JOE M |
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None ![]() |
I got my rebuild kit a few days ago and installed all the parts. I found that the kits came with the later model pump diaphram so I have to use my old pumps until I get the replacements. After about 30 minutes of tuning , the carbs seem to be working well. I still have some fine tuning. Prior to this I had a friend recheck my timing and valve adjsutmnts. All is well and compression is finally even all around about 110psi (still a little low).
So yesterday I started the car and began making some adjustments to the carbs. I turned the car aff and was checking for leaks and I heard a noise like fluid draining. I watched as gas filled each barrell. I am not sure why but after I stop the engine all the gas in the bowl leaks into the barrells (how is thisn possible??). This is happening on both carbs. Any thoughts?????? Thanks in advance. Forgot to say they are weber idf40 |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
I have a pear of Webbberrz with the thickening pheoholic spasters and my many folds stay plenty cool. Running without the phenoholic spasters seems like a bad idea. Elliot, make sure that your falter holders are in there good, one of mine liberated it's self on the track and my car was crisping before I knew it. I put a bead of RTV around the head now just to make sure that they can't come loose anymore. Hi! "I'm Elliot... and I'm a phenoholic." (I've been going to phenoholic meetings for years.) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
I have a pear of Webbberrz with the thickening pheoholic spasters and my many folds stay plenty cool. Running without the phenoholic spasters seems like a bad idea. Elliot, make sure that your falter holders are in there good, one of mine liberated it's self on the track and my car was crisping before I knew it. I put a bead of RTV around the head now just to make sure that they can't come loose anymore. Hi! "I'm Elliot... and I'm a phenoholic." (I've been going to phenoholic meetings for years.) Perzakly what is "phondolick" anyway? The Cap'n |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
The first step to recovering (upholstery?) is admitting that you have a problem to Huston.
purple |
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None ![]() |
Reporting can be done to me... I'm in the planet Houston
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
This thread is killin me!!! (IMG:style_emoticons/default/happy11.gif)
Elliot Cannon |
I have a pear of Webbberrz with the thickening pheoholic spasters and my many folds stay plenty cool. Running without the phenoholic spasters seems like a bad idea. Elliot, make sure that your falter holders are in there good, one of mine liberated it's self on the track and my car was crisping before I knew it. I put a bead of RTV around the head now just to make sure that they can't come loose anymore. Hi! "I'm Elliot... and I'm a phenoholic." (I've been going to phenoholic meetings for years.) Perzakly what is "phondolick" anyway? The Cap'n Phondolick is a town in Woskonson. (Hell, any grade school kid knows that). |
purple |
we're a bunch of goofy MFers
JOE M |
I think I found the problem. It appears that the pump spill screw had a rubber gasket on it. There should be no gasket on this screw. This is the screw that sits on the bottom of the bowl. It seems like it is some sort of check valve because there is a bearing of some sort in it. I had no gas left in the car and I also had no time to work on it last night.
Lo-Fi Version | Time is now: 28th June 2024 - 07:50 PM |
