strawman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 888 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California ![]() ![]() |
Got a chance to correctly set up the PCV system, using two oil catch cans -- one between the crankcase vent and the PCV valve, and another between the crankcase vent and the intake tract (before the throttle body). I also ran a hose from the head vents through a filter to the intake tract. I had a local welding shop TIG two nipples to the underside of the aluminum intake tract piping. For the most part, I was able to route the hoses underneath the intercooler and piping, but you can see a few of them in the video below.
To clean out the oil slick caused by my initial PCV system error, I ran half a bottle of Seafoam through the vacuum ports on the intake. Smoke galore, but along with new spark plugs the engine now purrs cleanly. (IMG:style_emoticons/default/aktion035.gif) Now I just need to figure out the cold engine start hunting/coughing; could be the larger than stock injectors I'm running, which will take a while for the ECU to "learn." I need to modulate the throttle for the first 20 seconds or so until it smooths out. I was also able to finalize burping air from the cooling system. The radiator fan I'm using -- out of a mid-90s Lincoln Mark VII -- really moves a lot of air, so I'm hoping my cooling system will suffice. And the Bosch intercooler pump -- out of a mid-90s BMW 5-series (E34 chassis) heater booster system -- helps to noticeably lower intake temps, at least at idle. The alloy pipe coming out of the turbo is warm/hot to the touch, but the intercooler outlet is ice cold. I'm hoping to drive it in the cul-de-sac tomorrow or the next few days, if it will ever stop raining! Here's a another video: https://www.youtube.com/watch?v=RgzxVT6A7Tk |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
Pvc is pretty complicated on a boosted suby. The vaccum in the intake manifold when it's na then the boost and a slight vaccum in front of the turbo reverses the pvc operation. Sometimes just longer hoses will help smooth out the high vaccum instances where the oil gets in the intake. We installed a mann provent ( it was used on the turbo, I think calloway, corvettes at one time) on my son's suby but it's a diesel part so the orings went to crap and needed to be switched but it puts the oil back in the pan to keep from lowering the oil level. On a low mileage driven car the catch cans are probably a easier and cheaper solution. I was afraid that the catchcans being a closed system sorta that the hoses would need to be extra long. We did a lot of plumbing with some manifolding to try to get a good system but now my son is considering going just to catchcans. I can't decide if this application is in the race car or street car application on the pvc deal.
Hope you come up with a better, simpler working solution than ours as the mann provent is not cheap. |
JStroud |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California ![]() |
That's got to be a great feeling to have it running after so much work.
I'm sure you can't wait for that first drive (IMG:style_emoticons/default/driving.gif) Glad you got it going, can't wait to see it (IMG:style_emoticons/default/beer.gif) Jeff |
Zaney |
Deuchland en der Haus ![]() ![]() Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest ![]() |
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/aktion035.gif)
Don't worry about unraveling the wiring loom few times. I think I did it 6 times (IMG:style_emoticons/default/hissyfit.gif) Great job Geoff! |
strawman |
Drove it for the first time a few minutes ago, and my wife captured it on her iPhone. She's almost as excited as I was!
https://www.youtube.com/watch?v=bg_NjmUrk-o Spent the day clearancing the fender flares, as I had a little rub under compression. Then I buttoned up the suspension (finally installed zip-ties that tie the rear upper hats to the Eibach coilovers) and torqued everything down. Finally, I installed the tach converter that Larry (904SVO) corrected for me (IMG:style_emoticons/default/pray.gif) -- so I now have a working tach that is driven by the Subaru ECU. The car definitely has a BIG turbo punch, although I didn't wanna piss off my neighbors too much. I still have a long way to go to have it truly roadworthy, but it feels GREAT to finally get it move under its own power!!! |
a914622 |
Member ![]() ![]() Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest ![]() |
Lucky page 13 as we go into 2013! congrads.
It sounds like the wife is happier! (IMG:style_emoticons/default/driving-girl.gif) |
904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
Glad that the tach works now. Did you wire the ODB2 in? check and see if you have any DTC codes I can help you with. Just wait till you get 18lbs of boost
and really go like HELL!!!!!!!! |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
(IMG:style_emoticons/default/beerchug.gif) That cul-de-sac looks like it is begging for some rubber rings (IMG:style_emoticons/default/happy11.gif)
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,316 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Drove it for the first time a few minutes ago, and my wife captured it on her iPhone. She's almost as excited as I was! The car definitely has a BIG turbo punch, although I didn't wanna piss off my neighbors too much. I still have a long way to go to have it truly roadworthy, but it feels GREAT to finally get it move under its own power!!! (IMG:style_emoticons/default/piratenanner.gif) Congrats Geoff! Absolutely killer (IMG:style_emoticons/default/evilgrin.gif) |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
wingnut86 |
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States ![]() |
AWESOMENESS!!
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,121 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,698 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Let's see, I've read your build thread how many times and for som,ew reason thought it was already running. (IMG:style_emoticons/default/headbang.gif) Mucho congratrulations. (IMG:style_emoticons/default/first.gif)
d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,349 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
Awesome and congratulations,,, I though you were making me look really bad until I heard ur wife say 4 years into it!!
I'm working on five so I see light at the end of the tunnel..... Sounds sweet.. Greg |
ruby914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None ![]() |
(IMG:style_emoticons/default/smile.gif) Congratulations!
That is a great way to start the year. (IMG:style_emoticons/default/driving.gif) |
charliew |
It sounds good, thats got to be a great feeling. I'm sure it gives you new energy for a couple more years of up grades. Just think how much closer to finished you are though.
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
(IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/aktion035.gif)
All the trick build and time spent pales in comparison to how you EVER got you wife that excited and supportive of a habit that clogs up the garage, burns your vacation time, and spends any cash, which will eventaully strand you around town, and cost as much as a foofy 911. Congrats again though! AWESOME! |
d914 |
I'll have to second that on the wife's reaction..... That was great to hear!
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,055 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Sounds AWESOME!!!! Good for you man, your hard work is paying off!
biosurfer1 |
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California ![]() |
Finally! WCR here you come!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
Lo-Fi Version | Time is now: 22nd April 2025 - 10:29 AM |
