85 Pages V « < 79 80 81 82 83 > »
> The Doc's tranny waggin'
Dr Evil
post Dec 21 2013, 03:18 PM
Post #1601
Send me your transmission!
Completely agree (IMG:style_emoticons/default/agree.gif) I would have to redo my whole geometry if I went with another or different set. No thanks. I did it when I built the engine and it was on the stand. I do not want to do it with the engine in place and am not dropping it again if I can help it.
Dr Evil
post Dec 21 2013, 10:40 PM
Post #1602
Damn, the stock rockers/studs/balls/nuts cost some money. I wish I held onto the ones I had (IMG:style_emoticons/default/dry.gif)
bulitt
post Dec 22 2013, 08:28 AM
Post #1603
Achtzylinder
Ebay. Just buy new balls.
Dr Evil
post Dec 22 2013, 09:27 AM
Post #1604
Nope. Already bought and paid for. New balls, nuts, studs, and rockers. You kinda need all of them. Also, I do not trust any of the parts gotten from the vendor of the roller rockers.
Dr Evil
post Jan 10 2014, 10:40 AM
Post #1605
Scotty, did I bring and leave my CIS test kit at your place. I can not find it anywhere and I need it, like now (IMG:style_emoticons/default/sad.gif) If I am to use the bus to help move my shop I need to get the CIS tuned up.
scotty b
post Jan 10 2014, 12:23 PM
Post #1606
rust free you say ?
QUOTE(Dr Evil @ Jan 10 2014, 08:40 AM) *
nope (IMG:style_emoticons/default/confused24.gif)
Dr Evil
post Jan 10 2014, 12:35 PM
Post #1607
How the hell do I lose a big red box with a CIS tester in it between Oct 1 and now? I looked everywhere (IMG:style_emoticons/default/sad.gif) I am pretty sure my pressure if grossly low.
type47
post Jan 10 2014, 03:17 PM
Post #1608
Viermeister
QUOTE(Dr Evil @ Jan 10 2014, 10:35 AM) *
... I looked everywhere ...
Did you look in Baby Evil's toy chest? (IMG:style_emoticons/default/idea.gif) Maybe he was checkin' his CIS pressures and forgot to put it back ...
If you are in a bind for a tester, there is a guy selling a homemade one on vwvortex for $20 and there are plans out there for building them...
VaccaRabite
post Jan 10 2014, 03:25 PM
Post #1609
En Garde!
QUOTE(Dr Evil @ Jan 10 2014, 01:35 PM) *
Between Oct 1 and now you have had 4 different garages.
I'd say its a wonder more stuff has not turned up missing.
You know the quickest way to find it of course. Just buy a new one. You will find the old one within a day or so of the new one arriving.
Zach
bozo914
post Jan 10 2014, 04:16 PM
Post #1610
Slacker
QUOTE(Vacca Rabite @ Jan 10 2014, 04:25 PM) *
Zach
(IMG:style_emoticons/default/agree.gif) My jumper cables are missing, am going to buy new ones, I'll trip over the old ones tomorrow or Sunday
scotty b
post Jan 10 2014, 04:38 PM
Post #1611
rust free you say ?
QUOTE(Vacca Rabite @ Jan 10 2014, 01:25 PM) *
Zach
You've seen Mike's organizational skillz. It's highly unlikely he misplaced it. Someone must have stolen it (IMG:style_emoticons/default/mellow.gif)
type47
post Jan 10 2014, 04:44 PM
Post #1612
Viermeister
http://www.harborfreight.com/automotive-mo...-kit-97706.html
bulitt
post Jan 10 2014, 05:25 PM
Post #1613
Achtzylinder
QUOTE(scotty b @ Jan 10 2014, 01:23 PM) *
I usually blame my wife for everything (IMG:style_emoticons/default/biggrin.gif)
worn
post Jan 10 2014, 10:16 PM
Post #1614
Well they came down a long way at hf if you only needcis. Just saying since now you arent stuck at thelow end. Duplication is the key to clutter. Good luck. My mom always told me to clean up when i wanted to vfind things. Bless her spirit, it always worked.
Dr Evil
post Jan 10 2014, 10:36 PM
Post #1615
HF has a CIS kit? Hmmmm.
wingnut86
post Jan 11 2014, 12:32 PM
Post #1616
...boola la boo boola boo...
Mike,
My apologies for the rest of the negative comments that the balance of the Motley Crew left here.
I for one, think your organizational skills are top notch (IMG:style_emoticons/default/beer.gif)
By the way, if you ever have to "work" on me personally in one of your medical MTV like "Cribs", please don't take the "NOT THIS ONE" tattoos personal...
(IMG:style_emoticons/default/smash.gif)
Dr Evil
post Apr 4 2014, 09:13 AM
Post #1617
Okey dokey, I finally took some time to go work on the bus yesterday. I have a download of the factory CIS manual and another one of a troubleshooting guide. From this I made a trouble shooting chart and reacquainted myself with the CIS.
Gripe list:
- Hard to start cold or warm
- Sometimes will not start warm
- Shitty mileage (could be because it is a bus and I drive it kind of fast)
- Poor idle. I had to adjust the idle high to keep the engine running when I switch from idle to D, otherwise it dies right off and it sucks to start (as above mentioned).
Based on this list, I had a suspicion that my fuel pressure was likely too low, and that this was either a restriction problem due to pump, or flow issue due to faulty WUR.
Pre-test exam of parts:
- Found that I had my Cold Start Injector wired backwards. This should not have been an issue, but I corrected it. I had Ground directly to one wire and power going first to the thermoswitch and then to CSI. This may have heated the TS and caused the CSI to prematurely close, but I doubt this was the issue. Fixed it anyway. The location I chose to put the TS in is unfortunately under more pressure than the TS could handle and it is pissing oil all over the place (IMG:style_emoticons/default/dry.gif) I will need to remedy this soon.
- Cleaned up oil, checked a bunch of other stuff, proceeded.
The test:
- The manual says to hook the gauge between the control pressure outlet on the fuel distributor and the WUR. Did this. Almost all tests are done here.
Findings:
- All cold, key on, system pressure is around 2.2 bar ( I think this is high).
- Warm running control pressure was 4.7 bar (seems kind of high, actually).
- System leak down pressure was good as it dropped fairly fast to 2.2bar and then maintained for over 10 min. (pass)
I have to admit making a mistake. I did not unplug the WUR power in when doing the cold system pressure check so I just noted the pressure dropping and the WUR making a whining noise due to it shunting the pressure in back to the return line. So, I did not record exact cold system pressure. I could not replicate the cold system pressure as the WUR did not cool down over the hour or two I was messing with it while doing other projects around the garage. I will go back tonight (maybe) and see if I can get cold pressure.
Thoughts:
-If cold pressure is too high, starting will be hard. The WUR did warm up pretty damn fast. The manual mentions 10min, mine was like <2min. The manual is not exact on each WUR and they changed about every friggen year.
-If I can deduce that the whole system pressure is actually too high, I can then change the check valve pressure limit with removal of a shim on the intake of the fuel distributor.
- One issue I am having with this thing is that the WUR I have has a vacuum component to it. So, to accurately measure it I have to have a vacuum source. So, I need to buy one I can measure. OR, I have a WUR without this feature and I can just omit this and try that out. I would rather do it with the one that came with the system (I think it is correct). An improperly functioning vacuum mechanism in the WUR would make cold starts suck as it would not drop the pressure and the pressure would then flood the cylinders on start up. A high pressure state makes sense as the engine floods often; smell of gas, wont start, have to wait 30min for fuel to dissipate from cylinders.
Any thoughts from those that know CIS stuff? Maybe the WUR originally had a special time delay circuit that I am not compensating for. Maybe changing to a simpler WUR would solve/remove some issues. I want simple. The current system does not have the TB pressure regulator that I have on my 74 2.7 in my 914.
malcolm2
post Apr 4 2014, 09:33 AM
Post #1618
QUOTE(Dr Evil @ Apr 4 2014, 10:13 AM) *
Grip list:
The test:
Findings:
- Warm running control pressure was 4.2 bar (seems kind of high, actually).
Thoughts:
I have an 85 VW Cabriolet with CIS. I feel your pain. In the past, my problems were the under car fuel pump, but you are getting high pressure. My car has an in-tank one too. Folks say that the screen falls off of it sometimes. Could there be something in the return line? When is the last time you replaced the fuel filter?
I have also been thru a few fuel distributors. Those things are so finicky. A mechanic told me once that he used to polish the plunger with ashes from his cigarette.
One more thing: the injectors. Mine are easy to pull and do a squirt test in empty water bottles. Could be plugged.
Good luck.
Clark
Dr Evil
post Apr 4 2014, 09:35 AM
Post #1619
More digging, more revelation.
This is from a 3.0, so it is either 76-77. Non-turbo.
Atmospheric warm system pressure is 2.7-3.1 so I am significantly over this. Finally, a definitive problem. More to come as I dig around the notes and manuals.
Dr Evil
post Apr 4 2014, 10:01 AM
Post #1620
QUOTE(malcolm2 @ Apr 4 2014, 11:33 AM) *
Grip list:
The test:
Findings:
Thoughts:
Good luck.
Clark
Pressure being up could be an obstruction in the line, but the pressure was not up until the WUR warmed up. I just changed the filter, but that is on the supply side so if it was clogged it would be low pressure, not high at dist.
I dont smoke cigarettes, so that wont work (IMG:style_emoticons/default/wink.gif)
- Lo-Fi Version Time is now: 20th April 2025 - 06:23 PM
