82 Pages V « < 38 39 40 41 42 > »
> The Project Anklebiter Build Thread., 8/29 Lid latches and glamor shots...
RJMII
post Jan 25 2011, 03:22 PM
Post #781
Jim McIntosh
What size of wheels are those? (IMG:style_emoticons/default/biggrin.gif) We could use the wheel diameter and a little bit of math and get some dimmensions for the a-arms. I'm liking the way those a-arms look like they mount, too.
db9146
post Jan 25 2011, 03:30 PM
Post #782
I am making the back half fairly independent, you could just bolt it to the front half of anything that had matching connection points, hook up a fuel line and have a self sufficient rear suspension and drive train. 350hp 3 wheelers could be fun, how about a home built Atom?
So let's see....you've got the sports car covered. If you found a VW bus and did the same to it, you'd have a family hauler or a camper. You could add a VW squareback or notchback for an estate wagon or family sedan, all using the same power plant. Kinda like swapping a battery pack into one of those multi-tool Dewalt kits. There you go!!! (IMG:style_emoticons/default/shades.gif)
Hontec
Post #783
I see things.....
Region Association: Europe
Dana, you used to work for Renegade right?
I have a question regarding the tacho; is the stock 914 unit compatible with the Subie output? (probably not) How are you going to run this? I bet you have experience with this.
Thanks
Randall
plymouth37
post Jan 25 2011, 06:19 PM
Post #784
QUOTE(Hontec @ Jan 25 2011, 03:30 PM) *
Thanks
Randall
I had mine refinished and re-calibrated by North Hollywood Speedometer, they also added the boost gauge, LED lighting, and changed the redline to match the subie's.
Hontec
post Jan 26 2011, 02:25 AM
Post #785
I see things.....
Thanks! (IMG:style_emoticons/default/cheer.gif)
plymouth37
post Jan 30 2011, 12:22 PM
Post #786
I did a little wiring yesterday. I started out by building a harness for the car's rear lights and rear mounted sensors. The harness will plug into the main harness at the firewall and at the other end the rear clamshell will plug into it for the taillights, this way it is still possible to break the car into components easily.
Then I pulled the subaru engine harness, ran any extra wires I needed to, and combined it with the car harness I had just built. Within the harness I ran a few extra wires to various parts of the car, this way any extra sensors or electronics I want to run in the future are already wired and ready to go.
Remember when it only took about 4 wires to hook up an engine? Well those days are gone!
plymouth37
post Jan 30 2011, 12:23 PM
Post #787
And here is the harness installed, I still need to run the battery cables but other than that the entire rear of the chassis is wired.
Since it was readily accessible, here is a shot of the front of the engine. Also notice that the engine is lacking a Perrin lightweight pulley, gonna have to fix that problem soon!
plymouth37
post Feb 11 2011, 02:01 PM
Post #788
I did a lot of trimming and wire wheeling on the firewall today. I have stripped the entire rear of the tub and trimmed it down to a point where I can start rebuilding the fire wall and longs.
I also decided that if I am going to build a high quality fiberglass or carbon body I need a perfect steel body to take a mold off of. Because of this I have decided to trade my lightweight lids for stock steel lids, If you want to trade click here. I think by starting with steel, I material that I am much more competent working with, I can end up with a much better final product. And then once I make a carbon body, one of you can have the steel one (IMG:style_emoticons/default/wink.gif)
Hontec
post Feb 11 2011, 02:11 PM
Post #789
I see things.....
Nice work! Are you excited to start building up again? Can't wait to reach that stage..
fat73
post Feb 11 2011, 02:30 PM
Post #790
W9R1
QUOTE(plymouth37 @ Jan 25 2011, 04:19 PM) *
Thanks
Randall
Hey Dana,
What boost sensor are you using? My boost guage stays pegged all the time. I thought I put a 930 sensor on there. Is that right?
Ed
BKLA
post Feb 11 2011, 08:04 PM
Post #791
Really old member
I can see a bidding war on the steel shell already!
Looks great!
plymouth37
post Feb 16 2011, 09:36 PM
Post #792
I got some welding done today, I reconfigured the upper portion to eliminate the stock dip and added about a foot of weld between the cage and the tub in the process. I also seam welded the firewall and ground down the pinch weld that splits the firewall in half.
Before:
plymouth37
Post #793
After:
majkos
post Feb 17 2011, 08:56 AM
Post #794
Very nice Dana!
I like how you made it so smooth.....
Care to help me with the Kar-B-Q ? (IMG:style_emoticons/default/av-943.gif)
KELTY360
post Feb 17 2011, 09:25 AM
Post #795
914 Neferati
Looks heavy. You must have added at least 8 oz. (IMG:style_emoticons/default/poke.gif)
plymouth37
post Feb 21 2011, 08:53 AM
Post #796
I started rebuilding the frame rail area of the firewall. Since the tub will end at the firewall I had to amputate the frame rails.
Here is how much I needed to remove to get to flat, rust free metal.
I welded in a filler plate, the frame rails, cage, and inner structure are all welded to the filler piece, hopefully this should tie all of the inner structure together.
plymouth37
post Feb 21 2011, 08:57 AM
Post #797
Here is a before and after shot, after I finish welding up the drivers side I will start fabbing up the outer structure that will tie the door jambs into the rest of the firewall
KaptKaos
post Feb 21 2011, 10:40 AM
Post #798
Family
Have you seen this???
http://www.autoblog.com/2011/02/18/you-can...powered-kit-ca/
http://www.factoryfive.com/whatsnew/update...nouncement.html
plymouth37
post Feb 21 2011, 07:44 PM
Post #799
QUOTE(KaptKaos @ Feb 21 2011, 10:40 AM) *
Very cool! The WRX engine really is a perfect power plant for a sub 2000 pound sports car. I am surprised it took them this long to come out with a good kit with Subie power. Nice find!
plymouth37
post Feb 21 2011, 09:14 PM
Post #800
QUOTE(fat73 @ Feb 11 2011, 02:30 PM) *
Hey Dana,
Ed
Hey Ed,
Mine is a VDO piece.
The part number reads: 993-606-103-00
The other side reads: 0-1.5 Bar
- Lo-Fi Version Time is now: 20th April 2025 - 12:47 PM
