OT Scissor lift installed in pit, or....why I'm sore tonight |
PRS914-6 |
May 30 2008, 11:49 PM
Thought I would post my installation of a scissor lift. It's a full rise scissor lift made by Bend Pak and will raise a vehicle 6 feet. It's designed to sit on the floor and ramps were included but I hated that you could only get one car at a time in the shop and the lift kind of consumed the area. The two post systems are much cheaper but then you have posts to deal with.
So, out came the saw, shovel, forms and concrete truck. Once the concrete cures, I will drop it in the new hole and the lift will be flush with the surface of my shop with 3/4" clearance all the way around. No more ramps or metal sticking up. I even installed an underground conduit for the hydraulic hoses and the air emergency lock system. The idea being to be able to use the garage like normal and still have a lift. It was a lot of work but I hope it will be worth it in the long run. |
Eric_Shea |
May 31 2008, 12:17 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Yeowza... nice job (as usual)
Humor us; show us a picture of something you've done 1/2 assed! Let us know you're mortal damn it!! (IMG:style_emoticons/default/biggrin.gif) |
biosurfer1 |
May 31 2008, 12:31 AM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
So when do us locals get a tour??
PRS914-6 |
May 31 2008, 12:38 AM
URY914 |
May 31 2008, 06:49 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 124,370 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Very nice. If you're going to do a job, do it right. And you did.
iamchappy |
May 31 2008, 07:56 AM
Just what i dont need, having to start on another project, Thanks!
Good work, I have considered recessing my lift into the floor as well, I have to use wooden ramps to drive up on to clear the lift. |
Gint |
May 31 2008, 08:14 AM
Mike Ginter Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Nice!
PRS914-6 |
May 31 2008, 08:29 AM
Another thing to consider if you are doing this and have a roll up door......I installed a Liftmaster 3800 jackshaft door opener. It operates off the spring shaft on the wall unlike the chain or screw style that sits overhead in the middle of the garage, just ripe to stick through the top of your car. (IMG:style_emoticons/default/sad.gif) I also extended the door tracking up 12". When open my door almost touches the ceiling, only eating up a few inches of ceiling height now.
Gint |
May 31 2008, 08:38 AM
I've been considering one of those for some time now to get the extra clearance for my lift. How much room does the liftmaster box need on the side of the door?
Krieger |
May 31 2008, 08:52 AM
Advanced Member Group: Members Posts: 4,771 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
(IMG:style_emoticons/default/smilie_pokal.gif) Very nice! I've never seen anything like that. Please post some pics when complete.
PRS914-6 |
May 31 2008, 08:58 AM
I've been considering one of those for some time now to get the extra clearance for my lift. How much room does the liftmaster box need on the side of the door? Normally you need about 3 inches vertical and 9" on the side. It can mount on the right or left side. I actually cheated by notching out the sheetrock and raised my shaft and operator even higher. The limiting factor is the spring shaft, not the operator. To get maximum clearance, I raised the shaft as high as possible and then raised the end of the track as high as possible. The result is a track that is not quite level overhead but it really doesn't hurt anything and it gives maximum clearance in the center where you really need it. With my 10' ceiling, I can raise the 914 the full height of the lift and walk under the car without bending over. I'm a short guy though....... |
Gint |
May 31 2008, 11:39 AM
My ceiling is only 9.5' and I'm not really short. I need all the room I can get. I'm using a hydraulic stool on wheels and roll around underneath. It actually works pretty well, but I'd love to get the extra height.
roadster fan |
May 31 2008, 02:49 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
(IMG:style_emoticons/default/wub.gif) Another inspiration. I agree with Eric, please show us something you did in your shop below your usual standard. please, please, please....... (IMG:style_emoticons/default/pray.gif)
Awesome job. I saw a similiar project on another forum (garage journal maybe) that had a cover over it to make a smooth floor when not being used. No chance to roll an ankle etc. Jim |
plymouth37 |
May 31 2008, 06:22 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
Wow, nice setup. I need one!
ConeDodger |
Jun 1 2008, 11:55 AM
Apex killer! Group: Members Posts: 23,859 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Yeowza... nice job (as usual) Humor us; show us a picture of something you've done 1/2 assed! Let us know you're mortal damn it!! (IMG:style_emoticons/default/biggrin.gif) E, You ought to see his tractor leak hydraulic fluid! (IMG:style_emoticons/default/biggrin.gif) I benefitted from this purchase and install. I got his previous lift that goes to about 40" high... Plenty for me. |
So.Cal.914 |
Jun 1 2008, 12:02 PM
Yeowza... nice job (as usual) Humor us; show us a picture of something you've done 1/2 assed! Let us know you're mortal damn it!! (IMG:style_emoticons/default/biggrin.gif) E, You ought to see his tractor leak hydraulic fluid! (IMG:style_emoticons/default/biggrin.gif) I benefitted from this purchase and install. I got his previous lift that goes to about 40" high... Plenty for me. To bad Clay didn't have you around when him and Slits had there 'Height' contest. |
PRS914-6 |
Jun 1 2008, 12:15 PM
Hey I fixed that!!! (IMG:style_emoticons/default/chair.gif) Of course the reason was that the leaking hydraulic fluid was costing me 10 times more than the damn seal to fix it. Yep, I admit I am anally picky. Think about my poor wife having to deal with that (IMG:style_emoticons/default/slap.gif) |
ConeDodger |
Jun 1 2008, 12:28 PM
Hey I fixed that!!! (IMG:style_emoticons/default/chair.gif) Of course the reason was that the leaking hydraulic fluid was costing me 10 times more than the damn seal to fix it. Yep, I admit I am anally picky. Think about my poor wife having to deal with that (IMG:style_emoticons/default/slap.gif) Well there you go... I have been to Paul's house several times and the tractor was the only thing that came up a little short... And now, even that is (IMG:style_emoticons/default/biggrin.gif) Paul, do you have pics of the lift in the sunken bed yet? |
PRS914-6 |
Jun 1 2008, 12:43 PM
Paul, do you have pics of the lift in the sunken bed yet? Not yet. I'm really chomping at the bit to stick it in there (IMG:style_emoticons/default/w00t.gif) but I don't want to chip the concrete since it's so green. That lift weighs about 1500 lbs and it will tough to drop it in without incident. |
ConeDodger |
Jun 1 2008, 01:50 PM
Paul, do you have pics of the lift in the sunken bed yet? Not yet. I'm really chomping at the bit to stick it in there (IMG:style_emoticons/default/w00t.gif) but I don't want to chip the concrete since it's so green. That lift weighs about 1500 lbs and it will tough to drop it in without incident. Do you need help dropping it in? I know you are tight with your neighbors but I could come up if you want. I want to get you to install those Elephant Bushings on my rear control arms anyway. And I have a little repair to do on some lugs I got from Eric Shea. Two popped out during the shipping. He tack welds them in and maybe you could reweld them? Are you going to lower it in with the tractor? |
Lo-Fi Version | Time is now: 2nd January 2025 - 04:47 PM |
