turboman808 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States ![]() |
Wow! That really opens up the view of that section of the engine. Your engine is looking great. I've really come to appreciate the underlying simplicity of the Subie engines, once all the modern complexities are stripped away. Glad I could help. Just for a little more Subie bling, here's a shot of the SVX that's going in my Syncro Westy. Couldn't resist getting the intake polished. As you can see, I went to the Sir Andy School of Photograpy. (IMG:style_emoticons/default/wacko.gif) Hijack over....now get back to work on the Biter. The 914 Nation awaits your progress. That is a really pretty motor. |
plymouth37 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest ![]() ![]() |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,121 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Thanks. The intake does a great job of covering all the wiring and plumbing. |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 124,582 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
I'm guessing it was Dana who broke into my garage and started tearing into my Matchbox (IMG:style_emoticons/default/laugh.gif)
plymouth37 |
HAHAHA, The resemblance is uncanny!
plymouth37 |
I finally finished a tough semester and I leave for a month long stay in Rome in 13 days so I decided to really push to make some progress on the car before I leave.
I took a big leap and decided to take the car to the next level and go with a full tube chassis in the rear. I will be able to drop a ton of weight and can custom build everything to mount the Subie engine rather than relying on a conversion kit. I would love to go with a double a-arm set-up in the rear but with out a chassis bench I don't feel like it's something I can do right. Since I will be retaining the stock swing arms I had to build a couple jigs to locate the swing arm mounts on the new frame. In addition to the jigs I took hundreds of measurements to make sure everything ends up where it needs to be. ![]() I will be raising the swing arm mounts 2" so the swing arm sits level at the cars lowered ride height. ![]() After a couple hours of careful cutting the two halves were separated. No turning back now! (IMG:style_emoticons/default/sawzall-smiley.gif) ![]() |
plymouth37 |
Here is what I am working with, I managed to remove the rear half of the car without hitting the jigs and according to my measurements the swing arm mounts are right where they should be.
The tubes of the rear frame will tie into my existing cage and into the longs. ![]() The Renegade conversion cradle weighs 28 pounds and the bare rear section I removed without suspension, lid, or diffuser weighed 144.4 pounds, I would be amazed if the new tube frame and f/g fenders weigh half that. ![]() I couldn't resist mocking up the 2 Anklebiters in the garage shot (IMG:style_emoticons/default/biggrin.gif) Stay tuned, lots of work on its way! ![]() |
BKLA |
Really old member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest ![]() ![]() |
Holy (IMG:style_emoticons/default/stromberg.gif) !
That's something I didn't expect. Looking forward to the (re)build! |
KELTY360 |
Holy crap! You've got stones the size of boulders. This pic reminds me of the old vaudeville magicians that sawed their assistants in half. Rock on!
![]() Did you cut it with the saw hanging on the wall? |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,458 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
I agree, you're very brave! (IMG:style_emoticons/default/smile.gif)
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,649 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
plymouth37 |
HAHAHA, I suppose I should put a not safe for purists warning on this!
Don't worry, it will be done perfectly, no corners will be cut. On the bright side I got a kick ass 914 trailer out of the deal! |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Tis but a scratch!
A scratch? Your car is cut in two! No, it isn't! Well, what's that then? (IMG:style_emoticons/default/laugh.gif) Sorry, that's what through my head when I saw that pic, Monty Python aside you sir are crazy (in a good way) Ferg |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Uh.. you cut it in half to do... what?
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
plymouth37 |
Uh.. you cut it in half to do... what? Lighter, faster, better, give me a week or so, I have things planned (IMG:style_emoticons/default/happy11.gif) |
carr914 |
Holy Snikeys
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,800 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Bullshit, he's doin a limo. And while the guys are away in Tahoe his going to get it done and claim the first right to a 914 Limo. He scheemed and waited till they were gone. This is going to divide 914 world into 914 universe and 914 world. Oh the drama. (IMG:style_emoticons/default/wacko.gif)
Millerwelds |
Pleepleus ![]() ![]() ![]() Group: Members Posts: 728 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California ![]() |
Bullshit, he's doin a limo. And while the guys are away in Tahoe his going to get it done and claim the first right to a 914 Limo. He scheemed and waited till they were gone. This is going to divide 914 world into 914 universe and 914 world. Oh the drama. (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/lol-2.gif) |
plymouth37 |
Bullshit, he's doin a limo. And while the guys are away in Tahoe his going to get it done and claim the first right to a 914 Limo. He scheemed and waited till they were gone. This is going to divide 914 world into 914 universe and 914 world. Oh the drama. (IMG:style_emoticons/default/wacko.gif) Gee thanks a lot, way to ruin the surprise! (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 19th April 2025 - 11:21 PM |
