914rrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,835 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States ![]() |
SOLD!!!
Package deal: $1950 obo (That's less than $5 per item as a package deal) Contact 865-463-2575 or 914rrr@comcast.net. Pair of NIB Euro taillight lenses Rear floor pan – new – aftermarket w/seat track replacements Longitudinal repair panel – new Longitudinal reinforcement – new Dash units – lower – qty 2 (1 w/vents & 1 w/o vents) 1 front bumper rubber top pad Complete steering housing w/ignition lock, key, wiper switch and turn signal switch Box full of 914 wiring and fuse panel(s) Several washer bottles w/hoses Several exterior door handles Interior door handles w/ covers and rods Pair of 70-74 fog lights Partial 75-76 2.0 injection system 2 mostly complete 73-74 2.0 FI systems OEM Leather steering wheel – needs recovering Tail shifter tranny Rebuilt side shifter tranny Headlight assemblies w/covers, eyebrows, & surrounds Several heater blowers w/single and dual outlets 73-74 OEM 2.0 muffler 3 early interior rearview mirrors Dash w/dash cover installed 3 73-76 engine support bars 2 engine lids with grills 75-76 Bursch muffler 1.7 aftermarket muffler w/hanger bracket 75-76 OEM black basketweave dash face Several interior windshield pillar trim OEM Engine sound deadening pad – nice from low mileage barn find Vacuum and fuel line hoses – New braided fabric style (several feet) Several front and rear brake calipers NEW Front rotors w/bearing, races, and seals installed (never installed) New vent window seal Several new and used keys Several tumblers and tumbler parts Rear deck lock Several pairs of drain funnels w/hoses & gaskets 75-76 bumper snubbers – qty 2 Several front turn signal housing, lenses, & seals (lenses are US, Euro, & Italian) ¼” 5 lug spacers (pair) Several side marker housings w/lenses 4 exterior mirrors Complete gauge cluster w/housing – silver button – 150 mph Several pair of headlight motors and mechanisms New 914 / Early 911 pressure plate 75-76 Bra Colgan Pedal board Misc OEM & aftermarket carpet pieces (black to salt/pepper) Several center console components (Brackets, gauges, frames, center pads, leather shift boots etc) 2 pairs of armrests / door pockets 2 rear decklids (1 rust free w/small dent, 1 is in fair to good condition) Lower front suspension cover plate Pair of aluminum valve covers Several OEM valve covers 2 4cyl fan housings (1 w/flaps) 1 fresh air blower w/housing 2.0 complete gasket set Several new / used cables Several chrome OEM window cranks Several black OEM window cranks Pair of 75-76 black OEM window cranks Several (20+) black nice aftermarket window cranks 12+ valve cover gaskets Several rear trunk top holders – rubber & plastic Several switches w/knobs 3 new oil filters 2 thermostats w/brackets (1 with cable and pulley) Pair of Koni red shocks and springs Several roll bar trim pieces 1 205/50/15 Falcon Azeni tire – new Door thresholds w/trim Distributor w/FI points – OEM – New/rebuilt 71-73 rear chrome bumper – surface rust, no rust through – good core 75-76 HE’s w/ header tubes 73-76 Rain tray – excellent cond Early heater blower w/bracket OEM & aftermarket window / targa bar rubber seals 2 pairs door stops Combo gauge (gas and oil temp) Fresh air vents & flappers Seat belts Motor mounts – new and used – some w/brackets Several wiper motor assemblies Used windshield to top seal / not very old – usable cond Horns 70-74 gas tank w/mounts, filler neck, & rubbers 5 used taillights w/housings – US spec 1 used taillight w/o housing – US spec Pair of new OEM euro taillight lenses 2+ sets of OEM alloy lug bolts 1+ sets of the OEM steel lug nuts Used and rebuilt starters Used and rebuilt alternators 5 914 jacks 3 OEM horn pads 1 targa top w/latches 3rd brake light assembly OEM hoses (longs to dash w/seals) Several ashtrays Early shifter Several heater flappers Several heater tubes & J tubes Complete 2.0 flywheel / clutch assembly – from low mileage engine Lots of lower engine tin (cylinder tin and air deflector tin) Alternator boots 6 speaker grills - factory OEM Several rear alignment shims Tan cotton seat covers w/black piping - like new Repro factory repair manuals 2.0 engine cooling fan (no broken fins) Several relay boards 1 NOS relay board cover Several used relay board covers Front trunk cable with pull handle .....there is more in our garage that we have not listed! Someone will get a great deal! |
Lo-Fi Version | Time is now: 26th June 2024 - 07:52 AM |
