Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,038 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Dr Evil |
More.
Attached thumbnail(s) ![]() ![]() |
Dr Evil |
s'more.
Dr Evil |
I made the rear pieces into one piece. No need for 2 and it fits better. I also installed a hose for the FP sensor.
Dr Evil |
Oil P hose and sensor.
Attached thumbnail(s) ![]() |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,720 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
The pic of the snow drift is actually several inches smaller then it was Saturday. It is thawing a little during the day, then freezing solid and compacting at night when the temps drop back under 5 degrees. We have had about 4 inches of sublimation since the storm 2 days ago.
I also picked up 80 pounds of salt the AM to help fight the ice war on the lower driveway. Can't let the salt near the old iron though. Gotta keep'em separated! I say the same thing about every T4 when it goes from untinned to tinned... It is amazing how much bigger they look with the tin on. That corvair motor is pretty compact, but it looks ginormous right now. Very cool watching this transform. I have off work today, so I'll be able to help whenever Mike comes over. Even if my "help" is just BSing and working on my car while he is working on the bus. Zach Zach |
Dr Evil |
That's more help than you know (IMG:style_emoticons/default/smile.gif)
VaccaRabite |
Mike continued working on tin this evening, welding on capture nuts.
I puttered about on my car, then welded some of Mikes exhaust stuff together. I think that a lot got done tonight, but nothing really picture worthy. Mike has a lot of stuff to take to get coated now. Then we wait out some silly white stuff, put the engine in the bus and drive it to Hershey to see if it makes it or not. (it will). |
Dr Evil |
Zach is right, there was not much to take pics of. Welding the nuts to the sheet metal was fun, easy and will allow for it to be assembled and disassembled easily. Zach hooked up welding the adapter with the O2 sensor bung. Now I think I will get the headers coated. They are rusting pretty bad just sitting there. I had to adjust the throttle linkage since I lowered the carb. Also put a hole in the front tin to accommodate the linkage. I will be putting some rubber seals around the hole to reduce hot air flow into the engine bay. Then clean up and paint. After that, probably installing the engine.......when I can dig out the rear of the bus. (IMG:style_emoticons/default/dry.gif)
I also need to make an oil T adapter....and I need the sensor. Zach says he has one. I have part of an adapter, I just need to thread it for the temp sensor. |
VaccaRabite |
The sender (I think) is in one of the yellow bins on the wood walled workbench. Look through them and you will probably find it. It MAY still be in its box, hiding in plain sight. Another place to look is in the red tool box, probably in the top bin. Erin and I are going to try and have a date this afternoon (her work closed too) so we may not be there if you come over. We won't be long, though. Still have to get Theo by 5:30.
Zach |
buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
Dr Evil |
The sender (I think) is in one of the yellow bins on the wood walled workbench. Look through them and you will probably find it. It MAY still be in its box, hiding in plain sight. Another place to look is in the red tool box, probably in the top bin. Erin and I are going to try and have a date this afternoon (her work closed too) so we may not be there if you come over. We won't be long, though. Still have to get Theo by 5:30. Zach I think I am staying home today. There is nothing pressing on the engine and the weather is gonna turn eventually. Maybe the next time I come down, the engine will be able to be put in. There is not much left to do before that and I am not motivated to come down just to do that little bit of work today. |
VaccaRabite |
Is that a jeep 725 or a 914? The jackstands look familar. Neither! Its a Jeep 715. The 725 was the ambulance version. Needless to say, it has spent too much time near my 914 and picked up the jackstand disease. Between the bus, the jeep, and my 914, I have no more ramps or stands to change the oil in my DD. The jeep is waiting for an engine, which will be showing up soon after the bus leaves. Zach |
buck toenges |
Is that a jeep 725 or a 914? The jackstands look familar. Neither! Its a Jeep 715. The 725 was the ambulance version. Needless to say, it has spent too much time near my 914 and picked up the jackstand disease. Between the bus, the jeep, and my 914, I have no more ramps or stands to change the oil in my DD. The jeep is waiting for an engine, which will be showing up soon after the bus leaves. Zach What type of engine. Didn't those trucks have some sort of flat head 6 cylinder that kaiser made into an overhead cam? Something like 230 tornado or something like that? |
VaccaRabite |
Yeah, 230 Tornado. It was the first Hemi engine, actually. Years before Dodge came out with one. Also, it was a very early overhead cam engine. It was ahead of its time.
Which is bad for a motor, since no one knows how to properly service it, and then they get a rep for poor reliability. 40 years later, many of them are still chugging along. But they are underpowered (130Hp, 210Tq) and parts are becoming difficult to find for the 24 volt motors. I am dumping it for a Chevy 350. The donor truck will be moving in within days of the Evil Bus moving out. I wanted to do a Cummins 4BT diesel, or an AMC 360, but the 350 is a 4 bolt main, good condition and free. hard to turn down. Zach |
Shade Tree |
Member ![]() ![]() Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest ![]() |
Are parts for your Corvair engine easy to find? I ask because there is an early 60's Corvair 6 with a powerglide for sale locally for $100.
Dr Evil |
Stupid easy and affordable.
Search: Larry's corvair parts Corvair Ranch (my local supplier) Clarks Corvair (best catalog, but sometimes stuff is not in stock) There are a few others, but these are all I have ever needed. |
VaccaRabite |
Yesterday I started de-burring the engine tin after I picked up a sheet and proptly but a metal jaggie into my thumb. (IMG:style_emoticons/default/wacko.gif)
Then I primed, and got a coat of paint on one side before I decided I had enough. I missed one edge de-burring that I noticed on the painted stuff that I might try and get Tuesday, and I have not touched the rear tin nearly at all - at least with paint. Not picture worthy, but it is progress. zach |
Dr Evil |
Thanks man. That will help a lot. The only things left then:
- Figure out the Oil T sensor mounting - Run some hoses and lines (drill some holes in the rear tin) - Wire up the bus so it will be ready for hooking the engine up - Paint the bay (again!, and again, and again) - Paint mounts - Install engine If you want, the mounts are in the back of the bus and need paint as well. And maybe an inspection of my welds. I am not sure if they need more material or not. I think I but welded them. |
VaccaRabite |
I''ll try and get out Tuesday night and inspect the mounts. It is likely that I will just continue de-burring and painting though. That has to be done before the engine can go back in.
I also need to remember to fill up the K1 jug again. The heater burned it all up keeping the garage warm while I puttered with my car and painted your tins saturday. |
Lo-Fi Version | Time is now: 22nd April 2025 - 09:14 AM |
