> OT: Anybody Own a Honda Pilot and Tow with it?
Ferg
post May 16 2008, 09:09 AM
Looking at a Honda Pilot to replace my Xterra. (mainly for the 3rd row seat) I know it does not have a real frame like my Xterra and the tow rating reflects that. Xterra=5500 Pilot=3500 or 4500 pulling a boat trailer, still figuring out why that makes a difference, seems to be due to boat trailer design and less tongue weight.
My camper weighs in at 2600 Dry, I figure with gear and my family we are in the 3-3200 range. Tongue weight is 170.
I think my car trailer is only about 800lbs, so with a 914 or 911 similar weights to the camper.
I've done some reading with mixed reviews, looking for some real world input from members.
Ferg (IMG:style_emoticons/default/beerchug.gif)
purple
post May 16 2008, 09:14 AM
Pigeon feeders attract me
My parents had a jeep cherokee, a '91 model I believe with the 4.0L inline six and they are Uni-body vehicles. It never had a problem pulling lots of weight.
They now have a diesel jeep grand cherokee and it can pull 6500 Lbs. Uni-bodies are great for towing when they are designed for it. Jeep makes great vehicles for this.
Just trying to break the myth that you need a frame to haul a mediocre amount of weight. For 25K pounds, i can see a dually.
Joe Bob
post May 16 2008, 09:41 AM
All I know is that when you tow near the max weight, stuff breaks. My 1/2 ton was ALWAYS burning thru brakes, the wife would get 15K on them. My 3/4 ton...60K....same pads.
Double axle trailer.....no problem on the brakes and tires....single axle....nothing but problems on the bearings, tires and surge brakes...
So.Cal.914
post May 16 2008, 09:46 AM
"...And it has a front trunk too."
From some negative info on other 'Tow' worthy vehicles, it appears the running
gear is more of a problem. I don't know if Honda has addressed this or not.
Rearends going out was what most of the bitchen was about.
purple
post May 16 2008, 09:50 AM
QUOTE(!Wet Spot! @ May 16 2008, 10:41 AM) *
was that an F150?
i ask because that is quite possibly, the most horrid example of a 'truck' i've ever seen.
Working at lowes as a loader, it never failed some dude wanted a full pallet of tile put in the back of one of these. f150's are worthless and ridgelines would suit the owners better for 99% of how they get used on a daily basis. I blame the auto makers for making the base full size truck as pussy as possible so you have to buy the next step up, aka f250 HD, 2500 ram, 2500 silverado.
it's sad; watching the springs bend backwards on a supposed 'full size' truck when you put tile in the back of it. my buddy's 2500 cummins was a hoss! you put a load like that in the bed and it just kisses the helper springs.
for towing, make sure your trailer has good brakes and you wont have problems. you were probably towing over the max limit of UN-BRAKED load, which is significantly lower than max rating. towing isnt hard if you read the manual.
Ferg
post May 16 2008, 10:47 AM
Thanks for the info, I was high bidder at a dealer sale at 21300 with a "if", I ran the carfax and it had a "stolen" record, so I passed...
Not to say the Pilot is out of the running completely but this one sure is. I'm still leaning heavily towards a Pathfinder. (same running gear as my Xterra)
Ferg
shelby/914
post May 16 2008, 11:28 AM
Ferg, does your pop-up have any kind of brakes? Given that you will be towing in the mountains most of the time you might want to consider putting brakes on it or going with the more substantial tow vehicle like the Pathfinder or even larger. You could even go for a full size suv if its main purpose is for towing the camper and the occassional need for the 3rd seat. Obviously you would not want to drive it all of the time. You could probably pick up one real cheap this summer. The wife and I have switched cars since she drives to work every day and I'm mostly home, she has the BMW and I have the Expedition. So now she is routinely getting 25/6 in town instead of 13. We'll probably never sell it as it's pretty much worthless as a trane in but comes in handy from time to time. Might also want to check into Colo law on trailer weights and brake requirements. They became much more restrictive a few years back, requiring brakes at lower weights and on both axels on tandems.
Joe Bob
post May 16 2008, 11:31 AM
Chevrolet/GMC. I grew up with Ford's and was underwhelmed on the dealer support in my area and the general design so I went with GM.....they are marginally better.
I'm just glad I purchased an extended warranty.....ECU, fuel pump, a/c relays, gauge pod, heated seats, fuel tanks, On Board Vapor Recovery, just to name a few of the screw ups....
Stoopid thing gets 13mpg and mostly sits....worthless as a trade in. Wife now drives a Volvo wagon and it gets 25-30mpg. But we have a boat and on long drives it gets 16...woo hoo....and it's roomier for the monsters, but they still bitch....
Ferg
post May 16 2008, 11:51 AM
QUOTE(shelby/914 @ May 16 2008, 09:28 AM) *
Yes, electric brakes on the camper and my car trailer, and the Xterra has brake controller ect.
The Xterra and the Pathfinder are exactly the same truck, Pathfinder is just stretched a bit and offers a third row seat.
I'm extremely happy with the Xterra so far, it tows excellent and the 264hp 4.0 six will outdrag my 911, and gets almost 20mpg when driven nicely.
Ferg (IMG:style_emoticons/default/biggrin.gif)
gopack
post May 16 2008, 12:04 PM
CHEESEHEAD in CA, MARK
I own a 2004 Honda Pilot, EX-L and have towed my car on a uhaul trailer from New Mexico to Idaho, and Idaho to Wisconsin with no problems. Just make sure you have added a transmission cooler, and take it easy in cross winds because the Pilot doesn't have the weight that a big PU has. I got about 14 MPG for the trip. The U Haul car transporter weighs in at 2000lbs, and the car as it sat weighed close to that as well! Also have towed cars on the uhauls back and forth to IL on numerous occassions!
On a side note, i really like the Pilot. it is a well built, well engineered CAR, BUT the 3rd row of seats are a death trap! small, and VERY close to the rear window. If you need to routinely travel with 8 passengers, I would suggest (shudder) something like a suburban or large van of some kind!
Ferg
post May 16 2008, 12:32 PM
Thanks Gopack... Sister has a Pilot and she loves it as well.
3rd row seats for us are strictly for when company is in town...
Right now the Xterra's back seat has two anchor systems for our two carseats. No room for a even a third person back there, rendering it a 4 person vehicle.
Now that Mom and Pop are very close to retirement, they will be visiting Colorado more often, and it would be nice to take one vehicle places rather than two...
TROJANMAN
post May 16 2008, 12:37 PM
Looks nice in pictures.........
Ask Scotty. He has a Ridgeline (same truck car?)
He probably knows everything you probably want to know.
And it's really pretty I hear.
I'd recommend a used Expedition and park it on the side of the house.
That's what we do with ours. No one drives it anymore, but we keep it around for visiting family and towing.
What a waste.............(IMG:style_emoticons/default/dry.gif)
Scott S
post May 16 2008, 12:52 PM
Small Member
Unfortunately it is my understanding that the frames are completely different. My RL has a normal ladder frame, then the main body structure is welded to it. The thing is amazingly stiff. Build quality seems to be top notch however, and like your Xterra, the thing seems to really scoot.
I got my wheels abck from the powder coater... yes, it is very pretty - if you like big giant white refridgerators.
Need to get the new grill. The thing looks like a barbque burner from the front.
You should be able to get a killer deal. Not only are there large rebates ($6k) but there is a redesign of the Pilot for 2009, so dealers will be dumping the old body style.
Good Luck!!
Ferg
post May 16 2008, 12:57 PM
(IMG:style_emoticons/default/laugh.gif) Greg, your Ford might be a collector truck someday (IMG:style_emoticons/default/blink.gif) I drove your Expedition back from Moab remember (IMG:style_emoticons/default/biggrin.gif) I hate to tell you, but the Xterra felt better as a tow vehicle, but that could be due to your heavy ass trailer...
I've been Nissan loyal for 10 years now... The Pilot was a thought if it was a good enough deal, but not that fell through, I'm most likely going the Pathfinder route.
Ferg
Ferg
post May 16 2008, 12:58 PM
QUOTE(Scott Schroeder @ May 16 2008, 10:52 AM) *
Good Luck!!
Scotty, we need some pics of that Maytag.
TROJANMAN
post May 16 2008, 01:04 PM
QUOTE(Ferg @ May 16 2008, 10:58 AM) *
Good Luck!!
I hear it's a work in progress............
(IMG:http://media.motortopia.com/files/5294/vehicle/4614122f78280/15422IMG_0534.jpg)
(IMG:style_emoticons/default/av-943.gif)
Scott S
post May 16 2008, 01:47 PM
Small Member
TROJANMAN
post May 16 2008, 01:48 PM
Scott S
post May 16 2008, 01:49 PM
Small Member
this is closer....
Scott S
post May 16 2008, 02:02 PM
Small Member
now were talkin....
- Lo-Fi Version Time is now: 26th December 2024 - 06:20 AM
