Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
Awesome build. And since you got all of us in the peanut gallery at 914world watching, you are never really without a net (IMG:style_emoticons/default/biggrin.gif)
Interested in seeing the rear suspension with axles in there. Looks like the axles go either behind or inside the black squared-off piece? Also super interested in a rear diffuser for the 914... That exhaust would be just fine popping up out the top like a stinger on a Baja Bug! I love that look! Thanks for sharing all the great photos and posts (IMG:style_emoticons/default/beerchug.gif) |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
I M N awe. Definitely one of the best threads EVER on this site (IMG:style_emoticons/default/beerchug.gif) AGREE!! (IMG:style_emoticons/default/beerchug.gif) |
plymouth37 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest ![]() ![]() |
I built the speed sensor bracket today, installed the axles, and painted the intercooler tubing and exhaust.
plymouth37 |
![]() Check out inside the exhaust in this pic, you can see the O2 sensor and all the way back to the wastegate, this should flow pretty well! ![]() |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,121 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Looking at that bracket makes me wonder how your weight saving tally is going. Do you have a target weight?
plymouth37 |
Right now the weight savings are somewhere around 525 pounds give or take. If it ends up around 1800 pounds when it is completely done I would be happy, could end up much lighter though.
Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
What are you using for a speed sensor?
I got a Hall Effect Sensor from Small Car Performance for mine, but I haven't installed it yet. -Britain |
Hontec |
I see things..... ![]() ![]() Group: Members Posts: 261 Joined: 23-September 10 From: Netherlands Member No.: 12,210 Region Association: Europe ![]() |
Superb Dana!!!! Excellent work.... can't wait to see how you are going to build the body.. (IMG:style_emoticons/default/piratenanner.gif)
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
I'm pretty sure when Dana gets an idea, right before he executes it, he goes "BWAHAHAHAaaaaaa . . ."
Too cool for words. (IMG:style_emoticons/default/thumb3d.gif) |
plymouth37 |
What are you using for a speed sensor? I got a Hall Effect Sensor from Small Car Performance for mine, but I haven't installed it yet. -Britain I honestly don't remember all it says on it is "0140", I think I got it from North Hollywood Speedometer, pretty sure it is the one Renegade sells for their Subie kits. |
plymouth37 |
I made a little progress yesterday.
I built the mounts for the coolant tank and the fuel pump/filter assembly. ![]() |
plymouth37 |
I am running a 928S pump on its stock bracket, the filter is on its way. Sorry for the bad shot, it is hard to get a good view of it.
![]() The coolant tank is stock WRX, just relocated to the other side of the engine. By deleting the throttle body heater I was able to lower the coolant tank by about 3" while still keeping it at the highest point in the system by 4 or so inches. ![]() |
plymouth37 |
Then I plumbed the rest of the engine's coolant lines.
KELTY360 |
Looks like you had to modify the oil filler tube. Is that still the SVX piece or did you use something else?
plymouth37 |
Looks like you had to modify the oil filler tube. Is that still the SVX piece or did you use something else? I have the stock wrx filler in there for now, the clearances were close enough with the engine raised that I was keeping the SVX piece off of the car while I put in the engine cross bar for fear of breaking it, I will be swapping it back in after I am done working on the tube chassis. |
Britain Smith |
What did you use for a throttle cable?
-Britain |
plymouth37 |
I got it custom made by terrycable when I did my conversion at Renegade, I think they sell them now.
Britain Smith |
Really...I will give them a call. How do did you route it? What does the end at the throttle pedal look like? Does it just go into the stock ball socket?
-Britain |
Britain Smith |
Looking at their catalog, didn't see the Subaru conversion cable....but it is a good thing they list a cable for a Porsche 935. Bet they sell a lot of those.
-Britain |
plymouth37 |
It is a custom cable, you specify length and what threads you need on the ends, then they supply the necessary hardware to adapt to whatever you need. It is routed like the stock one through the tunnel and attaches to the pedal like the original.
Lo-Fi Version | Time is now: 20th April 2025 - 11:19 AM |
