17 Pages V « < 12 13 14 15 16 > »
> Spoke's 71 2.056L 914 Progress Thread, Driving it Like I Stole It
Spoke
post Mar 16 2012, 06:20 AM
Post #261
Jerry
Prep for adding the last inner long piece.
I cleaned up all the tar and rust proofing. The PO had braised the metal in. The new piece will come through the wheel well and attach to the existing 16ga long metal.
The part of the patch to the inside of the wheel well was hiding some ugly rust. How shocking! (IMG:style_emoticons/default/barf.gif)
The new inner long material installed. I ground down as much of the braise on the existing long metal and welded.
Inner long is now solid metal from front to rear.
Spoke
post Mar 16 2012, 06:29 AM
Post #262
Jerry
Fabricated a patch for the drivers side floor.
The channel is raised on the inside and has a piece under the car which is raise to the outside. I decided to weld this bottom piece on the entire length of the channel. I don't think the original bottom piece spanned the entire channel.
The 2 pieces welded together. To protect the inside of the channel brace, I poured cream-colored lacquer that I had laying around which of course overflowed and got on everything.
A pic of the inside of the channel
Welded in place.
Spoke
post Mar 17 2012, 09:30 PM
Post #263
Jerry
OK, so I cut out all the rusted material on the wheel well. The problem is the wheel well piece is a complex piece with several bends. So I will make this 2 pieces; one with the concave bends and tack weld surface with the floor, and the other with the simple flat concave
This is the first piece with the most complexity. I made the tack weld surface and curves then sliced the metal so to make the concave shape.
Ready for welding.
Spoke
post Mar 17 2012, 09:37 PM
Post #264
Jerry
The bottom piece welded in place.
And the upper piece welded into place. Franken914 gets some more stitches and lives yet another day! (IMG:style_emoticons/default/beer.gif)
jaxdream
post Mar 18 2012, 09:08 AM
Post #265
Great work !!!! Keep going !!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
Jack
Spoke
post Mar 24 2012, 08:07 PM
Post #266
Jerry
Driver Floor corner piece.
Instead of drilling holes to "spot" weld, I made slots to weld between.
Installed
Spoke
post Mar 24 2012, 08:20 PM
Post #267
Jerry
I need to replace some of the channels in the floor. I could (and should've) replace the entire floor pan. But then again, I'm a CSOB. I bought enough 18ga metal to do the entire floor for $5 from a local metal shop so I will continue to replace in pieces.
I made channels before by making all the bends one at a time. Quite time consuming. So I made a jig for making the channels. Right now there are 4 pieces:
2 pieces to set the channel width. These mount in a vice and can be adjusted for width.
1 piece to pound the metal into the channel
1 piece to make a channel end.
Here are the channel forms in place.
The channel is formed by pounding on the jig where needed.
For making the channel ends, this piece can be screwed into the channel form.
Spoke
post Mar 24 2012, 08:24 PM
Post #268
Jerry
This piece will finish the floor next to the long. 2 channels terminate in this piece.
Here the piece is ready to weld.
jonferns
post Mar 24 2012, 10:02 PM
Post #269
Great work! (IMG:style_emoticons/default/smilie_pokal.gif)
abnrdo
post Mar 24 2012, 10:34 PM
Post #270
Awesome work! Keep plugging away!! (IMG:style_emoticons/default/smash.gif)
(IMG:style_emoticons/default/welder.gif)
effutuo101
post Mar 25 2012, 07:48 AM
Post #271
Very nice!
Spoke
post Mar 26 2012, 03:14 PM
Post #272
Jerry
The front channel rusted through in a couple of places so I'll replace the entire channel.
Also rusted is the circular plug so I'll replace this with another smaller channel.
Looks like the original.
And welded in.
Spoke
post Mar 31 2012, 08:49 AM
Post #273
Jerry
The floor under the cross brace wasn't rusted through but was thinned, so time to replace it.
New piece ready to go.
Done. More stitches to Franken914.
FourBlades
post Mar 31 2012, 10:09 AM
Post #274
From Wreck to Rockin
Great work. (IMG:style_emoticons/default/smilie_pokal.gif)
Are you a plastic surgeon by any chance? You could make some money in Hollywood... (IMG:style_emoticons/default/smile.gif)
John
Spoke
post Apr 3 2012, 03:06 PM
Post #275
Jerry
Making the driver side crossbrace. Used a 2x3 with an extra piece for the right width. An extra piece makes the bump-out for the parking brake switch.
All trimmed up and ready for welding.
Done.
trojanhorsepower
post Apr 3 2012, 06:23 PM
Post #276
Great work!
Spoke
post Apr 4 2012, 07:54 PM
Post #277
Jerry
Little patch on the footwell
Patch on the inner firewall. This mess will be covered by Engmen's inner long kit.
Spoke
post Apr 8 2012, 07:16 PM
Post #278
Jerry
The back of the floor was pretty much a mess so I replaced the last 2 channels with a new piece. Also completed the brace parallel to the long.
The original handbrake mount was really rusty so I cut off the post and bolt and made a new piece. This is 14ga steel like the original
New handbrake mount welded in.
uncle smokey
post Apr 8 2012, 08:18 PM
Post #279
That is some nice work.
Spoke
post Apr 9 2012, 09:47 AM
Post #280
Jerry
Installed the driver seat mounts. Welded some nuts on the underside of the mounts so I can bolt on the hinges.
For now, I'm using the same hinges that the PO used to support the seat. Welded 2 bolts onto the part attached to the seat runner and 2 bolts will attach the hinges to the mounts.
- Lo-Fi Version Time is now: 3rd April 2025 - 06:06 PM
