28 Pages V « < 3 4 5 6 7 > »
> 3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds
jasons
post Jul 28 2008, 07:24 PM
Post #81
Jackstand Extraordinaire
You know, I hate to meddle with your paint choices after you've already started but....
That intake looks bitchin in raw Al. Reminds me of something you would see on a vintage aircraft. And, I would do the valve cover in red wrinkle coat. Like the Maserati Spyder...
3d914
post Aug 1 2008, 05:07 PM
Post #82
Jason,
I agree - that wrinkle affect looks cool. I'll have to save that idea for next time though - too far along to backup now.
3d914
post Aug 2 2008, 01:53 PM
Post #83
Still workin on the intake manifold. I removed the intake runners and noticed that they would look much better with the casting seams removed. So I dug out the Dremel with the course sanding disk and went to work. Once I got the seam flat I used a file to feather and contour.
Went from this . . .
To this . . .
I still have to have these media blasted to remove the paint, but I have done a little sanding on them. The paint on these is thicker than the paint on the valve covers - for whatever reason.
Eric_Shea
post Aug 2 2008, 10:56 PM
Post #84
PMB Performance
When I was in the SHO club there were some guys who had theirs polished... talk about a dramatic effect.
3d914
post Aug 4 2008, 10:15 PM
Post #85
Definitely. Here are some examples . . .
SHO Bling . . .
Purty (IMG:style_emoticons/default/aktion035.gif)
3d914
post Aug 30 2008, 12:03 AM
Post #86
OK, I know there hasn't been much action here lately . . .
because its tooo dannggg HOTTTTT.
I am getting a few things done on the weekends. Pics to come when I have something together.
Stay cool!
charliew
post Aug 30 2008, 10:18 PM
Post #87
Good thread, lots of hard work, I don't know how you can work in the heat. I am retired and last summer I would work early in the morning till about 12 noon then clean up and eat and take a siesta and go back out at 7pm and work till 12 or 1 am. It worked pretty well except that you gotta have good lights and the painting must be in the early morning or it will get bugs in it. I also use a few big fans. Of course the fans gotta be off to weld.
Practise a lot with the scrap body metal before you try to put the repair panel in. You said the body metal is 16 ga. but I'm pretty sure it's thinner than that. It's probably 18 ga. Spot weld about 1 inch apart and keep going around the panel if it gets too hot to touch do something else and let it cool. You can buy the little butt weld gadgets at HF. I use a thick piece of copper to back the weld up if I can get it in position. Eastwood has a magnetic copper strip but it's not cheap.
My experience with pop rivets are they will show up later as little circles no matter what you put over them. After you get the fiberglass bonded to your satisfaction, drill them out and fill the area over with fiberglass strand. I haven't tried it but the product Kitty Hair, made by Evercoat, is a bondo type putty with fiber strands in it. There is also one by the same company that has short strands it probably will be easier to use, the long strands are harder to work with. They are both waterproof. I use them both but I haven't had to deal with pop rivets lately.
On the rotisserie I thought the practice was to brace the door gap to keep the tub from sagging as now the support is on the very ends not at the suspension where the tub was designed to be supported. I guess if the door gaps haven't changed it's ok, although it would be something if the fenders are stressed at the front and rear and you do all the body work and they relax when you take it off the rotisserie.
My experience with painting aluminium motor parts is that unless they are bead or sand blasted and painted with a epoxy paint it doesn't stick very well.
Good luck you are really working hard, I'm sure you will be proud of the finished product.
Isn't car life full of lessons?
3d914
post Sep 5 2008, 08:24 PM
Post #88
Charlie,
Thanks for the insights. Things have been progressing very slowly the last few weeks. On top of the heat, I now spend 4 hours at school a couple of nights, and reading/homework a couple more nights. But at least its time spent indoors - cool!
You're correct on the sheet metal - mostly 18 & 20ga in a few spots.
I've been trying to finalize my trunk and get it at least primered. The shop doing the final paint work suggested a self-etching primer to protect the bare metal. So now that I have most the paint off, I'm just cleaning up some areas of surface rust in the trunk, prepping down to bare metal, cleaning & treating with Metal Ready, then shooting with a couple lite coats of primer. Took eleven hours over two days last weekend just to get 1/3 of the trunk done.
Once I get the entire trunk to that point, then I'll move on to the sheet metal. I bought some other replacement/add-on panels, so I've got to start focusing on welding again. And then there's the hell-hole that I have to investigate.
Regarding the rotisserie; I still have my doors installed in order to maintain integrity. I also left the suspension in tact so that I can lower it as needed to do a couple of body cuts that shouldn't be done in the air.
I managed to get the aluminum manifold welded, so now I just need to finish up the metal work, blast it and get it ready to paint.
No work on the teener this weekend though - my son is in for the weekend from college - so I get to spend some time with him & working on his car.
PS: You're right about the lessons. I keep looking for them.
Eric_Shea
post Sep 5 2008, 08:51 PM
Post #89
PMB Performance
School Schmool... get ta work on that car. I want a ride! (IMG:style_emoticons/default/w00t.gif)
3d914
post Nov 2 2008, 09:33 PM
Post #90
OK, finally the engine is going together. He's where my list is at compared to a couple months back.
Engine rebuild . . .
  • Cleaned and painted the oil pan
  • Cleaned and painted the block
  • Cleaned the heads and valve covers
  • Cleaned and painted the valve covers
  • Modified and welded the intake manifold
  • Cleaned and painted the intake manifold
  • Cleaned and painted the intake runners
  • Had the heads professionally cleaned and decked
  • Replaced numerous freeze block plugs
Now that reassembly has begun, it should be done in three or four weekends. Of course I still have numerous parts to gather or recondition (water pump, some sensors, exhaust, etc).
To say I'm glad to have reached this point is an understatement. I'm glad I'm not on a schedule.
Here's a picture of the current status. Once I find the head bolts I can continue . . .
3d914
post Nov 16 2008, 09:34 PM
Post #91
OK, got some more done on the engine this weekend - thanks Tom!
Heads are on & valve covers are just sitting there waiting to put the seal/gasket on.
The crank position sensor is mounted and gapped.
A remanufactured waterpump Tom had available is also installed, along with the main tubing and housings for the head cooling.
Here are the pics so far:
Purtty,
So.Cal.914
post Nov 16 2008, 09:51 PM
Post #92
"...And it has a front trunk too."
Did you swap in 3.0 cams?
rick 918-S
post Nov 17 2008, 08:39 AM
Post #93
Hey nice rack! -Celette
Wow, that's a tall oil pan. You may need to shorten it. Have you test fit this in the car? Nice looking engine! (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/popcorn[1].gif)
3d914
post Nov 17 2008, 12:07 PM
Post #94
No 3.0 cams. I think the stock 3.2 is going to be more than enough to start with. And I can always upgrade - right?
I've done a test fit via CAD. The oil pan is low, but it won't sit more than 1/2" below the bottom of the rear firewall. You can see my layout on a previous page.
Once I get the intake on it will look even bigger. Once engine is running, I'll have to pull the intake off again to get the engine in from underneath, then install the intake from the top.
It'll be interesting . . .
3d914
post Jan 10 2009, 01:41 PM
Post #95
OK - latest progress.
The engine build continues. Did a valve-adjustment on new years eve, and have numerous plastic covers cleaned, painted, and ready to install. New engine pics coming when I get it all buttoned up.
Next issue I've been playing with is the intake. The huge, but cool, intake manifold on the SHO requires an equally large throttle body that is preceded by a MAF sensor.
So the dilemma for me has been how to route the intake air from the engine lid to the throttle body without giving up my entire trunk. Here's a couple of things to keep in mind:
  1. This is a custom 914, not a restoration!
  2. Throttle body points to the rear and extends slightly above the rear trunk lid. A fiberglass cover will be made for this.
  3. The inake diameter into the MAF sensor is 3.0 inches
  4. The output diameter of the MAF sensor is 3.5 inches.
  5. I plan to change the trunk hinging so trunk opens from the front.
  6. I don't want to loose the trunk completely. This still needs to be a weekend cruiser.
So here are three variations I've come up with for the intake. I've modeled them in 3D just roughly to get an idea of how each will look. Thanks Mark for the base 914 surface model.
Over the Top
This method routes the intake from each side of the engine lid, through filters, then back up and over to the center, where they meet at the MAF sensor, then curves down to the throttle body.
Side Run
This method routes the intake from each side of the engine lid, through filters, then directly rear through the trunk wall, over to the center and to the MAF sensor, then slightly up and into the throttle body.
Down the Middle
This method requires a custom pedestal in the center to mount a wing. The pedestal will house the air filter and box to blend to the 3.5 inch outlet needed on the input side of the MAF sensor. The intake and MAF will route directly down the center into the throttle body. Most of this should stay hidden under the trunk lid, although a custom cover will still be needed for the throttle body itself.
Thoughts? Comments?
Eric_Shea
post Jan 11 2009, 12:56 PM
Post #96
PMB Performance
Side = Clean
Todd Enlund
post Jan 11 2009, 01:00 PM
Post #97
Resident Photoshop Guru
QUOTE(Eric_Shea @ Jan 11 2009, 10:56 AM) *
Side = Clean
3d914
post Jan 18 2009, 04:01 PM
Post #98
A lot of time has gone by, but progress continues slowly. Here is the pre-assembly of the famous SHO Intake Manifold. I've been taking my time making sure everything is fitting together properly.
(Here are two pics. For some reason the yellow gets washed out in the sun)
Since the wiring harness sits under the intake between the fuel injector rails, I have a lot of work to do on the harness. I got it cleaned up & removed all the old dried out tape and insulator. Some lines will need to be extended for my application so all that will get done before the test run.
More to follow . . .
gopack
post Jan 18 2009, 04:19 PM
Post #99
CHEESEHEAD in CA, MARK
I think the down the middle is the most direct, and elegant approach. with a minimum of bends you dont have to worry about any pesky flow dynamics, and you know it will be a more laminar charge. also if the pedistal faces fron, it will be RAM AIR!
3d914
post Jan 26 2009, 05:04 PM
Post #100
Mark,
Sorry to see you're selling your project. I'll be relying on your current project thread for some insight into the typical body mods (hell-hole, flare fit with rockers & valances, etc). Don't stray far from the group - gotta keep that 914 fever!
Best of luck,
- Lo-Fi Version Time is now: 20th April 2025 - 02:35 AM
