stateofidleness |
Senior Member ![]() ![]() ![]() Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None ![]() |
so i have a dumb question.. i have my engine torn down to the heads and case and was my cylinders (i think) are kinda rusty (the little fins on it)
if i wanted to get a new cylinder/piston kit yada yada... can i get a "big bore" 96mm kit? I didn't know if going with the big kit would require any modifying of the heads or case or something.. or if it would "bolt up" just like the stock parts. pardon the noobness (IMG:style_emoticons/default/smile.gif) |
anthony |
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 ![]() ![]() |
Based on that I would recommend not taking the heads off and just putting the engine back in the car after welding. New rubber hoses, fuel lines, and stuff is great. You might also want to do new motor mounts. The ones near the engine are cheap and much easier to get to when the engine is out. The rear mounts on the tranny can be replaced with 911 "sport" mounts. Aftermarket ones usually costs $35/each whereas 914 mounts cost like $70/each.
stateofidleness |
one step ahead of ya.. got all new mounts installed already!
thanks anthony! |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
New o-rings on the push rod tubes is easy at this point definately worth doing.
Rear main seal and front crank seal. new valve cover gaskets and exhaust port copper seals. I would carefully check head torque and adjust valves Button it up and put it back in. Shift bushing at the fire wall before engine install. |
Lo-Fi Version | Time is now: 24th June 2024 - 05:54 AM |
