Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,038 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Shit! I just realized I need to put a return line on the tank (IMG:style_emoticons/default/dry.gif) This means draining, pulling it, getting some dry ice to evacuate the fumes, welding in a bung, and re-installing the tank. I think I just hit my limit.....
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
Dry ice? If only you had a friend with a kegerator. He could bring over a bottle of CO2.
Dr Evil |
I have CO2/Argon, but would rather just get some cheap ice (IMG:style_emoticons/default/wink.gif)
Dr Evil |
I just submitted the list of parts for the fuel system. It is gonna look PIMP when I am done (IMG:style_emoticons/default/biggrin.gif)
I hope to still get it finished. I think I will start to pull the tank tomorrow. |
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
Thanks for not using capital T's on "the tank".
Get at it! |
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
I didn't bother to read any of this. But I like those blue things. They're cool. (IMG:style_emoticons/default/thumb3d.gif) Scotty's paint is holdin' up pretty good too . . looks like. |
Dr Evil |
Man, who invited the canucks?
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
Nice skittles Dr Mike. See if you can attend the Aircooled Fest, in Sept this year. Located in Flanders NJ. It's a great time. Alot of the folks camp over nite.
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Nice skittles Dr Mike. See if you can attend the Aircooled Fest, in Sept this year. Located in Flanders NJ. It's a great time. Alot of the folks camp over nite. NO MIKE. Stay away form the skittles, and for God's sake do NOT wear a hoodie. As for the canucks, they're never invited, they just invade.........ish |
Dr Evil |
I am not sure where to source a nipple for the return fitting on the tank, any ideas? (IMG:style_emoticons/default/confused24.gif)
scotty b |
I am not sure where to source a nipple for the return fitting on the tank, any ideas? (IMG:style_emoticons/default/confused24.gif) a junkyard tank ? |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,927 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Hey, your running a power glide right? You should see about installing a lockup converter. Your mileage would be enhanced on the highway.
crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,830 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
ha ha, nipple, ha ha funny
Dr Evil |
Junk yard tank is not in the cards. I wont have time. Any other ideas?
What is a "lock up converter"? Yes I am running a PG with a posi and rebuilt TC. Herb, I figured someone would say something about the nipple, but I expected better from you (IMG:style_emoticons/default/rolleyes.gif) |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,812 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
One of the local body shops used to use carbon monoxide to weld gas tanks. They'd hook up one of those flexible rubber exhaust hoses to the filler neck and to a running car, let it run until the fuel tank got good and hot, then weld 'er up.
rick 918-S |
Locks up at cruising speed for a direct drive like a clutch. No slippy and loss in mileage due to the engine not delivering all the rotation to the rear wheels. My understanding is it turns the hydrulic coupling into a mechanical coupling. Drag cars use them and many of the GM line had them from the factory starting the the 80's I think. I think some of them were called switch pitch or something like that. I would think it could really benifit a big van.
d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,349 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
I have one on my 1990 454... its good for an additional 200 rpm loss at highway speeds.. For my 454 that a big thing!! acts like an overdrive to a point..
Dr Evil |
No locking TC for my box. Not that I could find, but thanks for giving me a desire to upgrade even more (IMG:style_emoticons/default/tongue.gif)
Injectors arrived today. |
Dr Evil |
Well, the tank is out. I had to lower the engine to do it (IMG:style_emoticons/default/headbang.gif)
Actually, not all the way. I did have a stroke.....of genius while looking around at the auto parts store. I am going to take a small section of plate, tap it for 1/4" NPT, cut a hole in the tank, weld in the plate, and install some npt-nipples (IMG:style_emoticons/default/smile.gif) This will be done tonight, I hope. I didnt feel like searching out dry ice so I will just flood it with argon/CO2 from my weld tank. I have a huge Argon tank right now. |
MDG |
Herb, I figured someone would say something about the nipple, but I expected better from you (IMG:style_emoticons/default/rolleyes.gif) heh . . heh . . the Doc said nipple. Again. |
Lo-Fi Version | Time is now: 21st April 2025 - 08:23 PM |
