82 Pages V « < 41 42 43 44 45 > »
> The Project Anklebiter Build Thread., 8/29 Lid latches and glamor shots...
plymouth37
post Mar 26 2011, 10:10 PM
Post #841
QUOTE(Rand @ Mar 26 2011, 09:44 PM) *
So I assume front shocktower to hoop in the cab is eminent?
Yep, I need to start figuring out the best way to beef up that area next, it is going to be a little tricky to route the tubing around the gas tank but I should be able to get a good amount of tube in there to connect the nose to the rest of the cage.
wes
post Mar 27 2011, 12:09 PM
Post #842
wes
I must say simply amazing work, it has inspired me to work on my own wich is nothing in comparison, thanks and keep up the great work! (IMG:style_emoticons/default/piratenanner.gif)
plymouth37
post Mar 27 2011, 12:54 PM
Post #843
Spring break is drawing to a close, back to school tomorrow.
I bolted the chassis back together and mocked up the body next to it, I have 2 914s now!
plymouth37
Post #844
Mike Bellis
post Mar 27 2011, 01:41 PM
Post #845
Resident Electrician
I think you should look into this fuel cell. It will fit in the stock location with minor mods and give you clearance for the tubing. http://www.summitracing.com/parts/RCI-2161A/
plymouth37
post Mar 27 2011, 02:02 PM
Post #846
QUOTE(kg6dxn @ Mar 27 2011, 01:41 PM) *
Nice find, that could be perfect, anybody have a pic of one like this installed?
plymouth37
post Apr 16 2011, 03:14 PM
Post #847
I did some sidework for my neighbor who is restoring a victorian house next to us and earned enough dough to buy some shiny bits for the car.
If I am going to insist on keeping the antiquated 914 box I figured I had better make it shift as well as possible.
After a call to JWest a Rennshifter and their stage 1 shift linkage showed up.
They are discontinuing the 914 shift linkage and only have the stage one left so if you want one now is the time to order.
post Apr 16 2011, 03:52 PM
Post #848
QUOTE(plymouth37 @ Jun 9 2008, 12:08 PM) *
Here's the plan:
Tub up restoration/customization (no cutting corners here).
Speedster styling.
40" tall
Under 1800 pounds.
320 horsepower WRX engine.
Let the games begin!
Very very SWEET build! Congrats and enjoy in good health !
smontanaro
post Apr 16 2011, 05:00 PM
Post #849
You should talk with Mark in Bartlett, IL (screen name "Bartlett 914") about his new shifter setup.
Skip
fat73
post Apr 16 2011, 07:48 PM
Post #850
W9R1
QUOTE(plymouth37 @ Apr 16 2011, 01:14 PM) *
They are discontinuing the 914 shift linkage and only have the stage one left so if want one now is the time to order.
You won't regret that shifter. Let me know how the other parts work out with the Renegade setup. (clearance wise)
banksyinoz
post May 14 2011, 05:12 PM
Post #851
finally getting back into it
Region Association: Australia and New Zealand
(IMG:style_emoticons/default/pray.gif)
OMFG
i am inspired, i love this, cant wait to see the final result
tscrihfield
post May 14 2011, 05:31 PM
Post #852
Drive Fast and Take Chances
QUOTE(banksyinoz @ May 14 2011, 07:12 PM) *
OMFG
This is one of those threads you hope that has been finished already from years ago.... So you can read it from start to finish without waiting! Impaitience takes over when watching a Thread like this one! Great work! You are quite a fabricator!
Thomas
513mugsy
post Jun 3 2011, 08:27 AM
Post #853
This has to be the most mind blowing buildup that I have ever come across. Dana you have to be the most productive fab'er that I have seen. I have a couple of questions... how much of this just comes out of your head and how much have you designed out on paper that we don't see? And how much weight could be saved if you redesigned the rear trailing arms to a chromoly tubing setup...maybe 20-25 lbs a pc? It took me 12 hours to read it all from the start. Very impressed and looking forward to seeing the finished product.
plymouth37
post Jun 3 2011, 08:48 PM
Post #854
I ran the coolant lines today. There are a few ways to run them through a 914, I used to have rubber lines running below the floor but wanted to integrate them into the car a little better so I decided to try a different route. I poked around the site and really liked the way Britain Smith ran them in his subie conversion and decided to follow a similar path.
First I welded in tubing that led through the front firewall into the passages that pass beneath the gas tank,
plymouth37
post Jun 3 2011, 08:51 PM
Post #855
Then I opened up the other end of the passage and the end of the long and welded in tubing to protect the hose from sharp edges.
Next step is to make some nice covers to seal off the area where the hose passes through the cabin.
plymouth37
post Jun 3 2011, 08:53 PM
Post #856
Finally I opened up the back of the long and welded in a tube that passes through the firewall.
majkos
post Jun 3 2011, 09:18 PM
Post #857
Hmmm........ (IMG:style_emoticons/default/idea.gif)
I like it.
Glad you done your homework,Dana! (IMG:style_emoticons/default/thumb3d.gif)
Britain Smith
post Jun 3 2011, 10:48 PM
Post #858
Nano Member
Looking good. I want to see what you come up with to cover the lines inside the cabin...I might want you to make an extra set (IMG:style_emoticons/default/smile.gif) Needs to be lightweight!
-Britain
plymouth37
post Jun 13 2011, 05:59 PM
Post #859
I mounted the radiator today, I am running the standard Renegade unit, due to the new position I had to change the outlet tube's angle and the location of the bleeder. Luckily there is a helicopter repair place close to my house that can weld anything to anything so they could handle welding the aluminum radiator easily.
Keeping with my tradition of mounting everything as low and inboard as possible, the radiator is mounted far inside the trunk, it is at a pretty steep angle but with proper shrouding I believe it will cool the engine just fine.
plymouth37
post Jun 13 2011, 06:00 PM
Post #860
Here is a close up of the mounts, the radiator is rubber insulated at all 4 corners.
- Lo-Fi Version Time is now: 20th April 2025 - 11:19 AM
