Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,167 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Convert to real 5-lug using 944 CVsThis Article describes how to convert the rear axles on your 914 to give you real 5-lug hubs using a mix of 914, 944 and 911 components. Tools and Supplies:
Step 1: Preparing the axle shafts Remove the CV joints from your old axles and machine both ends of your axle shafts to allow the wider 944 CVs to slide on. You'll have to remove 4mm of material to make up for the wider 944 CVs. 4mm of material removed: ![]() Stock 914 CV on the left and a 944 CV on the right ![]() Step 2: Putting it all together Grease up your new 944 CVs and slide them on the machined axle shaft *without* using the stock spring washer behind the CV! Make sure the CV slides all the way on and don't forget to put the circlip back onto the shaft to prevent the CV from sliding off. Note: Make sure the "groove" on the outside of the new CVs always points away from the axle (see picture with the complete axle). Remove the old stub axles and hub. Remove the old wheel bearings. Install the new wheel bearing in your trailing arms. Make sure the bearing surface on your new hubs is clean and press in the new hubs. Install the new stub axles and tighten the axle nut. Remove the old output flanges from your transmission, replace the seals and slide in the new 911 flanges. Grease up both, the output flange cup and the stub axle cup and install your new axles. Don't forget the CV seals! Tighten everything to spec and enjoy! 911 coarse spline output shaft and 911 stub axle: ![]() 944 CV on 914 axle shaft: ![]() Test fitting the output shaft on the 944 CV: ![]() And at last, the completed axle. The top shows the original 914/4 axle, the bottom shows the new axle: ![]() Mounted on the car: ![]() |
johannes |
Club Porsche 914 France President ![]() ![]() ![]() ![]() Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France ![]() |
Yes, : This goes to the classics (one vote) Congrats, this is a great post ! (IMG:style_emoticons/default/smilie_pokal.gif) |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
Wanna9146 |
Member ![]() ![]() Group: Members Posts: 235 Joined: 19-January 08 From: Florida Member No.: 8,595 Region Association: South East States ![]() |
did i miss something ??? Yes...when are you going to start selling these to those of us who are incapable (or lazy)? (IMG:style_emoticons/default/beerchug.gif) |
rebelmdot |
914ini ![]() ![]() Group: Members Posts: 224 Joined: 25-January 08 From: Tennessee Member No.: 8,625 Region Association: South East States ![]() |
Andy, can you tell me why this is better or more beneficial than the other 5 lug conversions that are on threads here? Thanks. |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Because you don't have to re-drill a 4 hub.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Let this go a few days and make all the edits you want Andy and get it all correct. Then I'll create a tech article.
Richard Casto |
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States ![]() |
Andy,
Thanks for the write up. I will probably be using this exact method on my car. I do have a question. I don't understand the differences in the various transmission output flanges. I am assuming that the course (33 teeth?) flange you mention works with 901/914 transmissions. Does that also work with early 915 transmissions that I think also used a course flange? I think that later 915 transmissions used a fine (43 teeth?) flange. Will this later 915 flange work with this setup? Overall with the 915, I am concerned if the CV still bolts up (hole pattern and bolt size) and about the output flange to stub axle distance (is the distance the same regardless of which transmission and flange you use. In short, will the 914 axle length always be correct) I would like to do exactly as you have described, but with my 914 transmission today and then in the future switch to a 915 transmission with hopefully the only potential change is in the output flange. |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,254 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
I'd add part #'s for the new parts, and spline counts for the output shaft, hubs and stub axles. Also, when machining the drive shaft, how big of a radius can be left on the inside corner (you do not want to have a sharp corner there), and I think I would also round the outside corner so as to remove the sharp edge. Do you require Schnorr washers as well? |
anderssj |
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,732 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region ![]() ![]() |
Great article!
(IMG:style_emoticons/default/agree.gif) It would be helpful to list the actual part numbers under "Tools and Supplies." Looking forward to using this info in the near future. THANKS Andy! |
stephenaki |
Can I get this one dad?? ![]() ![]() ![]() Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None ![]() |
How does this affect the issue with the parking/emergency brake? I understand that the 911 conversion negates the use of the parking brake; does this have the same problem or is it a non issue based on the fact that your not changing out the entire suspension.
Uneducated minds would like to know. |
Richard Casto |
How does this affect the issue with the parking/emergency brake? I understand that the 911 conversion negates the use of the parking brake; does this have the same problem or is it a non issue based on the fact that your not changing out the entire suspension. Uneducated minds would like to know. I believe that e-brake issues are more of a function of moving away from the stock 914 rear caliper than a five lug conversion issue. For example you can do a five lug conversion and use a 914/6 rear caliper ($$$$) as the e-brake solution is the same for all 914 (4 or 6) calipers. But it is common to do a five lug conversion and at the same time move to a 911 (or other) rear caliper that uses a different e-brake solution than the 914 rear caliper does. |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
Andy, nice write up!
I'm going to add a few things here so that it can be found when searching. Andy's method is a great and economical solution for the wimpy 914 CV's. If you are running big horsepower and large sticky tires you "can" go even bigger. It will cost a lot more though. I used course flange 108mm stub axles\CV's that came off the early 911's They are the biggest CV's available that will fit and even larger than the 944's. You can snag the early 911 5 lug stub axles that will bolt right on a 914 as well. (mine were off a 69) To tie it together I bought some Sway-A-Way free floating race axles that can be bought in most any length you desire. Hopefully a bullet-proof system. Sway-A-Way Web Site ![]() ![]() ![]() |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
How does this affect the issue with the parking/emergency brake? I understand that the 911 conversion negates the use of the parking brake; does this have the same problem or is it a non issue based on the fact that your not changing out the entire suspension. Uneducated minds would like to know. I believe that e-brake issues are more of a function of moving away from the stock 914 rear caliper than a five lug conversion issue. For example you can do a five lug conversion and use a 914/6 rear caliper ($$$$) as the e-brake solution is the same for all 914 (4 or 6) calipers. But it is common to do a five lug conversion and at the same time move to a 911 (or other) rear caliper that uses a different e-brake solution than the 914 rear caliper does. This mod has nothing to do with brakes. That would be another topic. One BIG benefit is that you can still buy NEW 944 CV joints, and they should hold up better with more power. One can still use 4-cyl rear calipers with 914-6 rear rotors, or one could have 4-cyl rear rotors drilled for 5-lug. Andy, Please post Part numbers of the transmission output flanges as these seem to be the item I have the greatest difficulty in obtaining. Thanks |
stephenaki |
I believe that e-brake issues are more of a function of moving away from the stock 914 rear caliper than a five lug conversion issue. For example you can do a five lug conversion and use a 914/6 rear caliper ($$$$) as the e-brake solution is the same for all 914 (4 or 6) calipers. But it is common to do a five lug conversion and at the same time move to a 911 (or other) rear caliper that uses a different e-brake solution than the 914 rear caliper does. OK, got it. My assumption is, correct me if it is wrong, that if I were to do Andy's conversion I would have to re-do the rear brakes or would the stock 914/4 system work with this conversion? Understand the stopping power is reduced with bigger wheels but if your not racing the car or increasing the power is it required to convert the brakes? I am still a novice at this so am trying to learn as I go along. |
Richard Casto |
I believe that e-brake issues are more of a function of moving away from the stock 914 rear caliper than a five lug conversion issue. For example you can do a five lug conversion and use a 914/6 rear caliper ($$$$) as the e-brake solution is the same for all 914 (4 or 6) calipers. But it is common to do a five lug conversion and at the same time move to a 911 (or other) rear caliper that uses a different e-brake solution than the 914 rear caliper does. OK, got it. My assumption is, correct me if it is wrong, that if I were to do Andy's conversion I would have to re-do the rear brakes or would the stock 914/4 system work with this conversion? One can still use 4-cyl rear calipers with 914-6 rear rotors, or one could have 4-cyl rear rotors drilled for 5-lug. I think John's point above answers your question. Doing the CV and 5 lug conversion does not require you to re-do your rear calipers. You will need to use rotors that have five lugs (either the 914/6 rotors or re-drill the 914/4 rotors) |
Wes V |
Member ![]() ![]() Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 ![]() |
First off, thanks!!
Requested additions; 1. I'd recommend verifying run-out of the of the hub prior to installing. Put it in a lath and use a dial indicator (while rotating the hub by hand). If the source car was in an accident, the hub could be bent and you may not see it by eye. If you don't notice it until installed, you will have to buy new bearings when you replace it with a good one. (BTDT) 2. CV bolts should be replaced with longer ones to match the 944's wider width. It may be recommended to use grade 8 bolts that allow safety wire. At least, locktite the bolts. 3. For us newbies, the 100mm reference is the outside diameter of the CV, not the bolt circle. Of course, that's if that's correct. Wes |
Steve Thacker |
UMMMPH Yea Baby Yea ! UMMMPH ![]() ![]() ![]() Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest ![]() |
Andy,
You have outdone yourself again. I wish I was your next door neighbor. I'd be one smart fucher with these cars. (IMG:style_emoticons/default/aktion035.gif) |
stephenaki |
I think John's point above answers your question. Doing the CV and 5 lug conversion does not require you to re-do your rear calipers. You will need to use rotors that have five lugs (either the 914/6 rotors or re-drill the 914/4 rotors) OOPs, I obviously missed that. |
Lo-Fi Version | Time is now: 31st March 2025 - 03:48 PM |
