5 Pages V « < 2 3 4 5 >
> engine shroud and alternator on a /6, removal in the car
krk
post Feb 10 2004, 09:45 AM
Post #61
I noticed you had a carbon fiber one on one of the cars -- meant to ask you about that. Mind you, I was a lot more enthusiastic about the idea before I started this bit of silliness -- I'll be reluctant to remove it anytime soon (and certainly not for one with that much work to fit)!
It's getting light outside -- can I start again now? (IMG:style_emoticons/default/laugh.gif) (actually not -- it got below 40F here last night so "it's cold out there campers!")
kim.
krk
post Feb 10 2004, 06:29 PM
Post #62
So I took a couple of hours of this afternoon -- weather is just too darn nice to let go. Finding and installing all of the shroud screws was a bit of fun. Had 4 left over at one point. Then down to 1. Got them all in finally and tightened it down.
Intake manifolds went on easy, as well as other bits of things (some trippy throttle manipulator that's likely a smog device of some kind -- vacuum line, plus two wires.)
I'm hooking up the last bits of electrical and I find I didn't shoot a pic of the coil wiring. In particular, there is a brown wire on the negative side of the coil that has to go somewhere. Anyone got a clue for me?
(after that, it's on to carbs/linkage/etc)
kim.
krk
post Feb 10 2004, 07:12 PM
Post #63
QUOTE(krk @ Feb 10 2004, 04:29 PM)
It goes back to the post on the alternator fan housing.
kim.
Gint
post Feb 10 2004, 08:53 PM
Post #64
Mike Ginter
You got it. It's a ground wire.
krk
post Feb 10 2004, 09:20 PM
Post #65
So at the end of a long day, there's good news and bad.
The good news. Got everything reassembled, and with a fully charged battery, the machine came back to life. (to me this was a minor miracle -- I haven't done this much reassembly in some time...) The wiring seems correct.
And it runs. (Gint, brake cleaner on exhaust stinks -- but it did work really well -- I'll post pics later)
And it now has an exhaust leak it's never had before. (how can a sitting car on its sorry butt acquire an exhaust leak? too much effort to smile in the morning as I rust? must be spite)
One of the carbs leaks at the accelerator pump. I guessedI would have to revisit the miserable suckers, so that wasn't that much of a surprise. I have complete carb kits, but I wanted to find out if the charging problem was solved, and I wanted to see how the jetting worked before ripping them to bits. Most of this was trial anyway -- tho I really don't wanna take that frik'n schroud off again.
But here's the real ugly part -- the original problem continues to exist. The alternator light does not come off at any rpm. I suppose I could have something wrong that blew up a perfectly good alternator -- clues welcomed! -- but other than that, it seems the problem may be elsewhere.
I'll look at it again in the morning.
But thanks (IMG:style_emoticons/default/smilie_pokal.gif) for all your help! There's no way I'd have got this far flying solo.
kim.
Gint
post Feb 10 2004, 10:09 PM
Post #66
Mike Ginter
Ouch. (IMG:style_emoticons/default/smash.gif)
Gint
post Feb 10 2004, 10:11 PM
Post #67
Mike Ginter
What exactly was the original problem? Other than the light being on?
krk
post Feb 10 2004, 11:31 PM
Post #68
Alternator light never goes off. At any rpm.
kim.
krk
post Feb 10 2004, 11:34 PM
Post #69
That was 2 degrees too glib. Grotty bits are detailed here:
http://www.914world.com/bbs2/index.php?act...ltage+regulator
kim.
Gint
post Feb 11 2004, 07:24 AM
Post #70
Mike Ginter
"glibass" (IMG:style_emoticons/default/laugh.gif) Thanks for the refresher link.
Now I remember (he says after reading the full description - again). Sorry I'm not an automotive electrical genius. Have you asked your alternator vendor (Auto Lectrics, Campbell) about your symptoms? They're in the business apparently; they might have some valuable insight.
I did pull a Bosch reman alternator out of my step-son's Cherokeee last night though (from underneath the car). Not quite as much fun as your job was, but it wasn't pretty either either.
ArtechnikA
post Feb 11 2004, 07:41 AM
Post #71
rich herzog
QUOTE(krk @ Feb 10 2004, 07:20 PM)
(how can a sitting car on its sorry butt acquire an exhaust leak?...)
rust never sleeps...
krk
post Feb 11 2004, 09:13 AM
Post #72
QUOTE(ArtechnikA @ Feb 11 2004, 05:41 AM)
Heh. It's funny. Apparently rust (and this car) are active i my dream state too. I woke up minutes ago thinking "you don't suppose that the brake cleaner that I put down the oil cleaner could have leached over to the end of the exhaust manifold and munched part of a gasket or something?"
Wadda ya think? Should I just go back to bed now? (IMG:style_emoticons/default/laugh.gif)
kim.
Eric_Shea
post Feb 11 2004, 09:26 AM
Post #73
PMB Performance
Blown diods (sic) from misc. reverse current?
You coming tonight?
krk
post Feb 11 2004, 09:31 AM
Post #74
QUOTE(Eric_Shea @ Feb 11 2004, 07:26 AM)
You coming tonight?
Possible -- I'm thinking that I should check the fan belt once it warms up a bit outside. If it's not on right (or at all) or too loose, it ain't gonna turn the alternator up to speed. (I should have thought of that last night -- could have checked then)
re: tonight -- don't know. Right now, i don't have a car/ride to get there.
kim.
Eric_Shea
post Feb 11 2004, 09:35 AM
Post #75
PMB Performance
How far from the San Mateo Marriott?
krk
post Feb 11 2004, 09:40 AM
Post #76
QUOTE(Eric_Shea @ Feb 11 2004, 07:35 AM)
In traffic, prolly 45 min give or take. But it's due south, directly away from The City™ which is probably an hour + back in traffic.
kim.
krk
post Feb 11 2004, 01:18 PM
Post #77
QUOTE(krk @ Feb 11 2004, 07:31 AM)
You coming tonight?
Some good news. I hosed the install of the fan belt. With the fan belt in and at appropriate tension, the alternator works fine, and the charging light behaves appropriately!
So the car starts and runs. The passenger side carb leaks gas like a good friend of an oil producing nation -- it's more than the little drips around the accelerator pump cover. I expected to redo them anyway -- I was mostly interested in seeing if the initial jetting/etc would at least work for a while. I'll work on buttoning them up next.
The car sounds good. I've not even played with the synchrometer/etc at all, so I'm sure things are out of balance, but even then, it sounds way better than before.
On the exhaust leak, I'm not sure. I'd forgotten all the interesting noises that webers make on a running car. heh. The noise sounds like a leak, but it is not there on start up -- only after the car warms up a bit.
kim.
Gint
post Feb 11 2004, 10:21 PM
Post #78
Mike Ginter
Nice work Kim.
I can't wait to hear that in my own garage.
krk
post Feb 11 2004, 10:49 PM
Post #79
You want my car? After all this high quality mechanical attention? [I'm thinking we should have fed you the beer (IMG:style_emoticons/default/laugh.gif)]
kim.
Gint
post Feb 11 2004, 10:53 PM
Post #80
Mike Ginter
I've finally learned my lesson (Ha!). One is plenty, thanks.
- Lo-Fi Version Time is now: 2nd April 2025 - 11:37 PM
