J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
This jack is no good. I know because I have one. Since the bottle jack portion doesn't move it gets in the way of the transmission. Well golly, that's a big problem (IMG:style_emoticons/default/huh.gif) . Attached thumbnail(s) ![]() |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
haHA! Foiled.
spunone |
Senior Member ![]() ![]() ![]() Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California ![]() |
I have a atv -motorcycle Jack iffin ya need one to use
okieflyr |
9fauxteen ![]() ![]() ![]() Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States ![]() |
Here's How mine went in.... 495lbs I used square tubing for temp bridge/balance.
Like Travis, I'd preffer the motorcycle style jack. But I run what I brung... Attached image(s) ![]() |
TravisNeff |
So the only catch is to have the whole car in the air vs. just the rear.
J P Stein |
On the occasion of that pic, I took the engine off the stand with the ATV jack, bolted the trans in place, then loaded it into the car in the space of 4-5 hours....by my self. Anyone that use a bulkhead mount for a 6 comes to appreciate the stability and fine height adjustments of this jack. Getting the front mounts lined up can be a real bear. This time things went very well.....but I've had practice. (IMG:style_emoticons/default/biggrin.gif)
Yes, having the whole car up and 2-3 inches down by the nose makes things easier. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:46 PM |
