wingnut86 |
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States ![]() |
BooYAH! Mike (IMG:style_emoticons/default/beer.gif)
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,055 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Awesome Dr Mike! Sounds very 911ish. Just noticed how fat (and phat) your wheels are. Those look wider than stock... (IMG:style_emoticons/default/confused24.gif) I'm too lazy to comb through the 76 pages and find out for sure. (IMG:style_emoticons/default/piratenanner.gif)
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,038 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Special 15" ( or 16, I forget) wheels with truck tires on them.
Dr Evil |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
flippa |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,179 Joined: 7-May 07 From: Boston, MA Member No.: 7,720 Region Association: North East States ![]() |
That's killer Mike! (IMG:style_emoticons/default/smilie_pokal.gif)
Dr Evil |
Just took it for a drive! It hauls ASS! It has good stable power up to 3.5K, then it really throws you back into the seat (IMG:style_emoticons/default/smile.gif)
However, it will not shift out of first. I may have the vac hose hooked up to the wrong spot. I need to check on this tomorrow. I hope to have it inspected tomorrow, then I will be legal. |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,717 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Just in time for me to get there! PERFECT!
Dr Evil |
Just passed inspection! Woot! Still not shifting into 2nd, but I can figure that out.
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,466 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Just passed inspection! Woot! Still not shifting into 2nd, but I can figure that out. I love it! Dr. Evil with a tranny stuck in first (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Dr Evil |
I was just going through the manual and I think I have a misadjuted low band. I did rebuild the tranz, and I thought I adjusted it correctly, but it is a place to look. It is a weird method:
- First you tq the adjuster to 40 in/lb - Then you back off EXACTLY 4 full turns Simple enough. |
Dr Evil |
Well, now it is acting up and pissing fluid on the driveway. (IMG:style_emoticons/default/dry.gif) Break time.
Dr Evil |
I talked with a corvair guru today to help focus my thoughts and he made some valid points that talked me out of just buying a rebuilt and slapping it in.
Here is the evolution of events: - Had forward in low only, and reverse worked. Possible cause is low pressure due to pump not working correctly. - Lost all forward, maintained reverse. Same possible cause as above. - Lost all gears. Further shows that pressure to the whole system was lost. There is a pump shaft coupling in the nose that is fairly easy to get to. This will show me the pump and if there is something cheap to fix it. Man, I hope so. I have to drain it and remove the pan anyway. This will just be a little delay in time. I hope to figure it out more tomorrow. I need time, no rain, and a place to work. It broke down on my inclined driveway. Good times (IMG:style_emoticons/default/dry.gif) |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,926 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
I guess it's safe to assume it's not the loss of vacuum modulator or an out of adjustment Modulator? That effects shifting into high gear in a powerglide. Also there is a band adjustment you can make too. The other probability is the pump is dead. If you have an out of alignment converter it will take out the pump. I've also seen the converter spacing incorrect and the converter wipe out the pump dogs. (converter not fully engaged)
crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,830 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
I will check with Jim at work...his family owned corvair ranch.....
he really knows them.... |
Dr Evil |
Funny you should mention Corvair Ranch. The guru I spoke to was Jeff Stonesifer, the owner (IMG:style_emoticons/default/smile.gif) Nice guy and we have had lots of talks in the past.
crash914 |
new owner. old owner is Goulden...jim's father..he grew up there...
Dr Evil |
Jeff still works there and answers the phone, then.
Well, I dropped the front of the tranz today and pulled the front cover to expose the main pump. It is easy to see the wear on the pump drive dogs. The pump shaft was OK and the C clip was in place. The primer piston was stuck in its slot and the drain plug had nice fine metal on it. I am wondering if I missed a measurement and the pump drive dogs were too big. I did have two trannies to choose from when I was rebuilding. At this point, I am shorter on time than $$ so I am going to spend for a rebuilt and hope it can get here fast so I can throw it in and GO. Attached thumbnail(s) ![]() |
crash914 |
which trans? torqueflight or th350?
Could be sealing rings on main shaft.... |
Dr Evil |
It is a corvair, so powerglide. They only came with the powerglide as an automatic.
I put all new seals in. I am pretty sure I did not screw that up as it is straight forward. |
Lo-Fi Version | Time is now: 21st April 2025 - 12:13 AM |
