Electrical connectors, Spade or bullet |
spunone |
Apr 2 2008, 02:43 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
On electrical connections which one works best for hooking up MSD boxes and such. Thanks
sww914 |
Apr 2 2008, 02:49 PM
I prefer spades, they work well and seem to be cheaper. A multi-pin connector would be better, if you can get both sides at your FLAPS.
jcd914 |
Apr 2 2008, 03:14 PM
I am partial to spade connectors as well. I think it is related to all the cr*p stereo wiring I had to deal with from the stereo store installers and they were always cheap, poorly crimped bullet connectors.
I prefer bare copper/brass that use the factory style 'W' crimp and shrink wrap and/or multi-pin plugs. Jim |
Apr 2 2008, 04:33 PM
Resident German Group: Admin Posts: 41,714 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
A multi-pin connector would be better (IMG:style_emoticons/default/agree.gif) here's what i used for my gauges ... (IMG:style_emoticons/default/bye1.gif) Andy |
geniusanthony |
Apr 3 2008, 01:30 PM
Its a brand new "Chrome-sicle" Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
I would think the situation itself should dictate, most important thing to consider is power handling. An MSD box will surely draw more power than say, Andy's gauge pack. Undersized or under-rated connections could be fire hazards or at least failure points.
Apr 3 2008, 01:44 PM
Undersized or under-rated connections could be fire hazards or at least failure points. (IMG:style_emoticons/default/agree.gif) make sure whatever you use has an adequate power rating for your application ... (IMG:style_emoticons/default/blowup.gif) Andy |
Mark Henry |
Apr 3 2008, 02:28 PM
I use a terminal block and ring connectors on all my engine hook-ups, looks pro, I colour code and its fast to un-hook all your wiring.
The big trick is to use a real good crimping tool. |
spunone |
Apr 3 2008, 02:35 PM
Heh Mark That sounds pretty cool got any pics? should work well with multi wire connections (IMG:style_emoticons/default/beer.gif)
geniusanthony |
Apr 3 2008, 02:59 PM
For these (semi)permanent connections, does anyone use solder in addition to these connectors? It seems as though one should, maybe add a little heat-shrink also.?
jcd914 |
Apr 3 2008, 04:25 PM
For these (semi)permanent connections, does anyone use solder in addition to these connectors? It seems as though one should, maybe add a little heat-shrink also.? I am sure some have strong opinions on solder VS crimp connections, I have seen long threads on other sites. I prefer to stay away from solder in general wiring for automotive use. A good crimp will have very close to the same electrical conductivity as a solder connection and most automotive systems will not be affected by the minor difference. With a soldered connection there is almost always some wicking of the solder up the wire that makes the wire stiff. Vibrations and movement in an automotive application can cause the wire strands to fail at this point in the wire. Soldering takes extra time, I don't see any advantage to the soldered connection and an increased chance of failure is means I will crimp my connections. Jim Low voltage, low impedance, electronics are probably and exception to this. |
Mark Henry |
Apr 3 2008, 05:00 PM
Heh Mark That sounds pretty cool got any pics? should work well with multi wire connections (IMG:style_emoticons/default/beer.gif) Sorry both of my cars (with this) are in storage and 50 miles away. This is the terminal block http://www.radioshack.com/product/index.js...rentPage=search It does 8 connections but can be cut down smaller with a hacksaw, don't over torque the screws when you mount it. Small ring connectors from the FLAPS will need to be filed a hair to fit and I take the plastic cover off them so they look sort of stock. I colour code the wires and shrink wrap them. The whole harness stays on the engine when I drop it. BTW My 67 bus has a 75amp alt. and I run it thru this block with no problem...even though it says 15 amp on the ratshack site.(IMG:style_emoticons/default/laugh.gif) |
blitZ |
Apr 3 2008, 05:10 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I like to tin the wire ends with solder prior to crimping the connector. Makes for a solid connection and is less likely to pull out.
Mark Henry |
Apr 3 2008, 05:21 PM
I like to tin the wire ends with solder prior to crimping the connector. Makes for a solid connection and is less likely to pull out. You shouldn't need to tin the ends if you use a good crimper, I think mine were around $80. The cheapos are crap...may as well use a pair of vicegrips. |
McMark |
Apr 3 2008, 08:25 PM
I use a double crimp connector. One crimp connects the wire to the spade, the other crimp grabs the insulation to keep it from working loose. Then I heat shrink everything. I LOATHE the blue/yellow/red plastic connectors. Nothing says "HACK JOB!" like those pieces of crap. (IMG:style_emoticons/default/barf.gif)
Sorry for the crap picture. (IMG:style_emoticons/default/dry.gif) Attached image(s) |
mightyohm |
Apr 3 2008, 08:37 PM
I agree with Mark.
You can get a lot of neat stuff from Waytek - www.waytekwire.com You can go a long way with a decent crimper like the Thomas and Betts WT111M, a handful of noninsulated crimp terminals (I like the spade or faston type) and some heatshrink tubing. You can actually pull the colored insulation off of the cheap crimp terminals you see at hardware stores and then use a good crimper to crimp them on REAL good. The crimper that you see sold at Radio Shack or OSH that is stamped and can cut and strip wires, crimp 10 different kinds of connectors, and make french fries is crap! Mark is showing what is called an open barrel connector, you can get them from Waytek, they call them relay terminals. You'll need yet another special tool, the blue handled one that Mark shows, also available from Waytek. (#491 I think?) I'm doing a big thing about crimping and making wiring harnesses at this year's Maker Faire (see my sig), check it out if you want to learn more. (IMG:style_emoticons/default/biggrin.gif) |
McMark |
Apr 5 2008, 02:18 PM
I had to make another connector, so I took better pictures.
mightyohm |
Apr 5 2008, 02:56 PM
Nice!
I am guilty of using the cheesy red/blue/yellow terminals if it's in an area where heatshrink would be hard - like if the heatgun would melt surrounding parts. On my back under the dash I usually use whatever is easiest. (IMG:style_emoticons/default/biggrin.gif) |
SGB |
Apr 5 2008, 04:29 PM
Nice! I am guilty of using the cheesy red/blue/yellow terminals if it's in an area where heatshrink would be hard - like if the heatgun would melt surrounding parts. On my back under the dash I usually use whatever is easiest. (IMG:style_emoticons/default/biggrin.gif) Yeah, me too. "Maker Faire" sounds cool- except the name-e. |
bperry |
Apr 6 2008, 01:25 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
Nice! I am guilty of using the cheesy red/blue/yellow terminals if it's in an area where heatshrink would be hard - like if the heatgun would melt surrounding parts. On my back under the dash I usually use whatever is easiest. (IMG:style_emoticons/default/biggrin.gif) I can't imagine anywhere on a car where the heat needed to shrink properly sized heatshrink tubing would melt anything surrounding it. It doesn't take that much heat to shrink the stuff. Worst case, and I have used this often, is to use a cigarette lighter (actually I use a BBQ grill lighter with the long snout) and quickly pass it under/around the desired area. As long as you don't linger and do it in multiple passes with a delay between passes, all that will be necessary is to wipe off a bit of black carbon left by the smoke. In a pinch even a match works. The key is to use the proper sized tubing and only the minimum amount of heat needed and apply the heat in multiple passes. I've done this for decades and never had an issue melting surrounding components. --- bill |
Slider |
Apr 7 2008, 06:16 AM
Problems are like cockroaches you find 1 and theres a 100 more Group: Members Posts: 223 Joined: 11-March 07 From: Fort Collins Colorado Member No.: 7,591 Region Association: Rocky Mountains |
Remember if you Solder the wire right the wicking will be minimal. a lot of people use surgical clamps ..clamped at the insulation to help dissipate the heat
Lo-Fi Version | Time is now: 2nd July 2024 - 07:04 PM |
