82 Pages V « < 33 34 35 36 37 > »
> The Project Anklebiter Build Thread., 8/29 Lid latches and glamor shots...
plymouth37
post Dec 12 2010, 07:24 PM
Post #681
Then I sprayed the parts with high heat paint and hung them in front of my trusty Reznor heater to bake.
This is starting to look like progress!
plymouth37
Post #682
Gint
post Dec 12 2010, 10:01 PM
Post #683
Mike Ginter
Very nice!
Hey Dana... got a tig machine? Can you weld aluminum? My Audi has a crack in the oil pan.
plymouth37
post Dec 12 2010, 10:05 PM
Post #684
I do have a tig but it is in storage up in Wyo, never been great at welding aluminum either, wish I was though.
plymouth37
post Dec 17 2010, 12:04 AM
Post #685
I finally finished this semester yesterday so I decided to spend some of my new found freedom working on the car. I wanted to start nailing down details like exhaust but I had to get the engine in a fixed position before I made any more progress on the drivetrain. I fabbed up an engine mount cross member, this one is almost identical to the Renegade one I used to run on my car, just the ends are at a slightly different angle.
Here is an under side view of the engine mount setup.
And a shot from the top, I am going to weld in threaded mounting holes into the chassis but everything is just hose clamped together until I can pick some up.
Hontec
post Dec 17 2010, 03:20 AM
Post #686
I see things.....
Region Association: Europe
Lookin' good, as usual!!! (IMG:style_emoticons/default/piratenanner.gif)
wingnut86
post Dec 17 2010, 12:06 PM
Post #687
...boola la boo boola boo...
Dana,
I'm most impressed young Jedi...
Maybe I should just rack, stack and tow my 2 out to Colorado for skiing.
Hmmm, maybe drop by for a cup of cocoa, 3-weeks of body and chassis work and take in the big skies (IMG:style_emoticons/default/drooley.gif)
2nd thought - I'll just freeze in the deep south and dream a little dream...
(IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/pray.gif)
-- Dave
Aka Wingnut
PeeGreen 914
post Dec 17 2010, 05:44 PM
Post #688
(IMG:style_emoticons/default/aktion035.gif) Nice Dana. Can't wait to see what you are able to do over the break (IMG:style_emoticons/default/smile.gif)
914Sixer
post Dec 18 2010, 07:31 AM
Post #689
Really bad to the bone !!!!! Keep up the excellent work.
nsr-jamie
post Dec 18 2010, 09:49 AM
Post #690
914 guy in Japan
Excellent!! Always glad to see updates in this thread, its one of my favorites. Thanks!!
plymouth37
post Dec 18 2010, 01:06 PM
Post #691
I had an hour or so to work this morning and pieced together an f-ing huge exhaust. I wanted to use oval tubing but since the exhaust had to follow a kind of complex path I decided to fabricate it out of 3" round tubing with a 1" spacer in the middle, the equivalent area is about that of 3.5" round tubing. Once I have a little more time I will weld it up, add an O2 sensor bung, and finish it smooth.
I think this should flow pretty well (IMG:style_emoticons/default/biggrin.gif). I will run this portion of the exhaust when I test the bare chassis, then eventually add on a full (but still muffler-less) exhaust once the body is on.
KELTY360
post Dec 18 2010, 01:40 PM
Post #692
914 Neferati
QUOTE(plymouth37 @ Dec 18 2010, 11:06 AM) *
An hour or so? You make me sick Dana, I haven't accomplished that much all year.
The Anklebiter just gets better....and better....and better...and better...and.......................
plymouth37
post Dec 18 2010, 01:43 PM
Post #693
Thanks! I used to build headers for Renegade so fitting tubing goes pretty quick for me, I can't wait to hear how this sounds, the turbo is going to scream!
KELTY360
post Dec 18 2010, 01:48 PM
Post #694
914 Neferati
QUOTE(plymouth37 @ Dec 18 2010, 11:43 AM) *
Looking forward to seeing how you'll set up the cooling system. Is that next?
plymouth37
post Dec 18 2010, 08:08 PM
Post #695
QUOTE(KELTY360 @ Dec 18 2010, 01:48 PM) *
I am going to wrap up the rear end first, amputate the back of the tub, then tackle the front end with the cooling system. I am going with my Renegade radiator mounted in the front of the car with a custom shroud.
KELTY360
post Dec 18 2010, 10:58 PM
Post #696
914 Neferati
QUOTE(plymouth37 @ Dec 18 2010, 06:08 PM) *
Does that mean we get to see the diffuser in place soon? (IMG:style_emoticons/default/drooley.gif)
iamchappy
post Dec 19 2010, 12:47 AM
Post #697
It all happens so fast!
Sick, talk about zero restriction.......
TC 914-8
post Dec 19 2010, 09:18 PM
Post #698
Hi Dana, I've been following your thread for quite a while (lurking) to say the least. Whats the chance of you making it to the WCR in June ?
At the rate you are going I think its possible.. (IMG:style_emoticons/default/welder.gif)
Everyone needs to chime in (IMG:style_emoticons/default/cheer.gif)
plymouth37
post Dec 19 2010, 11:57 PM
Post #699
QUOTE(TC 914-8 @ Dec 19 2010, 09:18 PM) *
There is no way the body will be done but I am not opposed to driving a bare chassis!
I may show up looking like this:
MDG
post Dec 20 2010, 07:11 AM
Post #700
Wolf in wolf's clothing.
QUOTE(plymouth37 @ Dec 20 2010, 12:57 AM) *
That would actually be pretty cool. Not sure about about a flathead for your car though.
- Lo-Fi Version Time is now: 20th April 2025 - 06:56 AM
