82 Pages V « < 26 27 28 29 30 > »
> The Project Anklebiter Build Thread., 8/29 Lid latches and glamor shots...
plymouth37
post May 20 2010, 08:21 PM
Post #541
I welded in the rear frame mounts, The entire back half of the frame and the body attached to it will be removable for easy access and/or replacement.
The couplers are really machined well and are guaranteed to some ridiculously high shear strength.
I also fabbed up the tranny mounts, the tranny mounts are oriented in the stock direction but I put them under the tranny rather than hanging it from them.
This location will work much better for the cage design I have in mind.
plymouth37
post May 20 2010, 08:44 PM
Post #542
I moved the swing arm mounts up 2" so the swing arm sits level at ride height and ran the main tube back to the tranny mounts.
Krieger
post May 20 2010, 08:58 PM
Post #543
Very cool! Nice ideas and execution.
plymouth37
post May 20 2010, 09:30 PM
Post #544
I finished up the passenger side "frame rail" and moved on to the drivers side.
plymouth37
post May 20 2010, 09:39 PM
Post #545
I then wrapped up the drivers side.
When I get back from Rome in a month I will build the X-Brace and the lower tube that will connect to the tranny.
Zaney
post May 20 2010, 09:51 PM
Post #546
Deuchland en der Haus
Porsche needs to hire you and have you in charge of the 918 or 'modern 914' project!
This is insane!!! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
Say 'Hi' to Roma for me.
(IMG:style_emoticons/default/beerchug.gif) Nate
KELTY360
post May 20 2010, 11:30 PM
Post #547
914 Neferati
Breathtaking
PeeGreen 914
post May 20 2010, 11:34 PM
Post #548
Wow Dana (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/aktion035.gif)
shoguneagle
post May 21 2010, 04:51 AM
Post #549
shoguneagle
WHAT A SURPRISE!!! I LOVE IT!!! Very, very nice adaption and goes beyond the normal car conversions, either body and/or engine configurations. I love projects that are being developed/are developed such as this one. Warms my heart to see engineering and project execution done with such talent, thought, and . . . . . . . . .! Keep going!!
You probably are doing what a lot of us would like to do - I am pulling for you, Tiger.
Steve Hurt
J P Stein
post May 21 2010, 06:14 AM
Post #550
Irrelevant old fart
Like building a house, everything starts with the foundation. You've shown us part of the framing, but not the foundation. What is happening forward of the firewall?
plymouth37
post May 21 2010, 07:15 AM
Post #551
I couldn't resist mocking up the trailing arms and wheels to see how it looks.
JP, you can kind of see the main cage in these pics, I will post better views later, I am going to add some tubing to the passenger compartment to strengthen the tie in points for the new rear chassis section in a month or so.
plymouth37
post May 21 2010, 07:18 AM
Post #552
The rear section that I have fabbed up so far weighs in at 52 pounds, the rest of what I am adding will not weigh more than 30 or so pounds including the f/g fenders so it looks like I am looking at losing around 100 pounds bringing the grand total to 550.4 pounds lost or the equivalent of gaining 100.7 horsepower.
Do I win the "most jackstands used to hold up a 914" award?
MDG
post May 21 2010, 07:26 AM
Post #553
Wolf in wolf's clothing.
Unreal stuff, Dana. You're turning into a mad scientist before our eyes.
Dr Evil
post May 21 2010, 08:41 AM
Post #554
Send me your transmission!
Dude, you have a real problem. When you get tired if this foolishness (after it is completed) you should sell it to me. I will start donating plasma now to save up (IMG:style_emoticons/default/wink.gif)
Scott S
post May 21 2010, 09:17 AM
Post #555
Small Member
you get more done in a week than I do in a year!! Cant wait to see the car. Simply fantastic work!! (IMG:style_emoticons/default/beerchug.gif)
KELTY360
post May 21 2010, 09:50 AM
Post #556
914 Neferati
Still not sure how you'll make it rust. (IMG:style_emoticons/default/screwy.gif)
J P Stein
post May 21 2010, 11:10 AM
Post #557
Irrelevant old fart
QUOTE(plymouth37 @ May 21 2010, 06:15 AM) *
I was thinkin' that was the case....you haven't done anything half assed yet. (IMG:style_emoticons/default/biggrin.gif)
I've been watching your thread with interest....more so now as there may be a Subi in the shitboxes' future. It needs another 150hp and the 2 valve motor won't go there
at a reasonable price. I hear there a JDM TT Subi motor.....true?
plymouth37
post May 21 2010, 02:23 PM
Post #558
Okay so here is where it gets interesting, as you can see the frame is not set up for the conventional vertical coilover placement. Having to build the frame a foot higher than it needed to be seemed like a waste of tubing and an unnecessary weight addition up high so I am going cantilever. And I rendered a little diagram:
Here is an exploded view:
And here it is with one inch past maximum travel in either direction.
I am using QA1 aluminum shocks with 400# springs and 4" travel, with the 2-1 lever the suspension will see 8" of travel and a 200# spring force.
The top of the shocks will mount on the X-member right above the diff, kind of like this very loose mock up. The coilovers also weigh a total of 6 pounds less than the stockers and that is pretty significant for a partially unsprung part.
Dr Evil
post May 21 2010, 03:11 PM
Post #559
SICK!
MDG
post May 21 2010, 03:18 PM
Post #560
(IMG:style_emoticons/default/blink.gif) Like I said, Mad Scientist. This is actually the apparatus that channels the lightning strike into creating life . . ..
QUOTE(plymouth37 @ May 21 2010, 04:23 PM) *
- Lo-Fi Version Time is now: 20th April 2025 - 12:32 AM
