 08:23 PM
Post #245
Jerry
The last job for now. Finished attaching the door sill.
The sill supports are made from 16 gauge steel.
I may have added a lot of steel in my rustoration but I took off 26 pounds of steel, rust, and tar.
Spoke
post Apr 10 2011, 08:32 PM
Post #246
Jerry
The 914 is out of the garage for the first time in 4 months. The metal work is done on the rear fender but bodywork is needed now. The 911 is going in the corner for now and I'll drive the 914 for the time being.
One fat ass and one narrow one.
9fourteen
post Jun 10 2011, 01:58 PM
Post #247
I see you used weld-through primer on this. How well did that stuff work? Did you always get good welds with it or did you have to remove some of it? What type/brand did you use?
Great job btw. Your project is inspiring me to finally start cutting the rust out of mine.
Thanks,
Don
Spoke
post Jun 10 2011, 03:50 PM
Post #248
Jerry
QUOTE(9fourteen @ Jun 10 2011, 03:58 PM) *
Thanks,
Don
Thanks, and BTW,
I don't know what brand I used. The welding wasn't bad through the primer. It does smoke a bit but you do want primer between all the layers of steel or behind panels you can't paint after installation.
porsche_dreamer
post Jun 10 2011, 10:09 PM
Post #249
Looks like some good progress. The turbo doesnt look to bad either!
Spoke
post Jul 11 2011, 09:08 PM
Post #250
Jerry
Got my front M-calipers back from Eric Shea. Wow!
Brake calipers front and rear ready to go for 5-lug conversion. Just need to get new rotors, and sell my 911 rear hubs & half shafts.
fitsbain
post Jul 27 2011, 08:15 AM
Post #251
Ask me if my car has rust!!!
Glad to see that corner came to good use.
Sorry it was so rusty.
Spoke
post Feb 11 2012, 07:50 AM
Post #252
Jerry
QUOTE(fitsbain @ Jul 27 2011, 09:15 AM) *
The piece was still 100x better than what I took off.
Spoke
post Feb 11 2012, 07:52 AM
Post #253
Jerry
Any tips for dislodging the spline? It seems to be rusted on. I've been soaking it in Aero Croil.
okieflyr
post Feb 11 2012, 09:34 PM
Post #254
9fauxteen
I can't see that the axle is disconected on the trans side (it should be) but you can thread the axle nut back on upside down and flush with the end, and then use a BFH to break it loose back through the hub.
Jeffs9146
post Feb 11 2012, 09:58 PM
Post #255
Ski Bum
You have to remove the trailing arm to get it out any further!
I just did this last month. You wont be able to pull the hub out of the bearing that way. You can remove the axcel and then pound out the hub and bearing but I found it easier to just remove the trailing arm and do it on the bench. That way you can leave the axcel, CV's and stub still attached and slide it back into the hub when you put the arm back on!
Here is the motivational photo!!!
Spoke
post Mar 1 2012, 08:05 PM
Post #256
Jerry
I finally dislodged the spline. Aerocroil, time, and a BFH did the trick.
Correct about the axle still connected to the trans; there was still plenty of play between the CVs to loosen the spline from the hub.
With my newly unemployed status, I put the rear end back together again and will focus on some longitudinal rust repairs since I have plenty of metal, cutoff wheels, gas in the welder tank, and time on my hands.
Spoke
post Mar 1 2012, 08:19 PM
Post #257
Jerry
Time to repair the driver side interior floor and inner long. The goal is to make the car as tight as possible spending the least amount of money.
The car has a reconstructed title after the wreck (see post #1) and is questionably not worth a whole bunch. The floor and longs should be replaced in their entirety but I will cut out the bad and replace with new steel like I did on the passenger side.
Note the trianglular replacement panel in the bottom. This was done by the PO.
I will continue to rebuild the inner long with panels such as the one shown here in 16ga steel. The PO placed a 16ga panel under the rotted out long and up the outside of the long. I will tie into this with about 2 or 3 of these plates, then cover with an Engmans inner long kit.
The gold flakes are from grinding some braising away.
Not much left of the crossmember. It's going away too.
Note the tie plate on the inner long to the floor. This is braised in and will be removed.
More of the braised plates.
Notice the hole to in the wheel well to the right.
Spoke
post Mar 1 2012, 08:25 PM
Post #258
Jerry
Like the passenger side, the inner long is completely gone all the way along the interior.
Had to remove the E-brake mount.
The E-brake mount is toast. I will cut off the bolt and sleeve and make a new bracket.
Spoke
post Mar 3 2012, 04:11 PM
Post #259
Jerry
Cleaned out the bottom of the long. Prepping for the replacement pieces.
Removed all the rusted pieces and rusted floor.
First replacement piece ready to be welding.
Spoke
post Mar 5 2012, 11:02 PM
Post #260
Jerry
Rebuilding the inner long
- Lo-Fi Version Time is now: 3rd April 2025 - 06:06 PM
