which 96mm p's and c's to use |
rhodyguy |
Jan 19 2004, 04:08 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what? i would have to mic all the new stuff?? the q.c. of these products had better not have me worried about being out of round.
kevin |
ChrisReale |
Jan 19 2004, 04:10 PM
QC? What the hell is that? (IMG:style_emoticons/default/laugh.gif)
I have heard rumors of some pistons being waaaay outta balance straight from the factory. What you should do is double check everything before using it. Go to a deli and have them weigh the pistons and print out a sticker that says how much it weighs |
McMark |
Jan 19 2004, 04:15 PM
Damn! I bought a set of Mahle pistons and they were 12 grams between the heaviest and the lightest. That's insane! The KBs I got were maybe 1.5 grams out. You have to check everything. If you trust someone elses QC then that's the part that will come back to bite you.
Jake Raby |
Jan 19 2004, 07:00 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
These days Mahle's suck pretty bad for balance. I consider a good set out of the box to be 8 grams out. I have seen up to 30!
None of the cylinders on todays market are worth a damn..thats why I bore stockers, they don't warp, don't leak and cool better! |
mightyohm |
Jan 19 2004, 07:05 PM
Jake, does it matter whether the cylinders to be bored out are Mahle or KS? They are pretty much the same right??
swood |
Jan 19 2004, 07:11 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
QUOTE(jkeyzer @ Jan 19 2004, 05:05 PM) Jake, does it matter whether the cylinders to be bored out are Mahle or KS? They are pretty much the same right?? Jake, what's your thought on a couple broken fin corners? |
914werke |
Jan 19 2004, 07:32 PM
"I got blisters on me fingers" Group: Members Posts: 10,517 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I know how you bring rods into balance, how the hell do you get 12GRAMS!! off a Pistion? (IMG:style_emoticons/default/headbang.gif)
Brad Roberts |
Jan 19 2004, 07:38 PM
You send them back defective. (IMG:style_emoticons/default/biggrin.gif)
mightyohm |
Jan 19 2004, 08:59 PM
Do what I did and drop it. See what falls off. (IMG:style_emoticons/default/rolleyes.gif)
mightyohm |
Jan 21 2004, 05:36 PM
I don't think aircooled checks the pistons out before they ship them to you. They just told me that the cyls are usually the problem and that they have not had a problem with the pistons.
thesey914 |
Jan 21 2004, 05:50 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
QUOTE(rdauenhauer @ Jan 19 2004, 05:32 PM) how the hell do you get 12GRAMS!! off a Pistion? I seem to remember the wrist pins are machined to match the weight |
914ghost |
Jan 21 2004, 06:27 PM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
speaking of.. .Can anyone supply the part number of the pistons that are usable w/ the 1.8 stroke?
And any of the 1.7 / 1.8 cylinders can all be bored to accept the right 96's? TIA Robert O Anyone got some o' them (pistons) they don't want? |
mightyohm |
Jan 28 2004, 01:58 AM
What ring gaps are people running with the 96mm KBs for a 2056?
For that matter what skirt clearance also? I was expecting to get this info with the pistons but got some generic american iron numbers instead. |
Lo-Fi Version | Time is now: 20th September 2024 - 04:59 PM |
